spasm3 Joined May 30, 2010 Messages 16,777 Location North Carolina Jun 21, 2019 #1 I have a tank of c-25 80cf. Its mounted vertically on my mig cart. I don't use it that often. Is the gas going to stratify in the tank? Is so how much movement does it take to correct it? Thanks
Lyman Joined Aug 13, 2011 Messages 3,103 Location Lakeside, CA Jun 21, 2019 #3 You are fine. I worked in the Welding Supply Industry for 10 years.
L Linctex Joined Dec 31, 2016 Messages 10,144 Location Waco, TX Jun 21, 2019 #4 I researched this once - the gas is always moving on its own.
T tom slick Joined May 26, 2003 Messages 10,023 Location Central Coast, Calif. Jun 22, 2019 #5 Even if it did stratify you can still weld with up to 100% of either gas.
