Interesting read
by double vanos. 07/16/19 10:34 AM
Apollo 11
by Snagglefoot. 07/16/19 09:55 AM
Brake Pad Unboxing and Review
by krismoriah72. 07/16/19 09:40 AM
Limited Slip Additive
by Snagglefoot. 07/16/19 09:39 AM
Future of Chevy Bolt
by Snagglefoot. 07/16/19 09:04 AM
ST6607 on Honda CR-V 2.4L
by MontePrix28. 07/16/19 08:50 AM
2006 4runner Oil Leak After Synthetic
by Lucas_Jones. 07/16/19 08:46 AM
Quiet Small Engine
by Bailes1992. 07/16/19 08:26 AM
2005 C55 AMG oil recommendation
by TinyVoices. 07/16/19 08:26 AM
Uniroyal Tiger Paw Ice and Snow 3 - Reviews?
by Miller88. 07/16/19 08:09 AM
Wix XP oil filter deal
by Randy_R. 07/16/19 06:54 AM
How accurate is the octane rating at the pump ?
by Mr Nice. 07/16/19 06:33 AM
NAPA Presents: A Concert Behind Prison Walls
by GumbyJarvis. 07/15/19 11:35 PM
2019 Dodge Ram Warlock
by buster. 07/15/19 11:04 PM
2014 VW Jetta - transmission service
by gregk24. 07/15/19 10:09 PM
Lucas_Jones, cobb_cruiser, robinjeter, SpicySenpai, Weatherdriver77
68670 Registered Users
87 registered members (4WD, 97K15004WD, 928, 1WildPig, 1978elcamino, 87sammy, 10 invisible), 2,121 guests, and 25 spiders.
Topics291,939
Posts5,013,704
Members68,670
Most Online2,967
Mar 10th, 2019
2017 Honda CR-V, dealer bulk 0w-20, 1600 mi OCI, 1.5l T #5143578
06/25/19 10:13 AM
06/25/19 10:13 AM
USA
OS4A Offline OP
OS4A  Offline OP
USA
Honda CR-V with 12,794 miles. Is a DD and driven very easy. Mostly short trips. 90/10 split local/highway.
Dealer performed first two oil changes. Last one in December 2018. Paperwork was vague and ambiguous so assume dealer bulk of unknown origin though 0w-20 was noted. Filter was Honda OEM. Filter was c/o and in decent shape with no noticeable particles to cause concern...link to c/o below.
https://www.bobistheoilguy.com/foru...-a02-filter-after-1700-miles#Post5134751
I changed oil and oil filter June 2019. Went with Magnatec 0w-20 and Bosch 3323 filter.
6 months in...fuel dilution at 1.8 according to BSL. MM displayed 50% oil life left. While numbers not terrible...not sure I would have wanted my friend to drive another 5-6 months before changing oil based on MM.
Also installed Fumoto valve. I will pull sample in 6 months for UOA. Time will tell. I realize low miles and gentle driving does not help the situation. That's not going to change sans the few times I plan to take it out on the highway.
Just setting the baseline.
Thoughts?
Thanks
Attached PDF document
OilReports.pdf (54 downloads)
2019 Subaru Impreza 5-door Castrol EP 0w-20 PBL14615 filter
2018 Honda Clarity PHEV Castrol Bio-Synthetic 0w-20 PBL14610 filter
2017 Toyota Rav4 Hybrid Castrol Bio-Synthetic 0w-20 PBL25608 filter
Re: 2017 Honda CR-V, dealer bulk 0w-20, 1600 mi OCI, 1.5l T [Re: OS4A] #5143599
06/25/19 10:35 AM
06/25/19 10:35 AM
ZFW
JustN89 Offline
JustN89  Offline
ZFW
I'm thinking you're experiencing much more fuel dilution than is shown on this report. I would try another lab on your next UOA and see what they say about the problem.
Re: 2017 Honda CR-V, dealer bulk 0w-20, 1600 mi OCI, 1.5l T [Re: OS4A] #5143767
06/25/19 01:28 PM
06/25/19 01:28 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
The way its driven Short tripper. What can you do but just drive and dump at 4K.
2019 VW Jetta S 6MT OCI#0 5033mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#7 52665mi-Castrol GTX Magnatec 5W20 + SOA Filter
Re: 2017 Honda CR-V, dealer bulk 0w-20, 1600 mi OCI, 1.5l T [Re: OS4A] #5144046
06/25/19 07:54 PM
06/25/19 07:54 PM
PA
jayjr1105 Offline
jayjr1105  Offline
PA
TBN down to 3 only after 1600 miles??
2013 Mazda 3 - Supertech FS 0w20
2005 Honda Odyssey - Supertech FS HM 5w20
Re: 2017 Honda CR-V, dealer bulk 0w-20, 1600 mi OCI, 1.5l T [Re: jayjr1105] #5144167
06/25/19 11:16 PM
06/25/19 11:16 PM
USA
OS4A Offline OP
OS4A  Offline OP
USA
jayjr1105
And to think the Honda MM was at 50%. We might of cringed if the OCI was completed based on MM.
Only reason I got involved with this CR-V is she had a front end fender bender a month ago and I offered to check fluids etc. The fumes from the dipstick were very noticeable.
Caught it in time so now we shorten OCI and run some more UOA's for documentation. Hopefully Honda comes up with a solution.
Re: 2017 Honda CR-V, dealer bulk 0w-20, 1600 mi OCI, 1.5l T [Re: OS4A] #5144298
06/26/19 06:14 AM
06/26/19 06:14 AM
Chattanooga, TN
Spector Offline
Spector  Offline
Chattanooga, TN
Are you in a cold winter area? Honda did extend warranty due to fuel dilution, sounds like you need to keep a watch on that dilution in the future.
Re: 2017 Honda CR-V, dealer bulk 0w-20, 1600 mi OCI, 1.5l T [Re: jayjr1105] #5144452
06/26/19 09:29 AM
06/26/19 09:29 AM
N.H, U.S.A.
N.H, U.S.A.
That's about right for anything. More syn base that is less prone to oxidise = less overbase detergent required. The TBN drops fast in severe service then hold the 3 > 2 line for the duration.
Cheap Diesel conventional will have a silly-high TBN - because the low group, oxidation prone, base oils need it
Re: 2017 Honda CR-V, dealer bulk 0w-20, 1600 mi OCI, 1.5l T [Re: Spector] #5144474
06/26/19 09:56 AM
06/26/19 09:56 AM
USA
OS4A Offline OP
OS4A  Offline OP
USA
Spector
Not really, mid-Atlantic states with only a few cold weeks a year (cold defined as below 32 degrees).
This CR-V belongs to a 68 year old woman and in December the dealership told her "everything is fine" after the oil change. Neither the dealership nor Honda has bothered to inform this person of the potential issues with this car. Inexcusable if you ask me.
I'm starting the documentation chain and will decide on course of action after next UOA.
Re: 2017 Honda CR-V, dealer bulk 0w-20, 1600 mi OCI, 1.5l T [Re: OS4A] #5144884
06/26/19 04:51 PM
06/26/19 04:51 PM
Danh Offline
Danh  Offline
Based on what you’ll find on CRV forums, barring an actual mechanical failure or CEL, American Honda will do absolutely nothing. Crankcase level increases by an inch? Normal. UOA with 10% fuel dilution? Normal. High UOA wear metals? Normal.
Hate to be cynical but these engines will almost surely survive the 5/60 warranty and that seems to be Honda’s concern. Wouldn’t be at all surprised to see a major engine redesign in the next couple years, though.
Re: 2017 Honda CR-V, dealer bulk 0w-20, 1600 mi OCI, 1.5l T [Re: Danh] #5144921
06/26/19 05:31 PM
06/26/19 05:31 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Especially if they want to see their high sales continue. I wouldn't touch one right now. They along with lots of other car companies are expecting you to swallow the junk they have produced.
2004 Corolla 134004
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 75175
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 2017 Honda CR-V, dealer bulk 0w-20, 1600 mi OCI, 1.5l T [Re: JohnnyJohnson] #5145193
06/26/19 11:12 PM
06/26/19 11:12 PM
USA
OS4A Offline OP
OS4A  Offline OP
USA
Danh
I hear ya. Best I can do for my friend is document and bring it to Honda's attention so it's on record.
Then decide on OCI to keep engine proper until/if Honda USA ever does the right thing or is forced to do the right thing.
I do not trust the dealership to do her right so I told her I'd handle what I can.
Re: 2017 Honda CR-V, dealer bulk 0w-20, 1600 mi OCI, 1.5l T [Re: JohnnyJohnson] #5145195
06/26/19 11:16 PM
06/26/19 11:16 PM
USA
OS4A Offline OP
OS4A  Offline OP
USA
JohnnyJohnson
It's a shame companies can ignore issues like Honda has
with the 1.5l DI Turbo. It's universally known this engine is bogus but yet no admission.
Gotta love it.
Re: 2017 Honda CR-V, dealer bulk 0w-20, 1600 mi OCI, 1.5l T [Re: OS4A] #5145381
06/27/19 08:47 AM
06/27/19 08:47 AM
N.H, U.S.A.
N.H, U.S.A.
Honda service ignored my issues with my New Fit about as well as the worst GM dealers have smile.
I stay away. I dont like their cars or motorcycles anyhow. - though I haven't driven the new CRV - don't plant to either .
