API 1509 Updated with New GF-6B Shield
by Solarent. 07/17/19 07:27 AM
Car Vac Recommendations
by klt1986. 07/17/19 07:05 AM
ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
Aother MEGA score+Free Mobil 1 oil change
by GMguy84. 07/17/19 12:39 AM
I think I need therapy...
by tony1679. 07/16/19 11:53 PM
Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
My new rig - 1987 Ford Econoline 27' Glendale RV
by caprice_2nv. 07/16/19 07:44 PM
Air Compressor OCI?
by Vern_in_IL. 07/16/19 07:35 PM
Looking for an SUV
by dgunay. 07/16/19 07:29 PM
Castrol GTX Magnatec 5w30
by Envoyguy. 07/16/19 07:21 PM
2019 Subaru Dual X-Mode
by buster. 07/16/19 06:36 PM
guru2019, MBhuntington, captainfloss, Lyndol, Belczek
68682 Registered Users
105 registered members (AlienBug, AandPDan, 69GTX, aquariuscsm, Alfred_B, 2010Civic, 10 invisible), 1,874 guests, and 22 spiders.
Topics291,979
Posts5,014,501
Members68,682
Most Online2,967
Mar 10th, 2019
Anyone Using DualLiner Pickup Truck Bed Liner? #5143500
06/25/19 08:29 AM
06/25/19 08:29 AM
Midwest USA
LoneRanger Offline OP
Midwest USA
I am thinking about Dual Liner as the choice for my F150. I don't like the factory paint being sanded off the bed on my brand new truck for a spray-on liner prep, so spray-ons are out. Drop-ins rattle on the highway and may interfere with water drainage between the liner and the bed. The DualLiner claims to not interfere with water drainage between the bottom mat and truck bed.
I haven't been able to determine, however, if the side panels rattle going down the road so I thought I'd see if anyone here has one and their experience with it.
2019 Ford F-150 ................................(Factory fill)
2019 GMC Terrain .............................(Factory fill)
2016 Moto Guzzi Stelvio <for sale>...(eni 10W60)
Re: Anyone Using DualLiner Pickup Truck Bed Liner? [Re: LoneRanger] #5143504
06/25/19 08:33 AM
06/25/19 08:33 AM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
Never used one but not a fan of rubber mats. They work well at first but then a little dirt/water get under neath them and they start moving around.
And you do not have to remove paint to do a spray on bed-liner. Just scuff, clean, and then install then spray/roll it on.
yup
Re: Anyone Using DualLiner Pickup Truck Bed Liner? [Re: LoneRanger] #5143514
06/25/19 08:45 AM
06/25/19 08:45 AM
Midwest USA
Midwest USA
Dual Liner system apparently secures the rubber mat to the bottom edge of the side panels and front panel guard in order to keep the mat from moving. Mat supposedly has rubber bumps or studs all over underside to allow any water under the mat to travel to factory drain ports in bed. I'm just curious if the side panels rattle going down the road. Interested in real world user experience, not manufacturer propaganda.
Re: Anyone Using DualLiner Pickup Truck Bed Liner? [Re: LoneRanger] #5143646
06/25/19 11:32 AM
06/25/19 11:32 AM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
That does look pretty cool but wow they are expensive.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Anyone Using DualLiner Pickup Truck Bed Liner? [Re: LoneRanger] #5143787
06/25/19 02:01 PM
06/25/19 02:01 PM
PV Az @ 5000'
AZjeff Offline
AZjeff  Offline
PV Az @ 5000'
Someone in your last thread has one in his truck.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Anyone Using DualLiner Pickup Truck Bed Liner? [Re: LoneRanger] #5143819
06/25/19 02:38 PM
06/25/19 02:38 PM
Lakeville, MN
MNgopher Offline
MNgopher  Offline
Lakeville, MN
I was the poster with one in the other thread.
I've had mine for 3+ years now in my F150 with little to complain about.
If I am remembering my install instructions, the front panel snaps in and the side ones are bolted in in 4 places - in my case at the tie downs and at the box link cleats (which as I understand are not standard on these later trucks). The only issue I have had is one side panel slightly bulges out from the metal leaving a small gap visible at the tailgate. Two sided tape (supplied with the kit) is used to minimize it, but it still happens. I have not had any issues with any flapping of the panels, but I also have a truxedo lo-pro cover. I do run open enough that I would assume I would notice flapping though. I do recall some folks having to trim panels slightly to fit correctly - I did not.
The bad mat "locks" into a groove at the bottom of the side panels (loosely). The mat has nubs on the bottom of it, and I pull mine out at least yearly to clean out underneath it. I have zero scratching or scuffing of the bed to date, and I have hauled sand, brush, and other abrasive things in the bed regularly.
One thing to note - these beds drain more than any other truck I have ever had. A drop in liner will keep it water tight. The spray ins may or may not. This definitely does not (seam between the rubber and side panels). On the good side, it means it means any water that gets in drains easily. The bad side is water can also get in that way.
I'd order another one. It does what I wanted - stuff doesn't slide around and the bed looks great.
Re: Anyone Using DualLiner Pickup Truck Bed Liner? [Re: LoneRanger] #5144377
06/26/19 08:12 AM
06/26/19 08:12 AM
MI
doitmyself Offline
doitmyself  Offline
MI
Thanks MNgopher. In the real world with a real work truck, employees are not going to always hose out the truck bed each time after hauling "dirty" material (sand, topsoil, mulch, gravel, etc.). What happens when the leftover dirt debris is exposed to heavy rains? Does this grime get washed into the seam between rubber and plastic and make it's way underneath the liner where it acts as sandpaper between the liner and bed?
We currently use drop in liners at my workplace. Abrasion does occur between the liner and bed paint. But, the bed never deteriorates faster than the rest of the truck from corrosion. The liner simple prevents dents and dings (tossed cinder blocks, shovel scrapes, etc.) when the truck is used as a truck. A liner is nice when shoveling out mulch, etc..
