API 1509 Updated with New GF-6B Shield
by Solarent. 07/17/19 07:27 AM
Car Vac Recommendations
by klt1986. 07/17/19 07:05 AM
ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
Aother MEGA score+Free Mobil 1 oil change
by GMguy84. 07/17/19 12:39 AM
I think I need therapy...
by tony1679. 07/16/19 11:53 PM
Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
My new rig - 1987 Ford Econoline 27' Glendale RV
by caprice_2nv. 07/16/19 07:44 PM
Air Compressor OCI?
by Vern_in_IL. 07/16/19 07:35 PM
Looking for an SUV
by dgunay. 07/16/19 07:29 PM
Castrol GTX Magnatec 5w30
by Envoyguy. 07/16/19 07:21 PM
2019 Subaru Dual X-Mode
by buster. 07/16/19 06:36 PM
guru2019, MBhuntington, captainfloss, Lyndol, Belczek
68682 Registered Users
105 registered members (AlienBug, AandPDan, 69GTX, aquariuscsm, Alfred_B, 2010Civic, 10 invisible), 1,874 guests, and 22 spiders.
Topics291,979
Posts5,014,501
Members68,682
Most Online2,967
Mar 10th, 2019
Brake Rotors #5143878
06/25/19 04:00 PM
06/25/19 04:00 PM
Texas
WyrTwister Offline OP
Texas
My brake rotor problems greatly diminished when I finally convinced my wife to stop and park the car ( or stay home ) when she detected brake noise / problems .
Brake friction material is much kinder , to the rotors ( or drums ) , than the steel backing plate ( or brake shoe steel ) . So the rotors or drums last much longer .
Then it all started over again when our daughter started driving ! :-(
Wyr
God bless
Re: Brake Rotors [Re: WyrTwister] #5143896
06/25/19 04:17 PM
06/25/19 04:17 PM
Illinois
Greatlake Offline
Greatlake  Offline
Illinois
Wow! Brilliant!
Thanks for sharing this information.
Re: Brake Rotors [Re: WyrTwister] #5143965
06/25/19 05:41 PM
06/25/19 05:41 PM
NH
supton Online content
supton  Online Content
NH
Meh, up here the rotors are probably near the end by the time it makes noise, at least for my wife and I. Our kids, who knows, they don't drive yet.
I'm also a big proponent of taking apart the pads on a yearly basis, and inspecting for delamination (and/or rust jacking). Good time to make sure everything is working properly. If something seems amiss, put the part on order, and replace at next tire rotation.
2011 Toyota Camry, base, 2.5L/6MT, 187k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 152k, ours
1999 Toyota Camry LE, 2.2L/4AT, 208k, his
Re: Brake Rotors [Re: WyrTwister] #5144048
06/25/19 07:57 PM
06/25/19 07:57 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
My better half is all too good at reporting strange noises, but it's up to me to inspect the vehicle on a regular basis to prevent damage like that. Tire rotation is the perfect time to do a quick visual inspect, or do the yearly break remove/clean/inspect/lube as supton mentions.
Various musings: http://hangfire.net
Re: Brake Rotors [Re: WyrTwister] #5144069
06/25/19 08:22 PM
06/25/19 08:22 PM
Texas
Texas
Thankfully , we do not live in the rust belt . Never worried about having to replace rotors or drums due to rust . Never taken brakes apart just to check them . If there are signs of impending problems , yes .
Does not mean we do not get occasional stubborn fasteners . But nothing like I see on youtube videos from the salt belt .
Our town often uses sand on ice / snow & not a great deal of salt . No salt would be fine with me .
Speaking of sand , you all ever see a sand storm ? :-)
All the best to you , :-)
Wyr
God bless
Re: Brake Rotors [Re: WyrTwister] #5144248
06/26/19 03:32 AM
06/26/19 03:32 AM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
I live in the rust belt. I have never replaced rotors due to rust, but I have replaced entire cars due to underbody rust.
Rust does not cause replacement, unless you only drive a vehicle once every 6 months. Otherwise every time you drive, the rust is scrubbed off the important area.
It can make getting rotors off a hub a pain, especially if it's the first time, but you get them off and clean the mating area and put some silicone grease or anti-seize in the contact area and it's no longer a problem.
Rust can decrease the disc cooling vane passage/effectiveness but I don't drive like a madman nor haul loads down long hills so that isn't an issue either.
Fasteners on the other hand, I don't have a problem with lug nuts but there are many other fasteners I go in assuming I will have to replace like sway bar links or lower shock bolts. An angle grinder is an automotive tool I'm not unfamiliar with.
Re: Brake Rotors [Re: WyrTwister] #5144304
06/26/19 06:27 AM
06/26/19 06:27 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Having put the rust belt in the rearview some four decades ago, rotor inspection and/or replacement for it just another thing to not miss. Simply drive into Discount Tire for a rotation and balance, as it's being done check pad thickness and rotor condition, drive on. Rust not been a factor in replacement decision.
Re: Brake Rotors [Re: Dave9] #5145023
06/26/19 07:34 PM
06/26/19 07:34 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
I had rust come through my front Dakota rotors from the vanes to the friction surface, and it was my daily driver. Granted, I was only putting 5K a year on it at the time, really short commute at that time.
Re: Brake Rotors [Re: Dave9] #5145073
06/26/19 08:21 PM
06/26/19 08:21 PM
MI
doitmyself Offline
doitmyself  Offline
MI
Say what? Do you think the salt and chemical exposure you get in Cincinnatti is equivalent to what we get up north?
Rotor rust up here certainly does cause premature replacement of rotors when there is still sufficient thickness on the pad areas:
[Linked Image]
Re: Brake Rotors [Re: WyrTwister] #5145084
06/26/19 08:35 PM
06/26/19 08:35 PM
northern NY
Driz Offline
Driz  Offline
northern NY
Knock that fur off those rotors with a small hammer and keep on trucking. That stuff doesn’t hurt anything other than making a light scraping noise when it rubs.
You know it’s bad when your caliper rots right through on a 12 year old GM OEM in Vermont. That’s a new one even to me but it sure happened to me.
