Older fram ultra
by tblt44 - 10/19/19 08:42 PM
Best price on Colt 9MM pattern mags?
by GumbyJarvis - 10/19/19 08:20 PM
Using a trim router for cutting sheetrock
by JLawrence08648 - 10/19/19 08:09 PM
C&P of a Tough Guard w/50,000 miles to be posted soon
by MrQuackers - 10/19/19 08:04 PM
Chevy dealer, 7 free oil changes?
by Zacc - 10/19/19 07:34 PM
School me..1200 amp jumper
by Schmoe - 10/19/19 07:19 PM
YouTube Finish Test
by RayCJ - 10/19/19 07:09 PM
Overfilled, drained some, still too full?
by OCDriver - 10/19/19 06:16 PM
Wix made in Korea?
by JGmazda - 10/19/19 06:01 PM
Oil change interval question
by SkipCam - 10/19/19 05:49 PM
Remove Spark Plug Wires
by borgward - 10/19/19 04:53 PM
Pinion yoke loose, is the bearing ruined?
by Fsharp - 10/19/19 03:45 PM
Need tires for the mustang
by BeerCan - 10/19/19 03:24 PM
No sign of of oil sample at BStone :(
by 21Rouge - 10/19/19 02:45 PM
Carpet Shopping - Need Advice
by The Critic - 10/19/19 02:17 PM
Local Autozone clearance
by Soggydog - 10/19/19 02:05 PM
Two Fumoto valves
by otis24 - 10/19/19 01:17 PM
Going in the engine today!
by domer10 - 10/19/19 01:15 PM
GM 4WD rubbing/grinding after 4Lo
by HawkeyeScott - 10/19/19 12:52 PM
Choosing a new phone
by ram_man - 10/19/19 12:28 PM
Hallj49803, Tralever, Jhams, gmguy57, jamie24874
69612 Registered Users
98 registered members (4WD, Aichiguy, Astro14, AITG, Ag76, 8 invisible), 1,763 guests, and 22 spiders.
Topics296,195
Posts5,093,247
Members69,612
Most Online3,532
Jul 30th, 2019
Sprinter Gen 2 oil #5143420 06/25/19 06:39 AM
A
Ammofirst Offline OP
A
A friend recently purchased a 2015 Mercedes Sprinter class B motorhome. He tells me it’s a V6 diesel that requires the 229.51 Mercedes spec. Is Pennzoil platinum 5W-30 euro L up to the challenge of a 10K oci ? I know it’s a mid saps GTL based synthetic and it carries the 229.51 spec but I’ve never considered this a long drain oil. It holds 13.2 quarts of oil so maybe that makes up the difference I don’t know. What would be your suggestion for a 10K oci ? Also what’s a good oil filter for the same oci ? Thanks.
Re: Sprinter Gen 2 oil [Re: Ammofirst] #5143459 06/25/19 07:31 AM
Danno Offline
229.51 is superseded by 229.52.
16K OCI should be good for that engine and year as per MB. I ran a fleet of 400 Sprinters with the 3.0L and that was the OCI.
10K is a piece of cake, or annually,.
Use the OE MB filter. Not cheap but that is one item I would say go OE on.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Sprinter Gen 2 oil [Re: Ammofirst] #5143465 06/25/19 07:43 AM
F
Fraser434 Offline
F
Initially in the Ram/Jeep EcoDiesel world the manual specifically read, Euro L 5W-30, saw alot of data on this oil, not particularly a fan of it. Consistently saw Iron numbers close to 100ppm. Saw better numbers from Mobil1 ESP 5W-30.
If you want an oil with more protection that slightly bends the rules, Mobil Delvac 1 LE 5W-30. Harder to find, it meets CK-4 and ACEA E6 which causes the manufacture to lower the SAPS and limit Zinc/Phos to 800ppm. From Lubrizol -
Quote
ACEA E6-16 oils are low SAPS Ultra High Performance Diesel (UHPD) lubricants designed for use in severe duty, long drain applications.
ACEA recommends their use in vehicles fitted with aftertreatment systems for the reduction of particulate matter (DPFs) and oxides of nitrogen (EGR and/or SCR), in combination with low sulphur diesel fuel.
Re: Sprinter Gen 2 oil [Re: Ammofirst] #5143477 06/25/19 08:02 AM
A
A
How do the valvoline mst oils measure up ? I think NAPA puts them on sale occasionally
Re: Sprinter Gen 2 oil [Re: Ammofirst] #5147510 06/29/19 11:15 PM
L
loneryder Offline
L
That chassis is at or near load capacity. It should be viewed as severe service and not run on 10k oci's. The valvoline 5-40 mst is a good oil that can be found on sale at napa. It meets the 229.51 spec
Re: Sprinter Gen 2 oil [Re: Ammofirst] #5147559 06/30/19 01:37 AM
E
edyvw Offline
E
I used it in BMW X5 35d. Excellent oil.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: Sprinter Gen 2 oil [Re: Ammofirst] #5148525 07/01/19 11:02 AM
U
UncleDave Offline
U
Valvoline has 2 compliant oils.
Valvoline SynPower B-Tec C3 5W-30 x The Valvoline Company, LEXINGTON, KY/USA
Valvoline SynPower MST C3 5W-30 x The Valvoline Company, LEXINGTON, KY/USA
Never once seen these on a shelf anywhere in Southern California
Mobil 1 ESP is compliant which is also hard to get
Ravenol has a formulation you can get.
The list Mercedes keeps is a joke - you'd think by looking at the list one could locate this rated oil everywhere- it is very hard to find 229.52 on a shelf where I live.
https://bevo.mercedes-benz.com/bevolisten/229.52_en.html
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: Sprinter Gen 2 oil [Re: Ammofirst] #5164862 07/19/19 02:53 AM
A
A
Thanks for the feedback. I Will send this thread to the owner and let him look it over
Re: Sprinter Gen 2 oil [Re: Ammofirst] #5164892 07/19/19 05:23 AM
demarpaint Offline
Mobil 1 ESP will work fine. Ebay and AMZN has it at prices much better than most parts stores.
God Bless Our Troops
