JHZR2
Staff member
I buy concentrate and distilled water so it's easy enough for me to make my own mix. I usually do.
It's reasonable to expect vastly different concentrations in there for a bit. Pour the two together and you definitely see striations (you can make them out in the attached pic) that don't go away by themselves. I don't know enough about how the water flows through, but it's reasonable to assume that the slugs of liquid in the hoses stay in relatively consistent concentrations there. If that's also the case in the radiator too, I can see it taking some time to fully mix.
But to get maximum heat transfer, surely they want turbulent flow in the heat exchange surfaces. As a result, there will always be some front-back mixing.
The wild card is if flow is turbulent in the engine but slows and becomes more laminar in the radiator. I'd suspect that could effect mixing.
But in the end it will mix. I'd lose no sleep.
But if I was filling a car that was going to sit for a while and not be readily used, I'd probably pre-mix just
To be double sure the inhibitor concentration was right everywhere.
Best practice but not always critical.
