More Dog pics
by Marco620 - 11/16/19 11:48 PM
which weather site is most accurate?
by WhyMe - 11/16/19 11:25 PM
mopar coolant
by boombie10000 - 11/16/19 11:11 PM
2015 Honda CR-V loud engine noise
by FordBroncoVWJeta - 11/16/19 11:10 PM
Old Vise info
by A310 - 11/16/19 10:18 PM
2003 Ranger Radiator Replacement: Which Coolant?
by chucky2 - 11/16/19 08:55 PM
ATV axle removal
by supton - 11/16/19 07:45 PM
High speed chase
by P10crew - 11/16/19 07:28 PM
Oil for Daily Beater Camry
by Speak2Mountain - 11/16/19 07:18 PM
Green coolant, future availability ?
by rubberchicken - 11/16/19 06:11 PM
Weird tire wear
by ledslinger - 11/16/19 04:50 PM
Why does Ford resell lemons?
by avacado11 - 11/16/19 04:07 PM
Slow initial response to loading web pages
by JHZR2 - 11/16/19 04:06 PM
Motorcraft FL-910S
by PW01 - 11/16/19 03:54 PM
Walmart ammo clearance
by redbone3 - 11/16/19 03:35 PM
GENERAL Q regarding SPX snow plow
by Kira - 11/16/19 03:13 PM
78 C10 at show
by WiskyBadger - 11/16/19 03:00 PM
300blk ammo?
by buck91 - 11/16/19 02:52 PM
The Rock is still alive!
by Char Baby - 11/16/19 02:48 PM
billad67, Diverdown, natas, matt3540, ChrisWild
69886 Registered Users
40 registered members (bbhero, bdcardinal, Bonz, 69Torino, BloodyButUnbowed, 1 invisible), 1,086 guests, and 25 spiders.
Topics297,525
Posts5,117,383
Members69,886
Most Online3,589
Nov 2nd, 2019
PCV Valve Cleaning Replacement ? #5142736 06/24/19 10:54 AM
ChrisD46 Offline OP
The Elantra (just over 100K miles) in my sig. is due for a PCV valve replacement ... The car doesn't burn any oil , has always used synthetic oil with OCI's of less than 6K miles and when the oil comes out it's still a dark amber and doesn't smell burnt .
I'm guessing that over time a PCV valve deteriorates in performance leading to engine varnish , sludge , etc. ... I figure a decent maintenance schedule is to clean the PCV valve ever 25K miles and replace at 100K miles ? Lastly , I'm sure (as I) there are a large group of people who never pay attention to their PCV valves ... My only redemption (maybe ) is that I use the latest spec synthetic 5W20 / 5W30 in my vehicles since new and change the oil & oil filter < 6K miles each time . Your thoughts on PCV valve maintenance ?
'17 Hyundai Sonata 2.4L GDI 5W20 QSUD / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: PCV Valve Cleaning Replacement ? [Re: ChrisD46] #5142740 06/24/19 10:58 AM
JohnnyJohnson Offline
They are so cheap I just replace mine I've tried cleaning them with less than favorable result. I can get a new one for less that $8.
2004 Corolla 136904
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 76703
Out: T6 5W-40 XG9100 73705
In: Rotella Dino PH9100 11-3-19
Re: PCV Valve Cleaning Replacement ? [Re: JohnnyJohnson] #5142788 06/24/19 11:47 AM
W
WhizkidTN Offline
W
OP: Just replace it with the OEM one. Super simple.
FWIW: I'm still running my original PCV valve but it works great (I test it) and I have cleaned it in the past with CRC Throttle body cleaner (wasn't really dirty, but easy to do).
Just go easy on the plastic threads and don't forget about the O-ring (lube with fresh oil).
His: '12 Kia Optima SX - 2.0L GDI Twin-Scroll Turbo [Tuned] (85K)
>EDGE 0W-40, Fram XG9688
Her's: '14 Nissan Rogue SL AWD - 2.5L NA (94K)
>EDGE 0W-20, Fram XG6607/XG7317
Re: PCV Valve Cleaning Replacement ? [Re: ChrisD46] #5142798 06/24/19 11:55 AM
N
njohnson Offline
N
I wonder if the shape and the size of the PCV valve makes a difference? Our two SUVs have small plastic PCV valves. On the one SUV, I didn't change it or clean it like I should have. It had deposit buildup bad enough that it didn't rattle anymore. Our dad has a 2006 Tundra with the 4.7L V8. I checked the PCV valve at around 100,000 miles, it is the original factory PCV valve. It is metal and is threaded into the valve cover. It is also probably around double the size of the SUV's valves.
I checked it, wondering if it was starting to clog up. I was curious because, not only is the valve bigger, but, we have used synthetic oil since the factory fill was dumped.
Unscrewed the PCV valve, it still rattled. Started the truck up, and put my thumb over the end. It about pulled some of the flesh of my thumb into the valve! Lots of suction.
I was happy with that. What made the difference? The size of the PCV valve? Or the use of synthetic oil since new?
Re: PCV Valve Cleaning Replacement ? [Re: ChrisD46] #5142803 06/24/19 12:02 PM
Propflux01 Offline
Probably both.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
A 55 Gallon Drum And A Shovel Can Solve A lot of Life's Little "Problems"
Re: PCV Valve Cleaning Replacement ? [Re: ChrisD46] #5142829 06/24/19 12:26 PM
M
mclasser Offline
M
I've only changed a PCV valve once - on my Accord at like 160k miles. Did it purely b/c I heard it's something that should be replaced periodically, not b/c there was any problem. The factory one still rattled and looked fine. Changed it out anyway and noticed no difference.
I'm only going to change one now if I have a problem, e.g., oil burning, rough idle, visibly damaged, and etc. If it ain't broke.....
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: PCV Valve Cleaning Replacement ? [Re: ChrisD46] #5142894 06/24/19 01:50 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
I've seen dealers carry high-flow versions for those cars with high blow-by.
Re: PCV Valve Cleaning Replacement ? [Re: ChrisD46] #5142967 06/24/19 03:19 PM
L
Linctex Offline
L
The one for my 2008 4.6L F150 is electrically heated (???) and gets "destroyed" when removed from the valve cover.
It's almost $50!!! ( $41.79 from RockAuto plus shipping)
If it ain't broke......... you know
I pull the hose off the top of it, and spray a little Berryman's B-12 spray down through it every 6 months.
I'll never replace it until it absolutely *NEEDS* to be replaced. Until then, I just clean it once in a while.
Re: PCV Valve Cleaning Replacement ? [Re: ChrisD46] #5142973 06/24/19 03:28 PM
K
Kjmack Offline
K
VW PCV is $ 160-180 range
Re: PCV Valve Cleaning Replacement ? [Re: ChrisD46] #5142983 06/24/19 03:42 PM
V
Virtus_Probi Offline
V
I had a dealer do a PCV valve replacement for me at a 90+kmile service (closer to 100k) even though I had purchased one on my own for $8-9 some time before. I really didn't want to pull that intercooler myself, I admit it...I mangled it a bit by barely touching it when it was new!!
Among a number of other odd things at that service, they charged me for 2 PCVs @ $20 each!
I can't find a parts diagram for the FA20DIT engine that shows the PCV valve...does it actually have two of them???
2014 Forester XT, 105000 miles
Last Change;
PP 5w30 d1G2
Tokyo Roki 15208AA170 filter
Re: PCV Valve Cleaning Replacement ? [Re: Virtus_Probi] #5143448 06/25/19 06:23 AM
V
V
Well, I did find a parts diagram and whatever I bought a while ago isn't the PCV valve.
Looks like I bought the "Hose Assembly-Pcv" and I should have bought "Valve Complete-Control".
Guess I'm a dummy for thinking the part with PCV in its name was the PCV valve!!!
Still don't think my car has 2 PCVs....I have had 3 Subaru dealers just hose me on service in the last couple of years between our two cars.
Gotta learn to do more myself!!!!
Last Change;
PP 5w30 d1G2
Re: PCV Valve Cleaning Replacement ? [Re: ChrisD46] #5143456 06/25/19 06:28 AM
ChrisD46 Offline OP
OP here : Thanks for the replies ... I decided to buy OEM PCV valves (on-line) to ensure I had the right fit ... The ones shown at Autozone , etc. were less expensive but looked different . Not sure if there is a quality difference but considering it's not something I have to replace so frequently I decided on the OEM PCV vales and call it a day .
Re: PCV Valve Cleaning Replacement ? [Re: ChrisD46] #5143840 06/25/19 02:14 PM
DGXR Offline
I went to replace the PCV in my Tacoma at 150,000 miles simply due to time and mileage. But I bought the wrong replacement valve (CA models have threaded install, not the typical grommet and push-on fit). So I cleaned, lubed and reinstalled the existing one which seemed to be working fine, and still have no issues. No burning oil, no smoke.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: PCV Valve Cleaning Replacement ? [Re: Linctex] #5144062 06/25/19 07:13 PM
clinebarger Offline
The little lock breaks off them, But doesn't destroy it. I've ran across those during engine swaps ('04 4.6L into a '05 model truck for example)......They're "Turn to Lock/Seat" with a O-ring seal like a lot of oil caps. Oil caps don't come off by themselves.
2001 Chevy Camaro L92/4L80E
Re: PCV Valve Cleaning Replacement ? [Re: ChrisD46] #5144607 06/26/19 11:22 AM
N
nthach Offline
N
If the valve is easily replaced, it doesn't hurt. Stick with OEM. On most cars, unless it's a chronic sludge monster or has a poorly-designed PCV system, there might not be a need to touch the PCV valve unless there is a driveablity concern. The PCV system does interact with manifold vacuum.
