Older fram ultra
by tblt44 - 10/19/19 08:42 PM
Best price on Colt 9MM pattern mags?
by GumbyJarvis - 10/19/19 08:20 PM
Using a trim router for cutting sheetrock
by JLawrence08648 - 10/19/19 08:09 PM
C&P of a Tough Guard w/50,000 miles to be posted soon
by MrQuackers - 10/19/19 08:04 PM
Chevy dealer, 7 free oil changes?
by Zacc - 10/19/19 07:34 PM
School me..1200 amp jumper
by Schmoe - 10/19/19 07:19 PM
YouTube Finish Test
by RayCJ - 10/19/19 07:09 PM
Overfilled, drained some, still too full?
by OCDriver - 10/19/19 06:16 PM
Wix made in Korea?
by JGmazda - 10/19/19 06:01 PM
Oil change interval question
by SkipCam - 10/19/19 05:49 PM
Remove Spark Plug Wires
by borgward - 10/19/19 04:53 PM
Pinion yoke loose, is the bearing ruined?
by Fsharp - 10/19/19 03:45 PM
Need tires for the mustang
by BeerCan - 10/19/19 03:24 PM
No sign of of oil sample at BStone :(
by 21Rouge - 10/19/19 02:45 PM
Carpet Shopping - Need Advice
by The Critic - 10/19/19 02:17 PM
Local Autozone clearance
by Soggydog - 10/19/19 02:05 PM
Two Fumoto valves
by otis24 - 10/19/19 01:17 PM
Going in the engine today!
by domer10 - 10/19/19 01:15 PM
GM 4WD rubbing/grinding after 4Lo
by HawkeyeScott - 10/19/19 12:52 PM
Choosing a new phone
by ram_man - 10/19/19 12:28 PM
Hallj49803, Tralever, Jhams, gmguy57, jamie24874
69612 Registered Users
81 registered members (bbhero, 4WD, 2003f7, AZjeff, aquariuscsm, AdditiveOCD, 8 invisible), 1,571 guests, and 25 spiders.
Topics296,195
Posts5,093,284
Members69,612
Most Online3,532
Jul 30th, 2019
Which grease? #5143734 06/25/19 12:43 PM
M
maverickfhs Offline OP
M
Maybe beating a dead horse, but which grease should be used for trailers tapered bearings?
I have these greases laying around 1-Coastal multipurpose wheel bearing 2-ST EP moly lithium 3- ST all purpose
My trailer bearing definitely needs to be greased by hand, so should I use either of the above or pick another one locally for greasing purposes?
Thank you for the advise thumbsup
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Which grease? [Re: maverickfhs] #5143758 06/25/19 01:11 PM
J
Jimzz Offline
J
Oh those 3 I would use the Coastal multipurpose wheel bearing if it says works with high speed wheel bearings (Gold label not red). The ST Moly I use in my grease gun for joints but not bearings. And ST all purpose is a very basic grease, I don't use it.
yup
Re: Which grease? [Re: Jimzz] #5143759 06/25/19 01:12 PM
M
M
Originally Posted by Jimzz
Oh those 3 I would use the Coastal multipurpose wheel bearing. The ST Moly I use in my grease gun for joints but not bearings. And ST all purpose is a very basic grease, I don't use it.
Thank you, would this be a good choice? https://www.walmart.com/ip/Super-Tech-Marine-Grease-14-oz-Tube/16928008
Re: Which grease? [Re: maverickfhs] #5143763 06/25/19 01:14 PM
J
Jimzz Offline
J
Yea if buying new grease that will work fine as well. Make sure to clean off all the old grease as not to mix them.
yup
Re: Which grease? [Re: maverickfhs] #5143830 06/25/19 02:56 PM
Donald Offline
If you are greasing trailer bearings by hand you want a small tub, not a tube for a grease gun. Unless you have a grease gun.
2015 Ford F250 w/Powerstroke
Re: Which grease? [Re: maverickfhs] #5143908 06/25/19 04:26 PM
W
Warstud Offline
W
You didn't mention the type of trailer.
Re: Which grease? [Re: maverickfhs] #5143925 06/25/19 04:55 PM
M
M
4x8, planning to use for motorcycle and other light stuff.
Re: Which grease? [Re: maverickfhs] #5143954 06/25/19 05:30 PM
MrMoody Offline
You might want to look into Bearing Buddies and a cheap grease gun if you are going to put any miles on the trailer.
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
"Fob" and "Noack" are not acronyms.
Re: Which grease? [Re: maverickfhs] #5144098 06/25/19 08:51 PM
M
M
Re: Which grease? [Re: maverickfhs] #5144099 06/25/19 08:52 PM
E
Elkins45 Offline
E
If you’re using a grease gun then you need to buy one of these cone-type bearing packers:
[Linked Image]
Any grease that is rated as a high temperature bearing grease will do just fine. The main thing is just to make sure there’s actually grease in the bearings and not just in the cavity.
Re: Which grease? [Re: maverickfhs] #5144136 06/25/19 10:10 PM
Dave9 Offline
You should look into the use of commas. Just saying, we shouldn't need prior knowledge to interpret something this simple.
If proper formatting isn't important, your post isn't important. There is no excuse for the breakdown of the english language. It will only get worse... Mark my words, text a teenager...
Re: Which grease? [Re: Dave9] #5144156 06/25/19 10:49 PM
E
Elkins45 Offline
E
Shouldn’t English be capitalized?
Re: Which grease? [Re: Elkins45] #5144305 06/26/19 06:29 AM
Donald Offline
People are judged on their "command" of the English language.
