Originally Posted by cwilliamsws6
I'm planning on saving up all my summer paychecks toward the purchase of a 98-02 V6 Camaro (read: am broke 17 year old redneck) but after I am graduated and have my own place and all that I would want to put in an LS1. I know the cars are the same platform so what all would be involved in converting it from the 3800 to the LS1?
*K-Member W/ Engine Mount Brackets.
*V8 Auto trans crossmember.
*Radiator....The radiator is actually the same besides the Steam Hose Fitting needed for LSx engines.
*Upper & Lower Radiator Hoses
*Heater Hose Assembly....No, You can't just run rubber hoses!!!
*Power Steering hoses.
*A/C Hose Assembly.
*Battery Cables (The whole assembly!)
*Air Filter Lid, Bellows, MAF.
*Throttle Cable, Throttle Pedal, Cruise Module & Cable (If the 3800 car is DBW), '99-'02 are DBW.
*Fuel Pressure Regulator as the 3800 have a rail return line vs Returnless on the LSx cars....Don't cheap out on this part!...Miscellaneous fuel lines & fitting to run a remote FPR.
*You have to add a fuse in the fuse block for Bank 2 Fuel Injector power. You can also modify a V8 harness to run all 8 injector off 1 fuse.
This above ASSUMES you have a LS1/4L60E out of a '99-'02 F-body with the front accessories, Engine Harness, Intake, Throttle Body, Oil Pan, Mounts etc.
The swap using a T56 adds more complications & you would almost need to start with a T5 equipped 3800 car to be remotely worth it!!
Buy a matching Header & Exhaust system!, Don't remember the last time I saw a LSx 4th gen with stock exhaust. The Hooker Blackheart system are nice!
My Camaro started life as a 3800/4L60E car.....But it's well beyond a LS1 swap at this point!
*L92 out of a 2008 Cadillac Escalade with a custom grind & dual valve springs
*5th Gen Camaro (LS3/L99) front accessories
*2003-2007 P59 engine controller with a custom engine harness
*4L80E with a 3200 stall converter
*Strange Dana 60, Truetrac, 3.73
