Originally Posted by wings&wheels
First run w/ Redline? There is a school of thought that Redline cleans aggressively and the numbers may not be from current wear. I always thought that 10w-30 was light for that car considering the RoW spec was 5w-40 I believe. I had a 2001 and ran it on Redline 5w-40.
That's interesting that Redline cleaning up old wear could be the cause, I had no idea. Looks like the common recommendation is to retest but with a different type of oil. I've ordered an OEM filter and will swap in PP or something similar. I used to run redline in another car and I liked it. When I bought this one I changed the oil to redline. I believe the most recent PO was running mobile 1. 10w-30 is recommended spec for this car, 5w-40 if you're in cold climates.
Originally Posted by Trav
Being a used car when he got it kind of leaves full disclosure of previous use a dark area. Personally I rather have a look see and find nothing or find the beginning of a issue before it comes back to bite me.
Just wanted to add it could be a thrust bearing wear on manual transmission.
I have seen reports of S2000s going through rod bearings and even main bearings, but it's not that common and usually due to massive oil starvation, such as being 3 quarts down or extended cornering with r comps.
I'm going to put pulling the pan on the list and do it once I find someone who knows what they're looking for with the rod bearings. In the mean time I'm going to change the oil and filter. Regarding the thrust bearing, my wife drove the car while I was away at work for a week. I rode with her later and was cringing at how she was using the clutch, so perhaps that caused increased wear also.
Originally Posted by JAG
If you keep using the Red Line and the lead and copper don't come down, you won't be able to know if the engine is unhealthy or if the oil is causing those metals to slowly dissolve into the oil.
very good point.
Originally Posted by oldhp
What's the oil pressure look like when hot?
The car is basically stock with a conservative tune, I don't have an aftermarket oil pressure gauge, just a dummy light, which has never gone off and I've never had an issue with VTEC lagging, which reportedly happens when you have low oil.
Originally Posted by aquariuscsm
Just for kicks I would do another uoa on good otc synth 10W30,like PP or QSUD.
Doing this.
