Older fram ultra
by tblt44 - 10/19/19 08:42 PM
Best price on Colt 9MM pattern mags?
by GumbyJarvis - 10/19/19 08:20 PM
Using a trim router for cutting sheetrock
by JLawrence08648 - 10/19/19 08:09 PM
C&P of a Tough Guard w/50,000 miles to be posted soon
by MrQuackers - 10/19/19 08:04 PM
Chevy dealer, 7 free oil changes?
by Zacc - 10/19/19 07:34 PM
School me..1200 amp jumper
by Schmoe - 10/19/19 07:19 PM
YouTube Finish Test
by RayCJ - 10/19/19 07:09 PM
Overfilled, drained some, still too full?
by OCDriver - 10/19/19 06:16 PM
Wix made in Korea?
by JGmazda - 10/19/19 06:01 PM
Oil change interval question
by SkipCam - 10/19/19 05:49 PM
Remove Spark Plug Wires
by borgward - 10/19/19 04:53 PM
Pinion yoke loose, is the bearing ruined?
by Fsharp - 10/19/19 03:45 PM
Need tires for the mustang
by BeerCan - 10/19/19 03:24 PM
No sign of of oil sample at BStone :(
by 21Rouge - 10/19/19 02:45 PM
Carpet Shopping - Need Advice
by The Critic - 10/19/19 02:17 PM
Local Autozone clearance
by Soggydog - 10/19/19 02:05 PM
Two Fumoto valves
by otis24 - 10/19/19 01:17 PM
Going in the engine today!
by domer10 - 10/19/19 01:15 PM
GM 4WD rubbing/grinding after 4Lo
by HawkeyeScott - 10/19/19 12:52 PM
Choosing a new phone
by ram_man - 10/19/19 12:28 PM
Hallj49803, Tralever, Jhams, gmguy57, jamie24874
69612 Registered Users
80 registered members (4WD, bbhero, aquariuscsm, AdditiveOCD, 2015_PSD, ammolab, 7 invisible), 1,633 guests, and 23 spiders.
Topics296,195
Posts5,093,281
Members69,612
Most Online3,532
Jul 30th, 2019
Synchromesh: Valvoline Vs. Pennzoil #5143453 06/25/19 07:27 AM
I
IndyFan Offline OP
I
I'm changing the old Jeep's Synchromesh manual transmission fluid today. It is an NSG370 transmission.
Advance Auto has Pennzoil Synchromesh for 9 bucks a quart. O'Reilly has Valvoline for 10 bucks a quart.
What does the hive say about which might be better gear lube? The price is close enough not to be a factor. Are they essentially the same? I'm guessing Pennzoil was probably the original Jeep factory fill, at least in more recent years, due to FCA's close relationship with SOPUS.
One other quick question...What is the recommended shelf life of Synchromesh? I may have a bottle of Pennzoil stashed somewhere that's probably 5 years old. (If I do, and the shelf life is ok, that will decide it in favor of Pennzoil.)
18 Jeep JLUR Wrangler 3.6 22k
15 Ford Transit 125k, Reman 3.5 @85k
17 Jeep Renegade 2.4 21k
08 Jeep Wrangler 3.8 134k
04 Jeep Grand Cherokee 4.7 105k
99 Mercedes E430 Sport 92k
Re: Synchromesh: Valvoline Vs. Pennzoil [Re: IndyFan] #5143462 06/25/19 07:40 AM
Chris142 Online Content
Online Content
The pz one makes my jeep shift notchy. I have the valvoline fluid in it now and its fine. I prefer the Royal purple fluid over both of those though. Last time I changed it napa had the valvoline on clearance for $3/qt and since I'm cheap thats why I got it.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Synchromesh: Valvoline Vs. Pennzoil [Re: IndyFan] #5143505 06/25/19 08:34 AM
MolaKule Offline
Global Moderator
Global Moderator
Any of these dedicated MTL's should work:
NOTE: This list is only a “suggested” list of MTFs. It is not an endorsement of any one fluid, nor is it implied that any one fluid will cure problems in MTs that have design problems or those that have excessive wear.
Mopar Type MS-9417 MTL 9.0 cSt
Valvoline MTF Part Number 811095 9.2 cSt
Pennzoil Synchromesh 9.3 cSt
RAVENOL PSA 9.5 cSt
RAVENOL SSG 9.5 cSt
Redline MTL 75W80
Amsoil MTF (9.7 cSt)
GM Synchromesh’s
Volvo MTF 645
Fuchs TITAN SINTOFLUID SAE 75W-80 synthetic MTF
Lodexol (Morris Lubricants) MTF
Motylgear 75W-80
Shelf Life is about 10 years for MTL oils. Suggest you warm it up and shake it well before installation if it has been on the shelf for 2 years or more.
"You ... sadist," said Mr Cummings, "you try to make people think." Ezra Pound (1885-1972)
Re: Synchromesh: Valvoline Vs. Pennzoil [Re: IndyFan] #5143785 06/25/19 02:00 PM
DGXR Offline
If they both meed the required spec, I would default to Valvoline simply due to personal preference.
Currently I run Amsoil synchromesh in my ZF S6-40 with excellent results.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Synchromesh: Valvoline Vs. Pennzoil [Re: IndyFan] #5143929 06/25/19 04:56 PM
I
IndyFan Offline OP
I
I may try Valvoline. I ran Pennzoil awhile back and felt the Mopar was smoother and quieter. It is just too expensive. If I pay more, I'd be inclined towards Amsoil. I can't buy Amsoil off the shelf, though, and I want to change it tonight or tomorrow.
Any more experience out there with RP?
Re: Synchromesh: Valvoline Vs. Pennzoil [Re: IndyFan] #5143983 06/25/19 06:06 PM
MolaKule Offline
Global Moderator
Global Moderator
Originally Posted by IndyFan
...Any more experience out there with RP?...
RP what?
Re: Synchromesh: Valvoline Vs. Pennzoil [Re: MolaKule] #5143996 06/25/19 06:14 PM
R
Red91 Offline
R
Royal purple.
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Synchromesh: Valvoline Vs. Pennzoil [Re: Red91] #5144012 06/25/19 06:48 PM
MolaKule Offline
Global Moderator
Global Moderator
Originally Posted by Red91
Royal purple.
Royal Purple does NOT have an MTF dedicated lubricant in the 10 cSt range, if that is what you're referring to.
They have only the Synchromax which has the viscosity of Dex/Merc ATF (7.5 cSt).
Re: Synchromesh: Valvoline Vs. Pennzoil [Re: MolaKule] #5144127 06/25/19 09:51 PM
I
IndyFan Offline OP
I
Royal purple.
Ok, thanks. I'm going to pick up a couple quarts of Valvoline at Napa or O'Reilly and get it done.
Thanks for all the info, everyone!
Re: Synchromesh: Valvoline Vs. Pennzoil [Re: MolaKule] #5144554 06/26/19 11:34 AM
L
Linctex Offline
L
This information really needs to be in a "quick access reference sticky" somewhere....
RAVENOL PSA 9.5 cSt
RAVENOL SSG 9.5 cSt
Redline MTL 75W80
GM Synchromesh’s
Volvo MTF 645
Motylgear 75W-80
Re: Synchromesh: Valvoline Vs. Pennzoil [Re: IndyFan] #5144805 06/26/19 03:19 PM
MolaKule Offline
Global Moderator
Global Moderator
An Updated article is posted here:
Manual Transmission Fluids
Re: Synchromesh: Valvoline Vs. Pennzoil [Re: MolaKule] #5144878 06/26/19 04:40 PM
I
IndyFan Offline OP
I
Wow, great stuff! Thanks for sharing. I went with Valvoline. Everything feels smooth. Thanks again for the help and the education to all here. This site is such an incredible resource because of your generosity!
Re: Synchromesh: Valvoline Vs. Pennzoil [Re: IndyFan] #5144881 06/26/19 04:43 PM
I
IndyFan Offline OP
I
Sounds like they are well prepared for massive rebates and incentives. The guy or gal that spends 80 grand on it will thing he/she got a steal.
