Originally Posted by Jethro_Bob
Originally Posted by philipp10
Ok I'm going to play devils advocate here. I have 3 cars, a 2007, 2008 and a 2010....so all are fairly old. None have ever been serviced. All three still cool decently but far from ice cold. I'm going under the assumption that all basically don't have a gross leak since they all cool. But as we all know, every system leaks some and at 10 years old, they are all probably a bit low on coolant. So what's wrong with going the shade tree hack and adding just a few ounces each. If they improve, probably just stop there. What's the worst that can happen? I end up in the garage for a service?
Where I live, shops advertise the hack job for $39.99, a 15oz can of 134a is about $5 retail. It take all of five minutes to put a hose on the low pressure side and guess with a non temperature compensated gauge. Best case scenario, your paying $400 an hour to improperly repair your car. Worse case, he used stop leak, your compressor fails and a $90 job becomes a $2000 system replacement.
This is why the top off cans with gauge are so handy.
If you have auto history & know it's been neglected & you can read instructions,
you can fire up the A/C system & load it & note performance improvement.
You'll actually be more careful than the service guy with eight vehicles stacked up behind yours.
