Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
Flank drive wrenches
by spasm3 - 01/24/20 08:39 PM
Auto assembly and mfg. logistics
by P10crew - 01/24/20 08:26 PM
Kodiak
by P10crew - 01/24/20 08:05 PM
yet another black eye for the 2,4 ecotec
by super20dan - 01/24/20 07:52 PM
New incentive for 0w20
by Snagglefoot - 01/24/20 06:43 PM
2020 Kia Forte Engine
by artbuc - 01/24/20 03:27 PM
Torn filter that's NOT a motorcraft.
by mpgo4th - 01/24/20 03:22 PM
K&N PS-1008 $3.36
by jayjr1105 - 01/24/20 03:14 PM
Forum notifications?
by jayjr1105 - 01/24/20 02:50 PM
Thinking about transmission cooler for Honda
by jayjr1105 - 01/24/20 02:26 PM
Goodyear Assurance Comfortred Touring
by Keystone - 01/24/20 02:03 PM
Honda Pilot OCI - Pennzoil Platinum
by Skier - 01/24/20 12:48 PM
Pete44, Connie7, 2020XT, 4strokes, Perseus
70518 Registered Users
86 registered members (14Accent, 2strokeNorthstar, afaisalkk, 4WD, 2010Civic, 9 invisible), 2,484 guests, and 15 spiders.
Topics300,511
Posts5,177,508
Members70,518
Page 1 of 3 1 2 3
2006 Camry 4 cyl. 15,000 miles on M1 5W-30 #5138478 06/19/19 01:29 PM
Deontologist Offline OP
Ran 15,000 miles on M1 HM 5W30 with a M1 filter. The oil dipped low at least once. Low as in not even present on the dipstick. Has had at least 1.5 to 2 quarts of makeup oil added. Ran entire time with leaky air filter box. Water is probably present from me not really heating up the car before sampling. I ran the car for maybe 30 seconds to get it into the garage.
https://www.bobistheoilguy.com/foru...-think-my-uoa-will-look-like#Post5127339
In any case, after I pulled the drain plug and sampled the oil, I put the old oil back in. Looks like I made the right call, the oil still has some life left!
Re: 2006 Camry 4 cyl. 15,000 miles on M1 5W-30 [Re: Deontologist] #5138487 06/19/19 01:46 PM
53' Stude Offline
Looks like time for engine work or engine replacement. That iron and aluminum # is nuts. My 09' with 153K wasn't even that bad with M1 10w40HM SL rated lube
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: 2006 Camry 4 cyl. 15,000 miles on M1 5W-30 [Re: Deontologist] #5138500 06/19/19 02:10 PM
E
Eddie Offline
E
The iron and Aluminum are wear metals and are quite high, which suggest much wear. I'd try a shorter OCI.. Ed
2014 CX5 Touring 2.5L :-)
Re: 2006 Camry 4 cyl. 15,000 miles on M1 5W-30 [Re: Deontologist] #5138501 06/19/19 02:11 PM
Was Wix blowing smoke up my ahem with their positive comments?
Re: 2006 Camry 4 cyl. 15,000 miles on M1 5W-30 [Re: 53' Stude] #5138503 06/19/19 02:15 PM
T
TmanP Offline
T
Yeah, I'd not be happy with that report if it was mine. I'd fix the leak in the air box, then change the oil (for sure!) and monitor the level more closely (so it doesn't ever drop off the dipstick). Until I got a better report, I'd not run the oil over 10k.
2012 Toyota Camry 2.5 60,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 50,000 mi
2010 Toyota Sienna 3.5 V6 200,000 mi
Re: 2006 Camry 4 cyl. 15,000 miles on M1 5W-30 [Re: Deontologist] #5138519 06/19/19 02:25 PM
Cujet Offline
That oil has no life left. Next time change it at 7500.
There are some on this forum that believe the wear rate decreases when oil is not changed. Nothing could be further from the truth. The more miles accumulated, the higher the wear causing particulates, and the more the oil is contaminated with combustion byproducts. Significantly diluting the oil with evaporated gasoline by products.
It is my opinion that UOA results do not track engine wear rates. UOA results are good for trend changes and will indicate a problem when major changes occur. Note: Those trend changes can be universal averages or your averages.
I worked for Mobil Oil in a past life. We tested various products and the associated wear rates. Wear measurement was done by scanning electron microscope.
I fail to understand how "high iron" can indicate a universal wear rate. As the iron may not be associated with any worn internal engine parts, and may in fact come from a balancer chain or a mechanically driven fuel pump.
Some people automatically associate "high iron" with cylinder wear. Without disassembly, there is no way to know that the iron you see in the UOA sample came from ALL the parts or just one of the parts such as the cylinders, camshaft, crankshaft, lifters, timing chain, fuel pump, oil pump, rocker arms, pushrods, and on and on.
Re: 2006 Camry 4 cyl. 15,000 miles on M1 5W-30 [Re: Cujet] #5138566 06/19/19 02:58 PM
L
LotI Offline
L
Agreed. UOA’s tell you the health of the oil, not the engine.
I would change the oil and reduce the OCI. You think an extra $25 of oil is worth a $3000 engine? Oil is cheap.
I think WIX sees 100ppm as condemning to the lube, so the OP’s oil is fine duh
And why didn’t they perform a KV100 test?
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX http://www.fuelly.com/car/buick/regal_tourx/2019/loti/943992
Re: 2006 Camry 4 cyl. 15,000 miles on M1 5W-30 [Re: Deontologist] #5138577 06/19/19 03:17 PM
J
JustinH Offline
J
I think you would get better results with quick lube bulk oil at 5k intervals than what we are seeing here.
Also a new air filter.
'16 Ford Escape
'11 Scion XB
Re: 2006 Camry 4 cyl. 15,000 miles on M1 5W-30 [Re: Cujet] #5138590 06/19/19 03:32 PM
K
Kjmack Offline
K
Thanks for a common sense answer , lots of crap slung around here . You laid it out correctly and honestly
Re: 2006 Camry 4 cyl. 15,000 miles on M1 5W-30 [Re: LotI] #5138594 06/19/19 03:41 PM
53' Stude Offline
For cripes sake, why in heavens name would I run a test on maybe 1/8th quart of burned, used oil??!
161,669 miles
Re: 2006 Camry 4 cyl. 15,000 miles on M1 5W-30 [Re: Deontologist] #5138656 06/19/19 05:12 PM
J
JAG Offline
J
I think it’s never a good idea to drain all of the oil just to get a sample and then pour it back in the engine. Especially considering the very long OCI and the leaky air filter box, it was not a good idea. I would drain and fill with new oil. Iron at 85 and aluminum at 27 PPM is pretty high, even for 15k miles. I suspect abrasives are the main cause of that more so than degraded oil chemistry or viscometric changes, but that’s just an educated guess.
Re: 2006 Camry 4 cyl. 15,000 miles on M1 5W-30 [Re: JAG] #5138663 06/19/19 05:23 PM
53' Stude Offline
Yeah...... engine is probably going south faster than a freight train
161,669 miles
Re: 2006 Camry 4 cyl. 15,000 miles on M1 5W-30 [Re: Deontologist] #5138681 06/19/19 05:45 PM
This was my parent's car and no one has any use for it anymore. I was about to put some bar and chain oil in the car after sampling, but I decided to just pour the old oil back. This car isn't getting another oil change unless the oil is free. I did the UOA out of intellectual curiosity. As far as they're concerned the car could disappear tomorrow and it wouldn't matter one bit.
I'm also a little suspect of people who say this engine is going to blow. For the last 2000 miles, I've been redlining the engine with nary an odd sound. I'm talking dropping the thing in 2nd on the freeway and pushing it to 5k rpms. I've bounced off redline countless times and nothing happened.
Re: 2006 Camry 4 cyl. 15,000 miles on M1 5W-30 [Re: Deontologist] #5138695 06/19/19 06:01 PM
R
RayCJ Offline
R
Iron at 85 and Aluminum at 27 inside of 15,000 miles.... I'm pretty sure that's the highest iron reading per 1000 miles I've ever seen here. Is there any chance sample got contaminated with iron filings?
Just out of curiosity, how did you capture the oil for the sample?
If that were my UOA, I'd change the oil/filter immediately, drive it for 1000 miles and do a simple UOA (no TBN). If it comes back with more than 2ppm FE per 1000 miles, I'd either get rid of it or make a decision to diagnose the damage and possibly fix it.
Ray
Re: 2006 Camry 4 cyl. 15,000 miles on M1 5W-30 [Re: RayCJ] #5138703 06/19/19 06:09 PM
I captured the oil midstream after pulling the drain plug. I didn't see anything shiny or metallic in the oil I drained out.
Page 1 of 3 1 2 3
