Originally Posted by ChrisD46
For the guy who wants to pick up a can of engine degreaser from WM , what is your favorite brand in terms of working well and ease of use applying & then rinsing with a garden hose ?
Gunk non-foaming. The foaming action seems like a waste. Been a looooooong time since I have done this, and there are a couple of different ways but.. Gunk brand non-foam.
Quote
I have always used Gunk, but was surprised the Walmart stuff worked better for less money.
I have had the same experience.
You can use Purple Power, standard oven cleaner (carefully,) as mentioned - the dish detergent if you let it sit on hot engine to clean, there are a few methods, just cover up the electrical and watch the show, might want to make sure the water is as warm as can be ? due to exhaust manifold, very hot, and hot on cold or hot on not hot enough makes for crack You could probably even use Simple Green
