2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
Flank drive wrenches
by spasm3 - 01/24/20 08:39 PM
Auto assembly and mfg. logistics
by P10crew - 01/24/20 08:26 PM
Kodiak
by P10crew - 01/24/20 08:05 PM
yet another black eye for the 2,4 ecotec
by super20dan - 01/24/20 07:52 PM
New incentive for 0w20
by Snagglefoot - 01/24/20 06:43 PM
2020 Kia Forte Engine
by artbuc - 01/24/20 03:27 PM
Torn filter that's NOT a motorcraft.
by mpgo4th - 01/24/20 03:22 PM
K&N PS-1008 $3.36
by jayjr1105 - 01/24/20 03:14 PM
Forum notifications?
by jayjr1105 - 01/24/20 02:50 PM
Thinking about transmission cooler for Honda
by jayjr1105 - 01/24/20 02:26 PM
Goodyear Assurance Comfortred Touring
by Keystone - 01/24/20 02:03 PM
Pete44, Connie7, 2020XT, 4strokes, Perseus
70518 Registered Users
59 registered members (4WD, ArrestMeRedZ, aleneros, Analyzer, alchargo, 6 invisible), 1,824 guests, and 20 spiders.
Topics300,513
Posts5,177,552
Members70,518
Trailer Flooring??? #5142140 06/23/19 06:36 PM
M
maverickfhs Offline OP
M
So I recently picked up a 4x8 and it's made by this company: http://cesmith.com/ and comes with 13 inch tires. I really liked it, can be an excellent platform for towing motorcycles and other stuff behind a car smile
But the floor is made of plywood and it's almost rotted out.
Have to put a floor, was thinking to use 2x4(PT), laid right next to each other would be a good option. Is that a good option or should consider something else? Appreciate any help and advise thumbsup
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
Re: Trailer Flooring??? [Re: maverickfhs] #5142161 06/23/19 06:53 PM
P
philipp10 Offline
P
Green treated plywood will probably last you more than a decade and mounts easily. How would you mount separate 2 x 4's?
Re: Trailer Flooring??? [Re: philipp10] #5142168 06/23/19 06:59 PM
M
M
What size or thickness for plywood would be good for motorcycle, fridge or very rare furniture stuff?
There are mounting holes on the frame, so laying one with the other and then bolting them down? Definitely a noob!
Re: Trailer Flooring??? [Re: maverickfhs] #5142188 06/23/19 07:24 PM
Danno Offline
You're looking at either 1/2" or 3/4" plywood. The 3/4" is quite heavy. How thick was the original plywood floor?
https://www.lowes.com/pd/Severe-Wea...-Sheathing-Application-as-4-X-8/50017278
https://www.lowes.com/pd/Severe-Wea...-Sheathing-Application-as-4-X-8/50017280
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Trailer Flooring??? [Re: Danno] #5142214 06/23/19 07:54 PM
M
M
Thanks, think original is 3/4" but will measure it tomorrow.
Re: Trailer Flooring??? [Re: maverickfhs] #5142219 06/23/19 08:00 PM
E
Eddie Offline
E
3/4 IS THE WAY TO GO. ED
2014 CX5 Touring 2.5L :-)
Re: Trailer Flooring??? [Re: maverickfhs] #5142337 06/23/19 10:01 PM
double vanos Offline
If you go with 2x4s treat yearly with copper green: https://www.lowes.com/pd/COPPER-GRE...ner-Actual-Net-Contents-1-Gallon/3064247
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Trailer Flooring??? [Re: maverickfhs] #5142383 06/23/19 11:34 PM
Dave9 Offline
Plastic deck planks. You don't need 2x (4) thickness, mostly just something that won't rot.
Re: Trailer Flooring??? [Re: maverickfhs] #5142396 06/24/19 12:06 AM
Nick1994 Offline
Just get another sheet of nice plywood and either paint it or seal it, and just replace every few years. Not too big of a deal.
2015 Hyundai Genesis 5.0L 56k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 236k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 149k Mobil 1 HM 10w40 & Fram Ultra
Re: Trailer Flooring??? [Re: maverickfhs] #5142506 06/24/19 06:42 AM
M
Miller88 Offline
M
PT 4x8 sheet of 3/4'' plywood is what I have on mine. It's worked for appliances and > 2000 pounds of gravel / dirt / fill / cinder blocks
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Trailer Flooring??? [Re: maverickfhs] #5142535 06/24/19 07:06 AM
P
pcoxe Offline
P
Treated lumber can be corrosive to steel. Plastic deck boards would probably be best.
Re: Trailer Flooring??? [Re: Nick1994] #5142571 06/24/19 07:40 AM
supton Offline
Ditto. I did a sheet of advantek (sp?) and left it untreated, per the advice of the guy at the lumber store; I think it went 8 years before it rotted out? Mind you it would be full of snow over the course of the winter. Second time around I splashed house paint on it and it's holding up much better. Single sheet of 3/4" and some carriage bolts.
FWIW my HF trailer was painted red but it was the cheapest red they could use. And the metal is cheap too. You might do well to slap some house paint onto the metal surfaces too to slow down UV exposure on the paint that is still good.
Edit: on PT 2x4's (if you do siding) you're supposed to use galvanized hardware but I didn't, just used cheapo zinc and it seems to be holding up ok. YMMV. I suspect the unpainted PT will die before the zinc hardware will.
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 220k, his
Re: Trailer Flooring??? [Re: maverickfhs] #5142621 06/24/19 08:42 AM
SeaJay Offline
Don't overthink it, put down some thick plywood. Slap some polyurethane on the wood first if it makes you feel better about its longevity.
Re: Trailer Flooring??? [Re: maverickfhs] #5145090 06/26/19 07:40 PM
P
philipp10 Offline
P
depends upon the structure below the wood but I would go 5/8 or 3/4. I used 5/8" and it was plenty. I was glad I went 5/8" over the 3/4 just due the weight savings. Some poster mentioned replacing every few years.....trust me, it will last minimum 10 years. I know because I have a piece of non-treated as a lean-to roof that went 15. On my trailer I didn't even bolt it down, just used wire as tie wraps on the front. It fit so tight I don't think it could come out even without them.
Re: Trailer Flooring??? [Re: philipp10] #5145095 06/26/19 07:41 PM
M
M
Thank you, would OSB board would be good too?
