Where do you buy super cheap reading glasses?
by MoneyJohn - 02/20/20 11:34 AM
Caliper Boot Was Loose When Changing Pads
by Fitz98 - 02/20/20 11:15 AM
Non-Detergent and Additized Mono-Grades
by MolaKule - 02/20/20 11:14 AM
$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
Jason454, Max331, 4fordsd, Mayberryminitruc, DaiwaGuy
70759 Registered Users
112 registered members (Anduril, apollo18, Astro14, 928, 2012AccentSE, aquariuscsm, 7 invisible), 2,272 guests, and 21 spiders.
Topics301,698
Posts5,200,876
Members70,759
Page 4 of 4 1 2 3 4
Re: What weight of oil 20 or 30? Rrrrrrr [Re: chubbie] #5142873 06/24/19 01:24 PM
supton Online Content
Online Content
Years ago I started writing date in YYYY-MM-DD. Seems to make the most sense for filing, be it files or folders on the computer, or papers in real life. Very simple, work from MSB to LSB.
I still marvel over the fact that while measuring distance and volume can be metric, time isn't. The second may be the base unit in metric but it's still 60 minutes to the hour, 24 to the day, 364 to the year. 7 days to a week and 30-ish days to the month. And then it gets beat up during leap years and other times of adjustment. Even metric users have to put up non-base 10 math when it comes to time. Yet the most common complaint about non-metric from metric users is... how do you remember all the different numbers if they aren't all related by factors of 10? but they manage to figure out the time of day and day of the year all the same.
2011 Toyota Camry, base, 2.5L/6MT, 201k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: What weight of oil 20 or 30? Rrrrrrr [Re: PimTac] #5142892 06/24/19 01:48 PM
J
Jimmy_Russells Offline
J
Originally Posted by PimTac
Could we refrain from using the R word here. It’s offensive. A grown adult does not need to use that word.
It's part of the chart man, I didn't put it there
The worst thing is tire sizes. Imperial, metric, and percentages all in one!
Re: What weight of oil 20 or 30? Rrrrrrr [Re: chubbie] #5142904 06/24/19 02:01 PM
Silverado12 Offline
24June19 is how we did it in the service. My first day was 03July78.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: What weight of oil 20 or 30? Rrrrrrr [Re: gfh77665] #5142908 06/24/19 02:06 PM
M
Mad_Hatter Offline
M
Originally Posted by gfh77665
Originally Posted by Mad_Hatter
Try this one...0 is freezing ❄️, 40 is freaking hot🔥. Now you can do my chart...😉
Years ago I learned:
"30 is hot, 20 is nice, 10 is cold, 0 is ice".
I like that, catchy..👍
Re: What weight of oil 20 or 30? Rrrrrrr [Re: Silverado12] #5142984 06/24/19 03:44 PM
K
ka9mnx Online Content
Online Content
K
Yep. That's the way we did it in the military and it stuck with me.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: What weight of oil 20 or 30? Rrrrrrr [Re: ka9mnx] #5143317 06/24/19 11:00 PM
chubbie Offline OP
Ok wow! A lot to read and follow on here now. So I guess the rams or the 3.7L was back specd to 5w-30 so either 20 or 30 weights would be ok.at least to me I does make sense to use the 30 weight with the heat. good.now this ocd loop in my mind can shut off.What is mds?
07 Dodge Ram 151K shell rotella gas truck 5w-30
18 Mazda cx5 61K pennz syn 0w-20
Re: What weight of oil 20 or 30? Rrrrrrr [Re: chubbie] #5143587 06/25/19 09:23 AM
G
gfh77665 Offline
G
Yes, use the 30wt in the summer. The 20wt's are spec just for CAFE purposes, not engine protection.
Re: What weight of oil 20 or 30? Rrrrrrr [Re: chubbie] #5143628 06/25/19 10:12 AM
W
WyrTwister Offline
W
When I was in chemestry & physice class , we used both metric & imperial / English systems all the time .
Wyr
God bless
Re: What weight of oil 20 or 30? Rrrrrrr [Re: WyrTwister] #5143641 06/25/19 10:26 AM
PimTac Offline
Actually it was pretty easy as long as you had your Pee Chee.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: What weight of oil 20 or 30? Rrrrrrr [Re: chubbie] #5143757 06/25/19 12:10 PM
DGXR Offline
I suggest 5w30, not only because of the various recommendations, but also because the vehicle is 12+ years old and probably has some wear. Also, most manufacturers recommending Xw20 oils do this for fuel economy/CAFE reasons and because it provides adequate engine protection, not because it's the best engine protection.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: What weight of oil 20 or 30? Rrrrrrr [Re: DGXR] #5144129 06/25/19 08:57 PM
chubbie Offline OP
I see makes sense also in the owners manual it says do engine oil changes at 5k miles never to exceed 6k miles. I'm assuming that is for conventional motor oil.it doesn't say anything about synthetic. Also I would change earlier if I was towing.about how long roughly could i go with synthetic without towing?
Re: What weight of oil 20 or 30? Rrrrrrr [Re: chubbie] #5144343 06/26/19 06:25 AM
ChrisD46 Offline
Ambient temp in a well running engine / cooling system probably means less to a grade of oil versus the proper protection the engine needs ... 5W20 may provide adequate engine protection however 5W30 may provide ideal engine protection .
'17 Hyundai Sonata 2.4L GDI 5W20 QSUD / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: What weight of oil 20 or 30? Rrrrrrr [Re: chubbie] #5150066 07/03/19 05:46 AM
J
JLTD Offline
J
The owners manual is a conservative estimate which is supposed to cover any oil… With UOAs you could easily extend your intervals, depending on your oil.
With the right synthetic, I would think that 10,000 mile intervals would be easily and safely done. Possibly more depending on your driving habits.
Lates.
Page 4 of 4 1 2 3 4
