Hyundai ELantra ATF follow up
by flinter. 07/17/19 10:14 AM
Poor Bill
by 4WD. 07/17/19 10:05 AM
Cadillac parked for 25 years...
by mattwithcats. 07/17/19 09:52 AM
Sumitomo Encounter Tires
by parshisa. 07/17/19 09:40 AM
API 1509 Updated with New GF-6B Shield
by Solarent. 07/17/19 07:27 AM
Car Vac Recommendations
by klt1986. 07/17/19 07:05 AM
ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
Aother MEGA score+Free Mobil 1 oil change
by GMguy84. 07/17/19 12:39 AM
I think I need therapy...
by tony1679. 07/16/19 11:53 PM
Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
guru2019, MBhuntington, captainfloss, Lyndol, Belczek
68682 Registered Users
100 registered members (14Accent, 4WD, AandPDan, AlaskaMike, Alfred_B, 87sammy, 7 invisible), 2,021 guests, and 30 spiders.
Topics291,983
Posts5,014,545
Members68,682
Most Online2,967
Mar 10th, 2019
Cheap powerfull filter magnet #5142852
06/24/19 01:50 PM
06/24/19 01:50 PM
WV
loneryder Offline OP
WV
I have a Harbor Frt. small magnetic parts cup. Recently I found that the magnet is just attached to the SS bowl by it magnetism. Pry it loose and it's the perfect size for an oil filter magnet. It may be too big for the smaller filters. Very strong and won't come off unless you hit something and I doubt it would come off even then.
Re: Cheap powerfull filter magnet [Re: loneryder] #5142877
06/24/19 02:27 PM
06/24/19 02:27 PM
Suburban Washington DC
atikovi Online content
atikovi  Online Content
Isn't the filter trapping the same stuff the magnet would?
Re: Cheap powerfull filter magnet [Re: loneryder] #5142884
06/24/19 02:39 PM
06/24/19 02:39 PM
Oregon
MrQuackers Offline
MrQuackers  Offline
Oregon
Filters let most anything less than 15 microns right on through so the magnet grabs the ferrous bits the full flow filters cannot.
Master the 1000 yard stare
coffeeMobil 1 USA
Re: Cheap powerfull filter magnet [Re: MrQuackers] #5142889
06/24/19 02:46 PM
06/24/19 02:46 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
True.
Though.... I don't see the point of having a big ring magnet on the bottom.
I put mine right where the flow is:
Originally Posted by Linctex
Magnets are 8mm N50 neodymium
[Linked Image]
Re: Cheap powerfull filter magnet [Re: Linctex] #5142895
06/24/19 02:52 PM
06/24/19 02:52 PM
Oregon
MrQuackers Offline
MrQuackers  Offline
Oregon
True.
[Linked Image]
Yes, because of your input I am doing the same.
coffeeMobil 1 USA
Re: Cheap powerfull filter magnet [Re: loneryder] #5142903
06/24/19 02:59 PM
06/24/19 02:59 PM
That is a cleaver idea but is this something that would only increase the life of the engine if you drove it 500,000 miles? What benefits does it have if you only use it 100,000 miles before trading it in?
Re: Cheap powerfull filter magnet [Re: atikovi] #5142913
06/24/19 03:09 PM
06/24/19 03:09 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I don't know.
The magnets cost near nothing.... they are extra left over from a quantity purchase for another project.
The truck has 194,000 miles on it now and doesn't burn a single drop of oil in 10,000 miles.
I'll likely run it another 200,000 miles. (yes, seriously)
Re: Cheap powerfull filter magnet [Re: loneryder] #5142928
06/24/19 03:28 PM
06/24/19 03:28 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Better off with high temperature magnets. As magnets get hotter, their field weakens unless made for high temps.
Re: Cheap powerfull filter magnet [Re: DoubleWasp] #5142945
06/24/19 03:41 PM
06/24/19 03:41 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I don't often very high oil temps in this truck.
Also , I have more of these in my bypass filter, too. They run even cooler yet.
Re: Cheap powerfull filter magnet [Re: loneryder] #5142968
06/24/19 04:21 PM
06/24/19 04:21 PM
New England
gathermewool Offline
New England
I don't think there are high-temp magnets. They will all degrade with exposure to hot oil.
I bought a bunch of these to hold up larger things on my fridge and work station; used the four remaining on the outside of the filter for each of our vehicles:
Neodymium Bar Magnets
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Magnatec 5W-20 + FU filter (47,300 miles)
Re: Cheap powerfull filter magnet [Re: loneryder] #5142996
06/24/19 05:04 PM
06/24/19 05:04 PM
Colorado
JerryBob Offline
JerryBob  Offline
Colorado
Old hard drives contain very strong magnets. If you can get your hands on an old HD.
Re: Cheap powerfull filter magnet [Re: JerryBob] #5142998
06/24/19 05:06 PM
06/24/19 05:06 PM
Alberta, Canada
Smokescreen Offline
Smokescreen  Offline
Alberta, Canada
Yep...and just stick them to the exterior of the filter....I have been doing that for years.
13 Civic Si 2.4L- 94Kkms(58Kmi)-QSUD,Wix
05 LeSabre 3.8L-274Kkms(171Kmi)-QSUD,Wix
03 Sierra 2500 6.0L-209Kkms(130Kmi)-QSUD,Wix
All with mpg > EPA
Re: Cheap powerfull filter magnet [Re: Smokescreen] #5143022
06/24/19 05:32 PM
06/24/19 05:32 PM
Massachusetts
DaHen Offline
DaHen  Offline
Massachusetts
Same here.
'06 Altima
ECHO: PB-255LN Blower
Husqvarna: 445E 18" Chain Saw
McCulloch: Electramac EM300S 16" Chain Saw
John Deere: TRS-26 Snow Blower
Craftsman, (Husqvarna in disguise): 22" Lawn Mower
Re: Cheap powerfull filter magnet [Re: gathermewool] #5143177
06/24/19 08:52 PM
06/24/19 08:52 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
there are high temperature magnets. And they do not degrade with high temperatures. some can go to extraordinary really high temperatures without losing their magnetism.
Re: Cheap powerfull filter magnet [Re: loneryder] #5143220
06/24/19 09:46 PM
06/24/19 09:46 PM
Michigan
BobsArmory Offline
BobsArmory  Offline
Michigan
Keeping the forces of evil at bay
2016 Chevy Malibu LT 1.5 Liter Turbo
2017 Chevy Equinox LT 2.4 Liter
2007 Pontiac Grand Prix 3800 Series III
