Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
88 registered members (1WildPig, AC1DD, 14Accent, 4WD, 2009Caraman, 90crvtec, 9 invisible), 1,831 guests, and 31 spiders.
Topics300,413
Posts5,175,255
Members70,497
AC for hybrid and electric vehicles #5138749 06/19/19 07:06 PM
J
JimPghPA Offline OP
J
I saw something interesting about the AC systems on hybrids and electric vehicles a couple of weeks ago, I think it was on one of Scotties YouTube videos but I can't remember for sure.
The AC on hybrids and electric vehicles has a compressor that shares it oil with an electric motor that drives it. If the AC system of a hybrid or electric vehicle is serviced using a refrigerant drain and charge system that has previously been used to service an AC system on a conventional gas powered vehicle then a small amount of impurities from the small amount of oil that got into the drain and charge system from it being used on a conventional system will contaminate the oil in the compressor and electric motor so that the oil no longer is non-conductive. This caused the electric motor to short out and fail.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: AC for hybrid and electric vehicles [Re: JimPghPA] #5138756 06/19/19 07:12 PM
L
LotI Offline
L
Rule number 1, don’t watch “Scottie’s YouTube videos”.
Rule number 2, see #1 or else you will go blind and get night vision lockjaw!
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX http://www.fuelly.com/car/buick/regal_tourx/2019/loti/943992
Re: AC for hybrid and electric vehicles [Re: JimPghPA] #5138757 06/19/19 07:12 PM
B
bullwinkle Offline
B
The easy answer would be-use virgin non-recycled refrigerant to recharge those hybrid A/C systems. Not sure what would be special about regular automotive refrigeration oil that would short out an electric motor? Regular A/C hermetic compressors always have the motor inside with the compressor head, and they don't (normally) short out.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: AC for hybrid and electric vehicles [Re: JimPghPA] #5138763 06/19/19 07:18 PM
J
JimPghPA Offline OP
J
Imagine having to replace the entire AC system is such a vehicle because the contamination would get into every part of the system and just replacing the compressor with built in electric motor would only set thing up to go bad again because of the contamination that by then had got into all parts of the AC system.
JimPghPa
Re: AC for hybrid and electric vehicles [Re: JimPghPA] #5138777 06/19/19 07:33 PM
M
mk378 Offline
M
Why would the oil in a conventional system be less pure than that in an electric system? If a mechanic thinks that a system is contaminated he'll send the customer away rather than ruin his expensive machine.
Re: AC for hybrid and electric vehicles [Re: JimPghPA] #5138790 06/19/19 07:51 PM
The Critic Offline
I don't know where Scottie gets this info from.
The electric a/c compressors use a special oil. Yes, the oil is non-conductive and you cannot contaminate the oil with conventional PAG oil. The compressor is electrically connected to the HV Battery but there is no connection between the electric drive motor and the a/c system; that is baloney.
2011 Toyota Prius 1.8L - 202K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: AC for hybrid and electric vehicles [Re: JimPghPA] #5138819 06/19/19 08:27 PM
I
itguy08 Offline
I
I don't know who Scottie is but this is true - from the MACS themselves:
https://macsworldwide.wordpress.com...echarging-ac-systems-on-hybrid-vehicles/
Re: AC for hybrid and electric vehicles [Re: JimPghPA] #5138833 06/19/19 09:08 PM
Chris142 Offline
The problem is the PAG oil that's used in every other car. They say that just a small amount of PAG oil in the valves,hoses etc will short out the hybrid parts. Must use a dedicated ac machine for hybrids or one that can flush its lines and other parts.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: AC for hybrid and electric vehicles [Re: JimPghPA] #5138842 06/19/19 09:27 PM
N
nthach Offline
N
xHEV/BEV compressors are the automotive cousin of a hermetically-sealed HVAC compressor that's used on refrigerators/freezers, portable AC units and small(home)-medium sized HVAC. They use POE oil that's similar to what's used in stationary HVAC and refrigeration(Emkarate RL) but not quite the same as "universal" ester oil for mobile HVAC.
Denso is tight-lipped about the composition of ND Oil 11, the stuff in the aftermarket seems to be repackaged Emkarate RL68 or Solest oil. There was some European firm saying the Denso stuff has a 50kV dielectric value, while stationary HVAC has 30kV.
Re: AC for hybrid and electric vehicles [Re: LotI] #5138919 06/20/19 01:34 AM
P
PandaBear Offline
P
This. That guy is a fraud and should be avoided (i.e. washing the CAT in detergent).
Hybrid car / EV's AC is running off / can be running off electric motor / battery, that's actually good because you are not forced to run the engine with the AC, and you can run it at a speed you need for the cooling load, instead of using a clutch to cycle it on and off.
My wife love to park the car and keep the AC on, with no engine running until the battery is low. It is actually very nice and still fuel efficient.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: AC for hybrid and electric vehicles [Re: itguy08] #5139199 06/20/19 11:25 AM
The Critic Offline
Yeah, I misread the original post. The compressor does share oil with the electric drive motor and therefore it needs the special oil. For some reason, I associated drive motor with the transaxle....read too quickly.
Re: AC for hybrid and electric vehicles [Re: PandaBear] #5140965 06/22/19 12:58 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Given that the dc bus on an xEV is like 300v, either would do if that was the case. There must be something else to it.
It’s kind of nice. The engine still has to start and short cycle/low load on an HEV every few minutes. The energy consumed by the battery or the engine to run the compressor is the same. The energy balance still requires the same amount of energy to do the cooling.
The trick is if it could actually be 10-15 minutes of ops and then one would be driving away anyway. Which is why I’m an advocate of phevs over hev and ev.
Re: AC for hybrid and electric vehicles [Re: JHZR2] #5142837 06/24/19 12:37 PM
N
nthach Offline
N
The AC compressor is usually driven off the 200V DC battery, it has a separate inverter(at least on Toyota-based hybrids). The hybrid motors run off a 500-700V AC bus - the voltage is boosted with a buck-boost transformer in the main inverter.
The compressors used in commercial HVAC and refrigeration run off 230V-460V AC. Someone should send in a sample of the Denso stuff and the Emkarate for testing.
