Flywheel pic
by Chris142 - 02/21/20 07:49 PM
Rislone Hyper Fuel
by rrretiree7 - 02/21/20 07:40 PM
Bosch Brakes
by ChiTDI - 02/21/20 07:16 PM
Which 15W40 for an Onan generator?
by atikovi - 02/21/20 06:39 PM
Valvoline Advanced 5W40 MST
by BurntMusic - 02/21/20 06:04 PM
2014 F250, 6.7L 13,000 OCI Amsoil AME 15w40
by claluja - 02/21/20 05:43 PM
What Are These On My Caliper Pistons?
by Fitz98 - 02/21/20 05:37 PM
Gun carry insurance
by Colt - 02/21/20 05:25 PM
drywall crack. how do i fix it?
by WhyMe - 02/21/20 02:55 PM
Yokohama AVID Ascend GT
by Bottom_Feeder - 02/21/20 02:53 PM
Getting my Chevy 4.3 to 300k
by CharlotteB - 02/21/20 02:16 PM
Updated PDS for Valvoline ME
by buster - 02/21/20 01:56 PM
Havoline ProDS Full Synthetic
by Fordiesel69 - 02/21/20 01:32 PM
Correct oil for flat tappets
by Gokhan - 02/21/20 11:55 AM
Laser tachometer?
by Elkins45 - 02/21/20 11:13 AM
Best beginner press?
by MVFarms - 02/21/20 10:20 AM
Help me pick a generator size
by dlundblad - 02/21/20 09:56 AM
...musical 'flat-tappet' oils
by Mad_Max_Sam - 02/21/20 09:44 AM
KIA
by WyrTwister - 02/21/20 09:42 AM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
118 registered members (askani79705, Astro14, alphadog, 03s, Astro_Guy, 8 invisible), 2,188 guests, and 24 spiders.
Topics301,757
Posts5,202,197
Members70,766
Son's van is giving multiple warning lights that come and go - vehicle dies #5142929 06/24/19 02:28 PM
69GTX Offline OP
Trying to give some ideas to my son. First the ABS warning light came on. Then the check engine and engine oil warning lights. Then they went away and everything was fine for a few
miles. Then they came back again in similar sequence. These lights are flashing, not steady. He stopped the vehicle...then it wouldn't start or even engage the starter. Just had the head lights available. A short while later he tried again and it started....warning lights were gone. This sequence repeated again. Warning Lights Flashing. Car won't start again. Didn't say if he turned it off or the car stalled out.
Sounds like an intermittent ground on the electrical system. Maybe corrosion in the battery lines/grounding. He did say one of the door panels was just removed for some work. Maybe that left an exposed wire or a strained wire that's grounding the electrical system at times....dropping the voltage and/or current.
comments? It's a 2002 Dodge Caravan.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Son's work van is giving multiple warning lights that come and go - vehicle dies [Re: 69GTX] #5142933 06/24/19 02:32 PM
M
mk378 Online Content
Online Content
M
If the starter doesn't turn (it may click, but it doesn't make that "car trying to start" sound) when you turn the key, check for bad connections at the battery.
Re: Son's work van is giving multiple warning lights that come and go - vehicle dies [Re: 69GTX] #5142954 06/24/19 02:58 PM
69GTX Offline OP
I told him to check anything going to and from battery to alternator and/or grounding...especially corrosion or bare wires. He said every connection was sealed or taped. He wandered into one of the auto retail places and they all jumped on alternator failing. Which makes sense since they'd like to sell him a new alternator. Currently the car is driving around fine. I told him not to turn it off until he gets where he's going. It could also be a heat related issue stressing a weakened or aged electrical system as it's 100 deg F today where he's at.
The two times he turned the car off - it wouldn't restart right away. He had to wait a bit. Heat? And in each case he heard nothing from the starter engaging the flywheel and cranking the engine.
1969 Ply GTX/RRs
Re: Son's work van is giving multiple warning lights that come and go - vehicle dies [Re: 69GTX] #5142959 06/24/19 03:06 PM
DerbyDave Offline
Check and double check all the grounds. I had a loose negative cable on my battery a while back, the dash lights would randomly light up then the car would die. Battery and alternator tested fine. I tightened the negative cable and it has never done it again. Your situation sounds suspiciously similar.
2005 Buick Terraza
2007 Honda Ridgeline
1986 Suzuki Cavalcade
1986 Suzuki Intruder
Re: Son's work van is giving multiple warning lights that come and go - vehicle dies [Re: 69GTX] #5142961 06/24/19 03:08 PM
T
tcp71 Offline
T
Battery issues can cause all kinds of crazy sensor issues. My bet is a plate in the battery is separating when hot. As it cools, connections are re-established and the van starts.If you can change the battery with another and try it, it might save the cost of buying a new one to confirm.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: NAPA 5w30 syn. (varies)
Re: Son's work van is giving multiple warning lights that come and go - vehicle dies [Re: 69GTX] #5142969 06/24/19 03:22 PM
69GTX Offline OP
Actually, he told me they had just put a new battery in the van. But checking all the connections makes sense. He did verify all the top connections were clean and tight.
1969 Ply GTX/RRs
Re: Son's work van is giving multiple warning lights that come and go - vehicle dies [Re: 69GTX] #5142977 06/24/19 03:33 PM
M
Online Content
M
New parts aren't necessarily good.
When it won't start you need to use a voltmeter to see where the voltage is being lost.
Re: Son's work van is giving multiple warning lights that come and go - vehicle dies [Re: 69GTX] #5142978 06/24/19 03:34 PM
Chris Meutsch Offline
Check chassis grounds on the negative side. My car was flashing dash lights, alt and battery checked out fine. Found a broken cable, fixed it, all is well.
2005 Honda CR-V EX, 280k
Re: Son's work van is giving multiple warning lights that come and go - vehicle dies [Re: 69GTX] #5143186 06/24/19 08:00 PM
M
maverickfhs Offline
M
Ground and probably alternator test. Good luck.
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
Re: Son's work van is giving multiple warning lights that come and go - vehicle dies [Re: 69GTX] #5143219 06/24/19 08:43 PM
B
BozoDeClowne Offline
B
Had a similar problem with an 04 with the 3.8L. Positive battery cable looked fine at the connector, but was terribly corroded at the crimp. So much so that about half of the strands had snapped. Same sort of thing - random lights and then stopping dead while driving. Every couple of years I'd have to cut a bit off the ends and install one of those "repair" cable jumpers as the cable would be too short to reach the top of the battery.
[Linked Image]
Down like a clown, Charlie Brown...
Re: Son's work van is giving multiple warning lights that come and go - vehicle dies [Re: mk378] #5143223 06/24/19 08:48 PM
B
bbhero Offline
B
Great point ^^^^^^^^
I had a hoopty Doo brand new alternator fail within literally 10 miles... Car died on the way to my lady's family house.
Nissan Altima 3.5 Coupe
Cam2 SuperproMax 5w30 Carquest r84356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Son's work van is giving multiple warning lights that come and go - vehicle dies [Re: 69GTX] #5143267 06/24/19 09:51 PM
69GTX Offline OP
Good inputs. Thanks all. Will have him closely check all those ground and battery points.
1969 Ply GTX/RRs
Re: Son's work van is giving multiple warning lights that come and go - vehicle dies [Re: 69GTX] #5143451 06/25/19 06:25 AM
W
wag123 Offline
W
Just because the battery is "new" doesn't mean that it isn't defective. I have seen this sort of thing before. Don't dismiss this possibility.
