More Dog pics
by Marco620 - 11/16/19 11:48 PM
which weather site is most accurate?
by WhyMe - 11/16/19 11:25 PM
mopar coolant
by boombie10000 - 11/16/19 11:11 PM
2015 Honda CR-V loud engine noise
by FordBroncoVWJeta - 11/16/19 11:10 PM
Old Vise info
by A310 - 11/16/19 10:18 PM
2003 Ranger Radiator Replacement: Which Coolant?
by chucky2 - 11/16/19 08:55 PM
ATV axle removal
by supton - 11/16/19 07:45 PM
High speed chase
by P10crew - 11/16/19 07:28 PM
Oil for Daily Beater Camry
by Speak2Mountain - 11/16/19 07:18 PM
Green coolant, future availability ?
by rubberchicken - 11/16/19 06:11 PM
Weird tire wear
by ledslinger - 11/16/19 04:50 PM
Why does Ford resell lemons?
by avacado11 - 11/16/19 04:07 PM
Slow initial response to loading web pages
by JHZR2 - 11/16/19 04:06 PM
Motorcraft FL-910S
by PW01 - 11/16/19 03:54 PM
Walmart ammo clearance
by redbone3 - 11/16/19 03:35 PM
GENERAL Q regarding SPX snow plow
by Kira - 11/16/19 03:13 PM
78 C10 at show
by WiskyBadger - 11/16/19 03:00 PM
300blk ammo?
by buck91 - 11/16/19 02:52 PM
The Rock is still alive!
by Char Baby - 11/16/19 02:48 PM
billad67, Diverdown, natas, matt3540, ChrisWild
69886 Registered Users
34 registered members (bbhero, bdcardinal, Bonz, 69Torino, BloodyButUnbowed, 2 invisible), 1,079 guests, and 25 spiders.
Topics297,525
Posts5,117,383
Members69,886
Most Online3,589
Nov 2nd, 2019
Havoline 0W20 VI higher than 5w30 and 10w30? #5142752 06/24/19 11:10 AM
W
Whammo Offline OP
W
I was looking at the spec sheet for Havoline synthetic oils and the 0w20 has a higher VI than all the other oils listed. Do you reckon this must be a misprint?
https://cglapps.chevron.com/sdspds/PDSDetailPage.aspx?docDataId=518483&docFormat=PDF
Re: Havoline 0W20 VI higher than 5w30 and 10w30? [Re: Whammo] #5142770 06/24/19 11:29 AM
L
LotI Offline
L
No. The 0W is thicker at KV100.
You can calculate VI yourself to verify.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX http://www.fuelly.com/car/buick/regal_tourx/2019/loti/943992
Re: Havoline 0W20 VI higher than 5w30 and 10w30? [Re: Whammo] #5142774 06/24/19 11:33 AM
K
kschachn Offline
K
No, I "reckon" it is correct. Why would you think it is not?
Mobil 1 0W-20 is published as 173, well in the same range.
1994 BMW 530i, 250K
1996 Honda Accord, 280K
1999 Toyota Sienna, 425K
2000 Toyota ECHO, 284K
Re: Havoline 0W20 VI higher than 5w30 and 10w30? [Re: Whammo] #5142779 06/24/19 11:35 AM
W
Whammo Offline OP
W
Okay I guess I don't understand VI then.
Re: Havoline 0W20 VI higher than 5w30 and 10w30? [Re: Whammo] #5142781 06/24/19 11:37 AM
A
ad_infinitum Offline
A
No. Simply, viscosity index means the finished oil flows well at low temperature, and doesn't lose viscosity dramatically at operating temperature.
For comparison, Mobil 1 0w-20 AFE's viscosity index is 173, 5w-30 is 172, and 10w-30 is 146.
Re: Havoline 0W20 VI higher than 5w30 and 10w30? [Re: ad_infinitum] #5142784 06/24/19 11:39 AM
W
Whammo Offline OP
W
Originally Posted by ad_infinitum
No. It means that it flows well at low temperature, and doesn't lose viscosity dramatically at operating temperature.
Okay, so it isn't saying that it is thicker than the others at operating temperature?
Re: Havoline 0W20 VI higher than 5w30 and 10w30? [Re: Whammo] #5142787 06/24/19 11:44 AM
A
A
Not at all. Viscosity index is a dimensionless number that represents how the viscosity of lubricant changes with temperature. The greater the viscosity index (VI), the smaller the change in fluid viscosity for a given change in temperature, and vice versa. Thus, a fluid with a low viscosity index will experience a relatively large swing in viscosity as temperatures change. High-VI fluids, in contrast, are less affected by temperature changes.
Re: Havoline 0W20 VI higher than 5w30 and 10w30? [Re: Whammo] #5142792 06/24/19 11:50 AM
The Critic Offline
For people in warmer climates, wouldn't a lower VI be a good thing? To an extent of course.
It seems like most high VI oils are loaded with VII and are less shear-stable.
2011 Toyota Prius 1.8L - 199K - Pennzoil Platinum 0W-20
2007 Honda Accord 2.4L - 140K - Valvoline Premium Blue Restore 10W-30
Re: Havoline 0W20 VI higher than 5w30 and 10w30? [Re: Whammo] #5142796 06/24/19 11:53 AM
A
A
Maybe this chart can help you understand: at 40c all the oils are the same viscosity, but as the temperature increases the oils with a lower VI lose their viscosity at a more significant rate in comparison to the oils with a higher VI.
[Linked Image]
Re: Havoline 0W20 VI higher than 5w30 and 10w30? [Re: The Critic] #5142817 06/24/19 12:14 PM
P
PandaBear Offline
P
That, or they are blended with extremely thick and thin base oil (synthetic) and the volatility is high, leads them burnt off / evaporate away. I'd try to use 10w30 and 5w20 instead of 5w30 and 0w20 whenever possible.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Havoline 0W20 VI higher than 5w30 and 10w30? [Re: PandaBear] #5142846 06/24/19 12:45 PM
4WD Offline
Or it benefits (just as a published number) from low cold flow ability - and that does not mean much to me even though I own two 0w20 spec engines …
I could spend $50 gallon to get a really high VI 0w20 - but that's not going to protect my 7500 watt gen better than 15w40 at $12 gallon (would have much lower VI)
Re: Havoline 0W20 VI higher than 5w30 and 10w30? [Re: Whammo] #5142858 06/24/19 12:58 PM
R
Rand Offline
R
iirc TGMO 0w20 was 200+ VI
Re: Havoline 0W20 VI higher than 5w30 and 10w30? [Re: Whammo] #5142876 06/24/19 01:27 PM
L
LotI Offline
L
You would want to look at HTHS viscosity. It represents how a fluid flows in the engine parts at high temperatures. A less useful but highly published number is KV100, or how an oil flows at 100C aided by gravity alone.
11 Kawasaki KLR 650
Re: Havoline 0W20 VI higher than 5w30 and 10w30? [Re: kschachn] #5142883 06/24/19 01:38 PM
B
bbhero Online Content
Online Content
B
Guess you are too fancy and sophisticated to like the word "reckon".... LOL
Nissan Altima 3.5 Coupe
Cam2 Dexos1 Gen 2 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Havoline 0W20 VI higher than 5w30 and 10w30? [Re: The Critic] #5142995 06/24/19 04:03 PM
SR5 Offline
Yes, I think so, assuming it’s well made.
I’m running a full Group III synthetic 10W30 right now, and it offers me all the winter cold starting ability I will ever need, but more shear stable and lower noack volatility than an equivalent 5W30.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
