Interesting read
by double vanos. 07/16/19 10:34 AM
Apollo 11
by Snagglefoot. 07/16/19 09:55 AM
Brake Pad Unboxing and Review
by krismoriah72. 07/16/19 09:40 AM
Limited Slip Additive
by Snagglefoot. 07/16/19 09:39 AM
Future of Chevy Bolt
by Snagglefoot. 07/16/19 09:04 AM
ST6607 on Honda CR-V 2.4L
by MontePrix28. 07/16/19 08:50 AM
2006 4runner Oil Leak After Synthetic
by Lucas_Jones. 07/16/19 08:46 AM
Quiet Small Engine
by Bailes1992. 07/16/19 08:26 AM
2005 C55 AMG oil recommendation
by TinyVoices. 07/16/19 08:26 AM
Uniroyal Tiger Paw Ice and Snow 3 - Reviews?
by Miller88. 07/16/19 08:09 AM
Wix XP oil filter deal
by Randy_R. 07/16/19 06:54 AM
How accurate is the octane rating at the pump ?
by Mr Nice. 07/16/19 06:33 AM
NAPA Presents: A Concert Behind Prison Walls
by GumbyJarvis. 07/15/19 11:35 PM
2019 Dodge Ram Warlock
by buster. 07/15/19 11:04 PM
2014 VW Jetta - transmission service
by gregk24. 07/15/19 10:09 PM
Lucas_Jones, cobb_cruiser, robinjeter, SpicySenpai, Weatherdriver77
68670 Registered Users
92 registered members (Alfred_B, 4WD, ad244, AdditiveOCD, alchargo, alteredtuning990, 10 invisible), 2,174 guests, and 27 spiders.
Topics291,939
Posts5,013,710
Members68,670
Most Online2,967
Mar 10th, 2019
Absorber drying chamois #5143600
06/25/19 10:36 AM
06/25/19 10:36 AM
Kern Co. California
Redright9 Offline OP
Kern Co. California
Hello,
Anyone use The Absorber synthetic chamois? I used to use them way back when and loved them, but I know times and fads change. I think a normal chamois is not recommended for drying really anymore because it holds tight to the panel of the car and drags (possible contaminates) across the car panels. The Absorber does pull water in and has in the past worked well for me but don't like that it has to be stored damp. I know there are a lot of fancy drying towels now too.. What would you use?
Thank you
Re: Absorber drying chamois [Re: Redright9] #5143603
06/25/19 10:40 AM
06/25/19 10:40 AM
Great Lakes
Quattro Pete Offline
Great Lakes
Ive been using Absorber for years. Still using it today.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Absorber drying chamois [Re: Redright9] #5143610
06/25/19 10:52 AM
06/25/19 10:52 AM
Atlanta,GA
BMWTurboDzl Offline
BMWTurboDzl  Offline
Atlanta,GA
Mine is over 15 yrs old and works fine. It works really well at blot drying.
435i
Re: Absorber drying chamois [Re: Redright9] #5143615
06/25/19 11:01 AM
06/25/19 11:01 AM
Ct., USA
Noey Offline
Noey  Offline
Ct., USA
Why not use microfiber?
"I don't know nothin' 'bout birthin' babies!"
Re: Absorber drying chamois [Re: Redright9] #5143636
06/25/19 11:19 AM
06/25/19 11:19 AM
PimTac Offline
PimTac  Offline
A good quality microfiber drying towel will outperform a chamois and with less effort and manipulation.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Absorber drying chamois [Re: Redright9] #5143662
06/25/19 11:46 AM
06/25/19 11:46 AM
D/FW Metroplex
The_Nuke Offline
The_Nuke  Offline
D/FW Metroplex
Originally Posted by Redright9
Hello,
Thank you
I have used the synthetic chamois, and continue to use one now, albeit only on surfaces that aren't prone to marring like glass.
The synthetic chamois will definitely dry a body panel quickly, and they can be stored in their original container while damp without issue. However, they should be washed periodically (but never dried!).
Their main drawback is that they have no way to keep dirt or other foreign matter from scratching the clear coat on a car's paint job if there is any dirt, pollen, etc. encountered while drying. If you have a white colored paint job, or if you just generally aren't concerned about creating swirls in the clear coat, the synthetic chamois is hard to beat as a drying utensil.
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 2.65 (215mm)
Re: Absorber drying chamois [Re: Redright9] #5143692
06/25/19 12:10 PM
06/25/19 12:10 PM
Minnesota
JoelB Offline
JoelB  Offline
Minnesota
I agree with Nuke, I would never use a chamois on a painted surface i cared about. Waffle weave microfiber is your friend here.
Mine: 2019 Chevy spark 1.4 Non-turbo
Mobil 1 0w20 AFE
ACDelco UPF64R
Wife's: 2018 Chevy spark 1.4 Non-turbo
Mobil 1 0w20 AFE
ACDelco UPF64R
Re: Absorber drying chamois [Re: The_Nuke] #5143708
06/25/19 12:24 PM
06/25/19 12:24 PM
Atlanta,GA
BMWTurboDzl Offline
BMWTurboDzl  Offline
Atlanta,GA
Hello,
Thank you
I disagree because it's HOW you dry which also matters. If you open the chamois up and lay it across the surface to "blot dry" the paint then marring will be as low as what you experience when using a MF towel. Products like the Absorber will hold a ton of water.
435i
Re: Absorber drying chamois [Re: Redright9] #5143802
06/25/19 02:15 PM
06/25/19 02:15 PM
5600 feet elevation, Arizona
double vanos Offline
I used a water sprite brand when I lived in Houston.
Highly recommend!
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Absorber drying chamois [Re: double vanos] #5143844
06/25/19 03:18 PM
06/25/19 03:18 PM
Kern Co. California
Kern Co. California
Highly recommend!
Is it like the absorber? Its a synthetic chamois I see, but does it need to be stored wet? does it dry out like a normal chamois? or is it more like a towel?
Re: Absorber drying chamois [Re: Redright9] #5143883
06/25/19 04:02 PM
06/25/19 04:02 PM
Olathe, KS
kkreit01 Offline
kkreit01  Offline
Olathe, KS
Absorber XL. I've used the Absorber for years. I use MF when doing rinseless washes in the winter. MF have to be washed, and break down over time.
2017 Jeep Grand Cherokee 4x4 3.6: 0w20 Rotella Gas Truck/Napa Platinum filter
2018 Ram 1500 CC Hemi: 5w20 Rotella Gas Truck/Napa Platinum filter
Re: Absorber drying chamois [Re: Redright9] #5143909
06/25/19 04:27 PM
06/25/19 04:27 PM
WY
sloinker Offline
sloinker  Offline
WY
Do microfiber towels magically repel foreign objects that may mar your cars surface? For everyday vehicles use the synthetic chamois on clean surfaces only and don't let it hit the ground. The best way to dry a car, magnitudes better than a chamois. I also prefer soft egyptian cotton for drying show car finishes. This is what Zaino Brothers recommended years back. Did an award winning job on my old '70 'cuda. Nothing quite like spending 12 hours washing/polishing/detailing a vehicle for car shows multiple times every summer. Sold that car and its expensive paint job and never looked back. Synthetic chamois and Nu-Finish are now it.
Re: Absorber drying chamois [Re: Redright9] #5143916
06/25/19 04:41 PM
06/25/19 04:41 PM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
Used them for decades, just bought another last year.
Absorber for the big water, microfiber to finish.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Absorber drying chamois [Re: Redright9] #5144130
06/25/19 09:58 PM
06/25/19 09:58 PM
Redright9 : I like the water sprite better than the absorber because it’s very soft and doesn’t “grab” the wet panel like the absorber does. It stores wet. Does an excellent job of absorbing water and is easy to wring out...
I still have mine (two of them actually), stored wet and ready to go. It’s strange to me that the water sprite can be stored wet for long periods of time and doesn’t smell or get moldy. The only other drying things I have are a waffle weave towel and leaf blower.
Re: Absorber drying chamois [Re: Quattro Pete] #5144175
06/25/19 11:49 PM
06/25/19 11:49 PM
Cajun Country, La.
BlueOvalFitter Offline
Cajun Country, La.
+1
"One Filter, One OCI!"
2007 F150, 4.2 V6
Havoline HM 5W20, MC FL-400S
"One Box, One OCI!"
