Cadillac parked for 25 years...
by mattwithcats. 07/17/19 09:52 AM
Sumitomo Encounter Tires
by parshisa. 07/17/19 09:40 AM
API 1509 Updated with New GF-6B Shield
by Solarent. 07/17/19 07:27 AM
Car Vac Recommendations
by klt1986. 07/17/19 07:05 AM
ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
Aother MEGA score+Free Mobil 1 oil change
by GMguy84. 07/17/19 12:39 AM
I think I need therapy...
by tony1679. 07/16/19 11:53 PM
Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
My new rig - 1987 Ford Econoline 27' Glendale RV
by caprice_2nv. 07/16/19 07:44 PM
Air Compressor OCI?
by Vern_in_IL. 07/16/19 07:35 PM
guru2019, MBhuntington, captainfloss, Lyndol, Belczek
68682 Registered Users
104 registered members (4WD, anw2397, Alfred_B, 87sammy, aquariuscsm, 69GTX, 8 invisible), 1,936 guests, and 24 spiders.
Topics291,982
Posts5,014,534
Members68,682
Most Online2,967
Mar 10th, 2019
Motorcraft Mercon V opinions? #5143951
06/25/19 05:28 PM
06/25/19 05:28 PM
New Bern, NC
Vigilant Offline OP
Vigilant  Offline OP
New Bern, NC
Went back 3 years and could not find anything. Motorcraft Mercon V does not even show up in the top 5. Castrol variants show up twice. I just had a 2006 4R75E and 98000 miles self-flushed and refilled with Motorcraft Mercon V. A few years ago, I had another 2006 4R75E self-flushed and refilled with Mobil 1 ATF. 10000 miles later, the trans failed. I suspect it was because I refilled a high mileage trans with Mobil 1, and the trans didn't like it. Had it rebuilt and filled with Mobil 1, and it's doing great.
Is Motorcraft Mercon V worth using, or should I have bought Castrol? Thanks in advance.
2006 F-150 5.4 3V 4X4. M1 EP 5W20, Motorcraft oil filter. Changing to Fram Ultra next oil change.
2006 F-150 4.6 2V 4X2. Same as above.
Re: Motorcraft Mercon V opinions? [Re: Vigilant] #5144043
06/25/19 07:43 PM
06/25/19 07:43 PM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
If it is licensed MERCON V fluid (which I believe the Castrol is) then it won't make a bit of difference.
1994 BMW 530i, 242K
1996 Honda Accord, 277K
1999 Toyota Sienna, 418K
2000 Toyota ECHO, 281K
Re: Motorcraft Mercon V opinions? [Re: Vigilant] #5144146
06/25/19 10:24 PM
06/25/19 10:24 PM
MA
Wolf359 Online content
Wolf359  Online Content
MA
Yeah, it's all the same stuff, Castrol, Motorcraft, Supertech. Supertech is probably the cheapest. I used that in my Taurus transmission a few times and it was fine. If you don't want to do Super Tech at Walmart, there's always Castrol. Valvoline also sells one, but it's not really certified as Mercon V, the fine print just says it's suitable for applications that call for Mercon V although I've used it in the past when I got it on clearance at $2 a quart.
Re: Motorcraft Mercon V opinions? [Re: Vigilant] #5144168
06/25/19 11:18 PM
06/25/19 11:18 PM
Connecticut
69GTX Online content
69GTX  Online Content
Connecticut
If I could buy the Motorcraft Mercon V for the same $4.75 that SuperTech sells for, I'd buy it. But since it costs like $6.50 or so that's not going to work. Just did my 2001 Lincoln transmission fluid change with SuperTech Mercon V....16 qts.
I'm sure the add packs for Castrol, MC, and ST are all pretty similar. They are all semi-synthetic. I'd rather use these than the full synthetic Mobil 1, Amsoil ATF, or Red LIne D4 for example. I'll just change it more often....every 15K to 20K miles depending on how it looks.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Motorcraft Mercon V opinions? [Re: Vigilant] #5144206
06/26/19 12:54 AM
06/26/19 12:54 AM
New Bern, NC
Vigilant Offline OP
Vigilant  Offline OP
New Bern, NC
Thanks to the drain plug, I will drain the pan every 8000 miles when the oil (M1 EP) is changed, and add 4 fresh quarts. That's probably overkill, but I'm comfortable with it.
Re: Motorcraft Mercon V opinions? [Re: Vigilant] #5144283
06/26/19 05:36 AM
06/26/19 05:36 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
No kidding! That's every 2 months for me!
All I ever buy for my 4R75E is SuperTech Mercon V
Re: Motorcraft Mercon V opinions? [Re: Vigilant] #5144297
06/26/19 06:13 AM
06/26/19 06:13 AM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
Here is the Castrol product. smile
If you want the job done right......do it yourself.
Re: Motorcraft Mercon V opinions? [Re: Vigilant] #5144300
06/26/19 06:20 AM
06/26/19 06:20 AM
Michigan
dwcopple Offline
dwcopple  Offline
Michigan
I just picked up a '98 Mustang GT and am looking to extract the fluid from the pan and refill with Mercon V. I will most likely use SuperTech as it is readily available and priced right. I wish MaxLife was okay for Mercon V as it was a spectacular fluid in past cars I've ran it in.
2017 RAM Big Horn 4x4 3.6L V6
2011 Chrysler 200 Limited 3.6L V6
