The other day we had a debate on fuels in a Classic Ford group i'm in.
Most people seem to run Lead replacement additives in their cars, i haven't for a long time though as i honestly thought it was a load of bull...
In the US / N.A this probably isn't much of a problem, as lead was banned much earlier than in Europe.
In most of Europe new cars began to be made with engines that could run on unleaded around 1985, catalytic converters did not become commonplace or mandatory until 1990-1993 in the then EEC.
In fact leaded gasoline was only phased out in most of Europe between 1999-2003.
My question is, do these "Lead Replacement" additives really work? i haven't noticed any symptoms of valve seat recession running plain 98 RON E5 gasoline in my Capri, which being made in 1975 has no emissions equipment and was made to be run on Super Leaded ( 97 RON ) gasoline, also known as Four Star in the UK.
The common symptoms of VSR are loss of compression, rough idling and the exhaust valve clearance closing up excessively on engines with mechanical lifters, as the valve effectively digs itself into the valve seat, i have none of these symptoms.
Some people instead of using Lead replacement additives add around 1% 2 stroke oil to their fuel, supposedly it helps neutralize the Ethanol in the gasoline ( we only have E5 here ) and also lubricate the valve seats.
