Bolt Carrier Group lubrication choices
by BlueOvalFitter. 07/23/19 10:42 PM
Rotella Truck Gasoline oil in sedan?
by Whammo. 07/23/19 10:36 PM
Part Throttle bad for 2-strokes?
by 92saturnsl2. 07/23/19 10:12 PM
"Newest" Rotella in Gasoline engine
by MontePrix28. 07/23/19 08:22 PM
GMC Yukon 70K Mile failures
by kstanf150. 07/23/19 08:20 PM
2019 Prius AWD-e underbody shots
by eljefino. 07/23/19 08:09 PM
Anti-Foaming / Anti-Aeration Additives
by RDY4WAR. 07/23/19 07:37 PM
Oil Change Tip
by KeithS_NW_Ohio. 07/23/19 07:34 PM
A New One on Me
by Danh. 07/23/19 07:19 PM
Subaru Syn 5w-30
by Ken42. 07/23/19 06:42 PM
Towing report - 2016 Grand Cherokee SRT
by OVERKILL. 07/23/19 04:02 PM
Rear Differential question
by dawgn86. 07/23/19 03:48 PM
Clean Engine - Skyactiv 2.0 - 62k miles
by buster. 07/23/19 03:47 PM
Lower octane at higher altitude...
by ZZman. 07/23/19 03:43 PM
vegafelisa, Keith_PDX, Dogeye59, skidmarkart, SJeP
68749 Registered Users
22 registered members (CleverUserName, EricBeau, deoxy4, alcyon, Brad_C, 53' Stude, 3 invisible), 685 guests, and 21 spiders.
Topics292,294
Posts5,020,622
Members68,749
Most Online2,967
Mar 10th, 2019
2012 chevy equinox with 121,xxxx #5138971
06/20/19 06:31 AM
06/20/19 06:31 AM
AZ
Robw Offline OP
Robw  Offline OP
AZ
Ok so i keep getting code to change purge valve, I did it twice!!! Still on!! Then bank one sensor, still on! It keeps pushing the pcv hose out of the air intake, took oil cap off has blow by.... im confused on what could be going on here... but it loses oil when the pcv hose pops off of course.... any help suggestions etc. Would be great...thank-you
Re: 2012 chevy equinox with 121,xxxx [Re: Robw] #5139018
06/20/19 07:45 AM
06/20/19 07:45 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
does it have a PCV valve or just an orifice?
You mentioned the PCV air IN from the AF but not PCV to throttle body or manifold.
Look for blockages in the plumbing and TB.
Taking off the oil cap doesnt generally tell you if you have blowby,. Thats the crank case volume change do to piston movement above the oil pan.
What engine? LF1 sixer or LEA 4 banger?
2019 VW Jetta S 6MT OCI#0 5033mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#7 52665mi-Castrol GTX Magnatec 5W20 + SOA Filter
Re: 2012 chevy equinox with 121,xxxx [Re: Robw] #5139023
06/20/19 07:59 AM
06/20/19 07:59 AM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
You need further diagnosis. There is no code to change the purge valve, only out of normal parameter codes.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
Re: 2012 chevy equinox with 121,xxxx [Re: Robw] #5139024
06/20/19 08:00 AM
06/20/19 08:00 AM
WA
Mad_Hatter Offline
Mad_Hatter  Offline
WA
Assuming your egr solenoid is clicking, check for vacuum leaks and/or bad fuel tank pressure sensor. Make sure your gas cap closes tight. If your egr is opening and closing with the new valve, you can probably rule out a bad solenoid and control circuit. I'd say it's a pressure issue. Otherwise check the wiring harness and control circuit voltage.
If your pcv is held in just by a grommet like on my old Camry, it's either plugged or you got really bad blow by. If the pcv screws in like my current car, I'm not sure what to make of it. Is the hose coming off the pcv going to the intake just popping out/off of the intake fitting??? Maybe it's just a bad angle and you need a [better] clamp on it.
Re: 2012 chevy equinox with 121,xxxx [Re: ARCOgraphite] #5139087
06/20/19 09:27 AM
06/20/19 09:27 AM
AZ
Robw Offline OP
Robw  Offline OP
AZ
4 banger!... the pvc is in the head cover
Re: 2012 chevy equinox with 121,xxxx [Re: Mad_Hatter] #5139088
06/20/19 09:30 AM
06/20/19 09:30 AM
AZ
Robw Offline OP
Robw  Offline OP
AZ
Ya know its not the factory gas cap, the previous owner replaced it and it say turn to one click but it always clicks two or more or if you do it softly it doesnt give it a full click...
Re: 2012 chevy equinox with 121,xxxx [Re: Mad_Hatter] #5139091
06/20/19 09:31 AM
06/20/19 09:31 AM
AZ
Robw Offline OP
Robw  Offline OP
AZ
And it pops off where you click it into the intake
Re: 2012 chevy equinox with 121,xxxx [Re: Robw] #5139166
06/20/19 11:33 AM
06/20/19 11:33 AM
WA
Mad_Hatter Offline
Mad_Hatter  Offline
WA
What are the codes you're getting?
Re: 2012 chevy equinox with 121,xxxx [Re: Robw] #5139204
06/20/19 12:33 PM
06/20/19 12:33 PM
CA
The Critic Offline
The Critic  Offline
CA
https://www.equinoxforum.net/18-faq...alve-causing-rear-main-seal-failure.html
Take care of this asap before it blows the rear main seal as well.
2011 Toyota Prius 1.8L - 193K - Idemitsu ZEPRO Adv. Moly 0W-20
2007 Honda Accord 2.4 - 137K - Mobil 1 EP HM 5W-30
Re: 2012 chevy equinox with 121,xxxx [Re: Mad_Hatter] #5139216
06/20/19 12:55 PM
06/20/19 12:55 PM
AZ
Robw Offline OP
Robw  Offline OP
AZ
P0013 and p0442 like I said though, I changed the purge and bank 1 sensor
Re: 2012 chevy equinox with 121,xxxx [Re: Robw] #5139256
06/20/19 01:40 PM
06/20/19 01:40 PM
WA
Mad_Hatter Offline
Mad_Hatter  Offline
WA
Well you know the codes so use Google to find what are the common causes for the EVAP DTC's and roll up your sleeves and get to work. Otherwise take it into a shop.
Start with that gas cap...
Re: 2012 chevy equinox with 121,xxxx [Re: Robw] #5140255
06/21/19 03:51 PM
06/21/19 03:51 PM
Iowa City
Talent_Keyhole Offline
Iowa City
Sounds like you have multiple problems. The most urgent is your crankcase pressure that is building up and forcing the PCV vent tube to become dislodged. The PCV oriffice in the head is likely clogged. There is GM Technical Service Bulletin on this. Go to the Equinox forum for advice. I have 2012 Equinox, 2.4L and I am aware of this problem.
