Serpentine Belt Change
by Propflux01 - 12/15/19 08:59 PM
QS HM 10W-40
by kstanf150 - 12/15/19 08:29 PM
4.5" Angle Grinder
by TheLawnRanger - 12/15/19 07:51 PM
Cooper CS5 Ultra Touring
by Warstud - 12/15/19 07:39 PM
Highway power loss
by HyundaiAbuser - 12/15/19 07:21 PM
General truck tires
by spasm3 - 12/15/19 07:18 PM
Alternative uses for CVT fluid?
by stroo - 12/15/19 05:57 PM
CANbus mileage editor
by cwilliamsws6 - 12/15/19 05:56 PM
Fed ex
by Chris142 - 12/15/19 05:53 PM
New oil treatment from Colgin
by qball16 - 12/15/19 05:36 PM
Discount Tire Direct $80 Flash Sale
by BePrepared - 12/15/19 05:16 PM
Bleed and refill?
by cwilliamsws6 - 12/15/19 04:19 PM
Pies: which ones do you love?
by 53' Stude - 12/15/19 02:32 PM
Honda Ridgeline ZF 9 Speed
by dakota99 - 12/15/19 12:02 PM
Selling my dump trailer
by Sunnyinhollister - 12/15/19 11:43 AM
Motorcraft 5W-20 canada
by xXF150Xx - 12/15/19 11:40 AM
Brake caliper pins
by Donald - 12/15/19 11:14 AM
Now this is a good job.....
by ZZman - 12/15/19 09:26 AM
Polish snow plow
by P10crew - 12/15/19 08:53 AM
bjonga, theman5142, 750IX, Tzam, tjl5709
70138 Registered Users
74 registered members (77GrandPrix, 69Torino, Aero540T, AndyB, 7 invisible), 1,569 guests, and 22 spiders.
Topics298,849
Posts5,142,582
Members70,138
Most Online3,589
Nov 2nd, 2019
LS Diff gear oil #5138205 06/19/19 06:55 AM
W
WyrTwister Offline OP
W
Any problem if you uae a diff gear lube with LS addative in a non LS diff ?
Thanks , :-)
Wyr
God bless
Re: LS Diff gear oil [Re: WyrTwister] #5138230 06/19/19 07:22 AM
T
The_Nuke Offline
T
yes
Last edited by Kestas; 06/19/19 09:02 AM. Reason: no need to completely quote the first post in the second post
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 2.65 (215mm)
Re: LS Diff gear oil [Re: WyrTwister] #5138232 06/19/19 07:24 AM
A
ARCOgraphite Offline
A
I would think NO problem. Its just a FM for the clutch pack. Everything else is the same.
But Friends don't let friends use Mobil 1 LS diff fluid.
MAybe we can hear from someone who used LS fluid in an open differential.
Again, I see no problem.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: LS Diff gear oil [Re: The_Nuke] #5138245 06/19/19 07:34 AM
K
Kamele0N Offline
K
Originally Posted by The_Nuke
Thanks , :-)
yes
No...!!!
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: LS Diff gear oil [Re: WyrTwister] #5138253 06/19/19 07:41 AM
Char Baby Offline
No problems at all. I do it all the time. Not only in the Firebird in my signature(no LS/no Posi) and in my wife's previous Lexus AWD.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: LS Diff gear oil [Re: WyrTwister] #5138257 06/19/19 07:45 AM
Astro14 Offline
No problems.
As far as Mobil 1 with the LS additive?
Well, I ran it exclusively in my old, non LS, Toyota 4 Runner. Which saw off roading, Vermont winters, and is still on the road with 300,000 miles, and its original front and rear differentials, with their original seals.
So, I’m going to say that particular product works just fine in a non LS differential.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: LS Diff gear oil [Re: WyrTwister] #5138267 06/19/19 07:54 AM
R
RamFan Offline
R
No issues at all.
18 Giulia Ti Sport Q4
  • 2.0T I4 - 20k - PP Euro LX 0w30 - PureOne - 10k/1yr
16.5 CX-5 Touring AWD
  • 2.5L I4 - 66k - Castrol Edge EP 0w20 - Denso - 7.5k/1yr
Re: LS Diff gear oil [Re: WyrTwister] #5138297 06/19/19 08:40 AM
R
Rand Offline
R
Thanks , :-)
No issues.
Re: LS Diff gear oil [Re: Rand] #5138350 06/19/19 10:10 AM
DuckRyder Offline
Non-LS meaning an open diff, no no problems (I suspect this is what you mean). I’ve also run M1 - LS in multiple open diffs with no issues.
If the Non-LS is some sort of locking or torque biasing diff then there could be issues depending on the specifics. (Generally folks use “LS” as a sort of all encompassing terms, but that isn’t always technically correct)
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: LS Diff gear oil [Re: WyrTwister] #5138356 06/19/19 10:19 AM
B
beanoil Offline
B
No.
Agree that friends don't let friends use M1.
I like Schaeffer.
Schaeffer
" Extreme Performance Full Synthetic can be used in heavy-duty or high performance transmissions, aftermarket 5-speed and 6-speed separate motorcycle transmissions and final drives, including standard and limited-slip differentials and shaft drive transmissions requiring the use of an hypoid type gear oil."
Re: LS Diff gear oil [Re: WyrTwister] #5138378 06/19/19 10:54 AM
O
oldhp Offline
O
How could there be one??? Same ring & pinion, same seals, same axle seals. The only difference is the ring gear carrier. One has spider gears (open) and the other has clutch packs (posi).
I use RedLine gear oil.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: LS Diff gear oil [Re: WyrTwister] #5138384 06/19/19 11:10 AM
gathermewool Offline
Why are some of you saying “no”!?
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19)
15 Legacy Premium FB25
Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
Re: LS Diff gear oil [Re: WyrTwister] #5138385 06/19/19 11:15 AM
4WD Offline
Did M1 in G80’s for 20 years before switching to Delvac 1 …
Re: LS Diff gear oil [Re: WyrTwister] #5138445 06/19/19 12:40 PM
Sam_Julier Offline
I have used various grades of 80W90 conventional with LS additive in both 240s. (Dana 1031 axle.)
330,000 miles total between the two cars. No issues at all.
Sam
2013 Toyota Avalon Hybrid TGMO 0W20, 81k
1993 Volvo 245 T5 10W30, 168k
1993 Volvo 244 T5 10W30, 177k
Re: LS Diff gear oil [Re: gathermewool] #5138552 06/19/19 02:48 PM
L
LotI Offline
L
Because the question asked by the OP was “Any problem using LS in a non-LS application?”
The answer is ‘no’
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX http://www.fuelly.com/car/buick/regal_tourx/2019/loti/943992
