API 1509 Updated with New GF-6B Shield
by Solarent. 07/17/19 07:27 AM
Car Vac Recommendations
by klt1986. 07/17/19 07:05 AM
ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
Aother MEGA score+Free Mobil 1 oil change
by GMguy84. 07/17/19 12:39 AM
I think I need therapy...
by tony1679. 07/16/19 11:53 PM
Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
My new rig - 1987 Ford Econoline 27' Glendale RV
by caprice_2nv. 07/16/19 07:44 PM
Air Compressor OCI?
by Vern_in_IL. 07/16/19 07:35 PM
Looking for an SUV
by dgunay. 07/16/19 07:29 PM
Castrol GTX Magnatec 5w30
by Envoyguy. 07/16/19 07:21 PM
2019 Subaru Dual X-Mode
by buster. 07/16/19 06:36 PM
guru2019, MBhuntington, captainfloss, Lyndol, Belczek
68682 Registered Users
105 registered members (AlienBug, AandPDan, 69GTX, aquariuscsm, Alfred_B, 2010Civic, 10 invisible), 1,874 guests, and 22 spiders.
Topics291,979
Posts5,014,501
Members68,682
Most Online2,967
Mar 10th, 2019
Think I killed my Briggs 190CC Free Mower #5142597
06/24/19 09:14 AM
06/24/19 09:14 AM
Central NY
Miller88 Offline OP
Miller88  Offline OP
Central NY
Free lawnmower I got two years ago. When I got it , both the crankcase and the gas tank were full of water. Through a lot of frustration, I got the carb working correctly. Sharpened the blade and it was back in business.The last two springs, it started on the first pull with ZERO winterization -- but I do use ethanol free gas in it.
I was playing brushhog with it a few weeks ago mulching some weeds and stuff I pulled out of an old, overgrown flowerbed. I ran it a bit too hard. I noticed it started burning oil and the exhaust smelled of dead engine. I kept the oil full and kept going. The next time I mowed the lawn it was a darn good mosquito fogger. I have a really small lawn and it managed to run through all of it's oil doing just my back yard.
Was mowing yesterday and it would occasionally start popping out of the intake (or I thought). And it seemed to have less and less power as I kept going. Then it started stalling every 30-40 seconds -- every time I'd pull the rope to start it, I seemed to have less and less compression.
It did go out with a bang, though. Then there was no compression - I don't even get a reading when checking the compression. So I took the head off hoping to find a stuck valve or a lose valve seat. Nothing with the valves but the bottom of the cylinder is really scored. Put it back together and tried to fire it up without the air filter and found out that it was popping out of the breather. Guess the rings had enough.
The best brushhog is a free mower! Until it kills the mower.
On to the next free mower!
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Think I killed my Briggs 190CC Free Mower [Re: Miller88] #5142605
06/24/19 09:29 AM
06/24/19 09:29 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
No compression ? Cam bad ? Hole in piston ?
Wyr
God bless
Re: Think I killed my Briggs 190CC Free Mower [Re: Miller88] #5142610
06/24/19 09:33 AM
06/24/19 09:33 AM
New York City
SeaJay Offline
SeaJay  Offline
New York City
you got you money's worth, and then some.
I had a free mower, didn't do nothing except change the oil once every season and put E10 fuel (the only kind available by me) in it when needed. Fuel tank leaks some, but ran for five years until I gave it away for free to someone else, who as far as I know is still using it.
Re: Think I killed my Briggs 190CC Free Mower [Re: Miller88] #5142632
06/24/19 09:54 AM
06/24/19 09:54 AM
FL
CharlieJ Offline
CharlieJ  Offline
FL
What killed the mower? Using it to mulch some brush shouldn't have killed it, something else went wrong.
'07 Mazda3 2.3 Mobil 1 HM 5w-30
'84 Mazda Rx-7 Valvoline Maxlife 10w-30
Re: Think I killed my Briggs 190CC Free Mower [Re: WyrTwister] #5142727
06/24/19 11:39 AM
06/24/19 11:39 AM
Central NY
Miller88 Offline OP
Miller88  Offline OP
Central NY
Got my money out of it for sure!
I think the rings are gone. the bottom of the cylinder wall is really scored
I think sitting for a year or two with rainwater in both the gas tank and crankcase is what did it in
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Think I killed my Briggs 190CC Free Mower [Re: Miller88] #5142805
06/24/19 01:05 PM
06/24/19 01:05 PM
Arkansastan
Propflux01 Offline
Propflux01  Offline
Arkansastan
Broken rings maybe, hence the sudden fog. Then continue to run Until they just disintegrated ?
2014 Hyundai Elantra
2014 Hyundai Elantra GT
A 55 Gallon Drum And A Shovel Can Solve A lot of Life's Little "Problems"
Re: Think I killed my Briggs 190CC Free Mower [Re: Miller88] #5142807
06/24/19 01:08 PM
06/24/19 01:08 PM
MN
ZebRuaj Offline
ZebRuaj  Offline
MN
Is the deck worth holding on to? Frankenswap time with another curb pick up mower.
~Shade tree mechanic for friends and family.
Re: Think I killed my Briggs 190CC Free Mower [Re: ZebRuaj] #5142828
06/24/19 01:25 PM
06/24/19 01:25 PM
Central NY
Miller88 Offline OP
Miller88  Offline OP
Central NY
I think that's what happened. It seemed to burn a decent amount of oil over the three summers I had it.
That's the plan! Friend of mine has a few curb picked lawnmowers with rotted decks. The deck on this one is in good shape for as old as it is. I'm assuming most B&S lawnmower engines should mount to the deck in a similar fashion?
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Think I killed my Briggs 190CC Free Mower [Re: Miller88] #5142836
06/24/19 01:35 PM
06/24/19 01:35 PM
MN
ZebRuaj Offline
ZebRuaj  Offline
MN
The motor mount pattern should be. Just hold on to the corresponding bolts. And blade adapter + bolt.
I put a B&S from a Craftsman onto a Toro. Carry over the motor bolts as they were different thread pitch. Same for the blade adapter bolt in my situation.
Re: Think I killed my Briggs 190CC Free Mower [Re: Propflux01] #5142944
06/24/19 03:40 PM
06/24/19 03:40 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
You pretty much nailed it.
if it was "running fine" - - - - - then got pretty bad pretty fast - - that's about right
Re: Think I killed my Briggs 190CC Free Mower [Re: Miller88] #5142964
06/24/19 04:12 PM
06/24/19 04:12 PM
Florida
1978elcamino Offline
Florida
donate the mower to project farm
2018 F150 5.0
2016 Ford Fusion 2.5
Re: Think I killed my Briggs 190CC Free Mower [Re: Miller88] #5143068
06/24/19 06:25 PM
06/24/19 06:25 PM
ME
eljefino Offline
eljefino  Offline
ME
If the crank's good, save it. Lots of mowers with bent shafts from hitting rocks. Build a frankenmower!
The carb may be worth retaining as well.
Re: Think I killed my Briggs 190CC Free Mower [Re: Miller88] #5143141
06/24/19 07:55 PM
06/24/19 07:55 PM
Central NY
Miller88 Offline OP
Miller88  Offline OP
Central NY
Well that worked out great! Friend of mine had a craftsman he picked from the curb. No front wheels because the deck was cracked. Same exact engine as mine. Swap took about 15 minutes. The cable is also exactly the same so not even a problem!
I'll save the carb off of the dead one and plan to swap it since the "new" one stumbles a bit when I start it. I rebuilt the carb on the dead one a few years back when I got it. I'll take the piston out and use that as some sort of wall art or something.
Just needs the blade sharpened and it should be cutting on our next scheduled sunny day ... which may not be until August.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Think I killed my Briggs 190CC Free Mower [Re: Miller88] #5143375
06/25/19 04:32 AM
06/25/19 04:32 AM
WA
vw7674 Offline
vw7674  Offline
WA
whatever you find next, you can drill the deck to accommodate.
I've got B&S and Tecumseh patterns drilled on mine, zero issues. Swap away.
Re: Think I killed my Briggs 190CC Free Mower [Re: WyrTwister] #5144006
06/25/19 06:36 PM
06/25/19 06:36 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
hole in piston? Never seen that before.
The "thinking" man's friend.
