Hyundai ELantra ATF follow up
by flinter. 07/17/19 10:14 AM
Poor Bill
by 4WD. 07/17/19 10:05 AM
Cadillac parked for 25 years...
by mattwithcats. 07/17/19 09:52 AM
Sumitomo Encounter Tires
by parshisa. 07/17/19 09:40 AM
API 1509 Updated with New GF-6B Shield
by Solarent. 07/17/19 07:27 AM
Car Vac Recommendations
by klt1986. 07/17/19 07:05 AM
ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
Aother MEGA score+Free Mobil 1 oil change
by GMguy84. 07/17/19 12:39 AM
I think I need therapy...
by tony1679. 07/16/19 11:53 PM
Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
guru2019, MBhuntington, captainfloss, Lyndol, Belczek
68682 Registered Users
104 registered members (4WD, 97f150, 2012AccentSE, 2015_PSD, 14Accent, 1978elcamino, 8 invisible), 2,033 guests, and 22 spiders.
Topics291,984
Posts5,014,570
Members68,682
Most Online2,967
Mar 10th, 2019
Rubber cement tubes? #5143872
06/25/19 03:53 PM
06/25/19 03:53 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
Any tips or tricks to prevent rubber cement tubes from drying out after puncturing the seal? I’ve been patching tires the past number of years and it’s been working well. Except my cement tubes are often no longer any good by the time I need it again.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Rubber cement tubes? [Re: buck91] #5143875
06/25/19 03:58 PM
06/25/19 03:58 PM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
Zip lock bag might help.
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 188k miles
03 Saturn Ion 2.2 L4 5spd 239k miles
PP, PPHM 50/50 5w30
Currently under the influence of oil shocked2
Re: Rubber cement tubes? [Re: buck91] #5143882
06/25/19 04:02 PM
06/25/19 04:02 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I use wirenuts and tape to try to seal caulking tubes . Might try that on the tubes of rubber cement ?
Wyr
God bless
Re: Rubber cement tubes? [Re: buck91] #5143895
06/25/19 04:15 PM
06/25/19 04:15 PM
Arizona
Kawiguy454 Offline
Kawiguy454  Offline
Arizona
Keep the stuff in the house with minimal temperature swings. Living in AZ I have found that the expansion contraction from wide temperature swings causes most of the problem. The Volatile's tend to creep out of sealants and glues very quickly if kept in the garage. Otherwise maybe get a food vacuum sealer to put them in outside. Also a problem here are plastic bottles of stuff getting tiny leaks where the plastic bends/kinks from the heat cycles. Keeping the caps "Loose" so air can breathe in/out keeps that from happening but accelerates evaporation.
Re: Rubber cement tubes? [Re: buck91] #5143915
06/25/19 04:39 PM
06/25/19 04:39 PM
Somewhere in time
Imp4 Offline
Imp4  Offline
Somewhere in time
For as infrequently as I use these this kind of stuff, I consider the puncture type foil sealed tubes to be single use products.
No bagging, vacuum sealing, zip ties, stapling, Scotch tape, etc... is going to preserve the reminder of the product in the tube.
And if I turn out to be wrong, it's a win all around, but I sure don't count on it....
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Rubber cement tubes? [Re: buck91] #5143936
06/25/19 05:02 PM
06/25/19 05:02 PM
Upstate NY
Wheel Offline
Wheel  Offline
Upstate NY
I have the same problem with rubber cement. If I open a tube, I plan on having a spare because that one will be gone when I get back to it. I try to keep enough tubes that I can patch a bunch at once and waste less.
2009 Subaru Legacy (N/A)
Pennzoil Platinum Plus and NAPA filter
Re: Rubber cement tubes? [Re: buck91] #5143960
06/25/19 05:37 PM
06/25/19 05:37 PM
NH
supton Online content
supton  Online Content
NH
Last couple of times I've done this, I've waited until I have 3 or 4 tubes to fix. That way I'd hopefully use the whole tube up. Maybe use the last bit if I popped a tire within short time. But since I don't get that many flats, I wind up with bad tubes hanging on a hook, waiting for their tipping point. [On the plus side, a chopped up tube can make rubber strips for various projects.]
However I've had low success in gluing patches on. I think the last batch of tubes I got were super smooth and I didn't scuff enough for the patch. Became too much work to patch then only have it fail as I pumped up to pressure (installed).
2011 Toyota Camry, base, 2.5L/6MT, 187k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 152k, ours
1999 Toyota Camry LE, 2.2L/4AT, 208k, his
Re: Rubber cement tubes? [Re: buck91] #5144077
06/25/19 08:28 PM
06/25/19 08:28 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
You all are correct , I half way expect such products to be no longer useful , next time they are needed . But , being cheap , I keep trying to perserve them , anyway .
Wyr
God bless
Re: Rubber cement tubes? [Re: buck91] #5144200
06/26/19 12:45 AM
06/26/19 12:45 AM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
My strategy: Buy a big tube in the auto department, and store it in the freezer between uses. That greatly slows evaporation of the solvent in the glue.
I used to carry glue and patches on my bike instead of a spare tube. Unfortunately, I got flats so rarely that sometimes it dried out between uses.
2011 Toyota Prius now at 101K
Re: Rubber cement tubes? [Re: buck91] #5144561
06/26/19 11:46 AM
06/26/19 11:46 AM
Oregon
MrQuackers Offline
MrQuackers  Offline
Oregon
I had a flat on my beater, holes top and bottom from a nail. Got out the patch kit since I had no spare. Glue all dried out. Walked home, since it was less than a mile. Rummaged around and found some Park glueless patches I bought long ago. Usually patching a hole on the rim side is iffy but the tube is still holding air weeks later. I grabbed a couple extra Bell glueless kits at $1.59 each from Fred Meyer.
Master the 1000 yard stare
coffeeMobil 1 USA
Re: Rubber cement tubes? [Re: MrQuackers] #5149006
07/01/19 08:20 PM
07/01/19 08:20 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
Originally Posted by MrQuackers
... Rummaged around and found some Park glueless patches I bought long ago. Usually patching a hole on the rim side is iffy but the tube is still holding air weeks later. I grabbed a couple extra Bell glueless kits at $1.59 each from Fred Meyer.
Are recent glueless patches better than the ones of the mid-90s when they first appeared? I and friends had bad experiences with them then. Typically, they would seem to work ok initially, but within a couple of days they failed.
Re: Rubber cement tubes? [Re: CR94] #5153066
07/06/19 12:58 PM
07/06/19 12:58 PM
Cold Lake, Alberta, Canada
Surestick Offline
Surestick  Offline
I think they're still considered a get-you-home solution, not a permanent one.
