API 1509 Updated with New GF-6B Shield
by Solarent. 07/17/19 07:27 AM
Car Vac Recommendations
by klt1986. 07/17/19 07:05 AM
ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
Aother MEGA score+Free Mobil 1 oil change
by GMguy84. 07/17/19 12:39 AM
I think I need therapy...
by tony1679. 07/16/19 11:53 PM
Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
My new rig - 1987 Ford Econoline 27' Glendale RV
by caprice_2nv. 07/16/19 07:44 PM
Air Compressor OCI?
by Vern_in_IL. 07/16/19 07:35 PM
Looking for an SUV
by dgunay. 07/16/19 07:29 PM
Castrol GTX Magnatec 5w30
by Envoyguy. 07/16/19 07:21 PM
2019 Subaru Dual X-Mode
by buster. 07/16/19 06:36 PM
guru2019, MBhuntington, captainfloss, Lyndol, Belczek
68682 Registered Users
108 registered members (4WD, Alfred_B, 69GTX, 87sammy, AandPDan, 2010Civic, 9 invisible), 1,948 guests, and 23 spiders.
Topics291,979
Posts5,014,505
Members68,682
Most Online2,967
Mar 10th, 2019
2008 Yamaha F350 91 Hrs OCI #5143164
06/24/19 08:39 PM
06/24/19 08:39 PM
Maryland, USA
nicklx Offline OP
nicklx  Offline OP
Maryland, USA
Hey folks,
Decided to try a different oil to combat the low viscosity that I was having with the Yamalube 10w-30. Went with West Marine 4 stroke 10w-40 this time. Unfortunately, I don't think the large amount of idling we do helps these motors, but its the nature of our work. Never noticed a significant rise in the oil level of the port motor though. I did skip doing an analysis on the last oil change as it was a short interval and went ahead and did this latest one which was closer to 100 hour interval.
[Linked Image]
[Linked Image]
01 VW Jetta GLS 1.8T
98 BMW M3
04 Passat 1.8t (Currently Rebuilding)
Re: 2008 Yamaha F350 91 Hrs OCI [Re: nicklx] #5143298
06/24/19 11:33 PM
06/24/19 11:33 PM
Maryland USA
rubberchicken Offline
Maryland USA
I am not impressed with any West Marine 4 stroke oil. If it were mine, I would probably use Amsoil 10w40. Do you do a lot of trolling ? The Fuel and flashpoint are a bit off- perhaps a checkup of your ignition is in order. Maybe a badly gapped plug, or a coil that is marginal.
Re: 2008 Yamaha F350 91 Hrs OCI [Re: nicklx] #5143677
06/25/19 12:02 PM
06/25/19 12:02 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Marine engines get hit from both sides with FD issues. High load and rpm does it. Idling does it. Marine engines spend most of their time either idling or at higher load and rpm.
At least this oil hung on pretty good, and wear metals got a tick better.
