Sorry about poor display.. This was second oil change since buying used car in order to make sure motor was cleaned well and no unusual metals were present. First short change was not tested. Will change oil/filter at 5000 mi next time and if it still looks good will extend to 7K. PP 5-20 and Kia filter were used again this time.
WIX oil analysis
31500 miles on vehicle
3000 miles ON OIL & Kia Filter
Pennzoil Platinum Full Syn
SAE 5W20
Metals (ppm)
Iron (Fe) 6
Chromium (Cr) Lead (Pb) 3
Copper (Cu) Tin (Sn) Aluminium (Al) 2
Nickel (Ni) Silver (Ag) Titanium (Ti) 6
Vanadium (V)
Contaminants (ppm)
Silicon (Si) 12
Sodium (Na) 10
Potassium (K)
Additives (ppm)
Magnesium (Mg) 636
Calcium (Ca) 936
Barium (Ba) Phosphorus (P) 562
Zinc (Zn) 679
Molybdenum (Mo) 71
Boron (B) 124
Contaminants
Water (%) Coolant No
Physical Tests
Viscosity (cSt 100C) 9.0
Physical / Chemical
Base Number (mgKOH/g) 3.9
Engine wear levels appear satisfactory for first sample.
Silicon level (dirt/sealant material) satisfactory. Water
content acceptable. Viscosity within specified operating
range. Action: Resample at next recommended
interval to monitor and establish wear trend.
WIX oil analysis
SAE 5W20
Metals (ppm)
Iron (Fe) 6
Vanadium (V)
Contaminants (ppm)
Silicon (Si) 12
Sodium (Na) 10
Potassium (K)
Additives (ppm)
Magnesium (Mg) 636
Calcium (Ca) 936
Zinc (Zn) 679
Molybdenum (Mo) 71
Boron (B) 124
Contaminants
Physical Tests
Physical / Chemical
