Telephone demarc boxes
I had to have the surge protector replaced twice in the last five years. I knew something was wrong when I picked up the phone and all I heard was a constant staticy noise and could not dial any numbers. Took the repair tech about 5 minutes start to finish to diagnose and fix the problem.
Yes, I am sure a phoneman knows how to test a surge protector, but how can I test it?
I think that if your line is noisy, then the surge protector is bad. If it's quiet then the surge protector is likely bad. That would be my guess based on the two instances I experienced.
The protector is in place to protect the inside wiring and customer premise equipment from power surges/lightning strikes. They are gas filled and I've seen them pop in hot weather. Just bypass it. Drop wire to IW. See if dial tone returns. Best way is to clip to the disconnected drop with a buttset. I was a telephone repairman for seventeen years and have changed quite a few of them.
lol WHUT? Either way it's bad?
Okay I get what you meant, but let's back up a minute...
How to test whether a surge protector still works depends on how it's designed. Each discrete component has its own test method.
Unless you're a rocket surgeon (aka electronics guru) who has a bench supply capable of generating high voltage, and reverse engineer the surge protector to determine what the clamp voltage should be, then instead you inspect the components.
Again it depends on how it is designed, but to start with, if you see spark gaps with burnt bridges, or MOVs cracked apart or pinholes in them, they are out of service. Similarly any blackened component is suspect. I am over-generalizing now, some things like TVS or GDT, are probably fine if they look okay. Shunting a large surge then failing to provide further protection, tends to be destructive visually.
