Older fram ultra
by tblt44 - 10/19/19 08:42 PM
Best price on Colt 9MM pattern mags?
by GumbyJarvis - 10/19/19 08:20 PM
Using a trim router for cutting sheetrock
by JLawrence08648 - 10/19/19 08:09 PM
C&P of a Tough Guard w/50,000 miles to be posted soon
by MrQuackers - 10/19/19 08:04 PM
Chevy dealer, 7 free oil changes?
by Zacc - 10/19/19 07:34 PM
School me..1200 amp jumper
by Schmoe - 10/19/19 07:19 PM
YouTube Finish Test
by RayCJ - 10/19/19 07:09 PM
Overfilled, drained some, still too full?
by OCDriver - 10/19/19 06:16 PM
Wix made in Korea?
by JGmazda - 10/19/19 06:01 PM
Oil change interval question
by SkipCam - 10/19/19 05:49 PM
Remove Spark Plug Wires
by borgward - 10/19/19 04:53 PM
Pinion yoke loose, is the bearing ruined?
by Fsharp - 10/19/19 03:45 PM
Need tires for the mustang
by BeerCan - 10/19/19 03:24 PM
No sign of of oil sample at BStone :(
by 21Rouge - 10/19/19 02:45 PM
Carpet Shopping - Need Advice
by The Critic - 10/19/19 02:17 PM
Local Autozone clearance
by Soggydog - 10/19/19 02:05 PM
Two Fumoto valves
by otis24 - 10/19/19 01:17 PM
Going in the engine today!
by domer10 - 10/19/19 01:15 PM
GM 4WD rubbing/grinding after 4Lo
by HawkeyeScott - 10/19/19 12:52 PM
Choosing a new phone
by ram_man - 10/19/19 12:28 PM
Hallj49803, Tralever, Jhams, gmguy57, jamie24874
69612 Registered Users
81 registered members (aquariuscsm, bbhero, 4WD, AdditiveOCD, 2015_PSD, ammolab, 6 invisible), 1,644 guests, and 21 spiders.
Topics296,195
Posts5,093,271
Members69,612
Most Online3,532
Jul 30th, 2019
Particle Count (PC) testing of used oil #5137437 06/18/19 11:25 AM
T
Talent_Keyhole Offline OP
T
Which labs will do particle count testing of used motor oil? Not talking about diesel oil, just regular motor oil.
Polaris Labs says it will damage their delicate instruments, and the dark color will not allow a result to be given. Even the attached oil sample, they will not test, because it was once in an engine regardless of time.
Re: Particle Count (PC) testing of used oil [Re: Talent_Keyhole] #5137451 06/18/19 11:37 AM
shanneba Offline
Blackstone does particle counts on used oil.
The price list says $25 but if they do a standard analysis on the same sample the PC is only an additional $15.
2003 BMW 330Ci
2013 HD Sportster XL1200C
Re: Particle Count (PC) testing of used oil [Re: Talent_Keyhole] #5137483 06/18/19 12:10 PM
F
FlyNavyP3 Offline
F
If you use a CAT SOS oil sample and submit it as a transmission, differential, or hydraulic sample they will automatically do a PC analysis as part of the test at no additional cost. I've done this a few times already. The only thing you don't get is TBN.
Luke
Re: Particle Count (PC) testing of used oil [Re: shanneba] #5137513 06/18/19 12:53 PM
T
T
If they start offering GC Fuel Dilution, I would be fully on-board. Not going to pay two different labs to get accurate fuel dilution and particle count.
Re: Particle Count (PC) testing of used oil [Re: Talent_Keyhole] #5137690 06/18/19 04:15 PM
CourierDriver Offline
I know oil analysis is a big deal, but I have never lost an engine do to oil ....
Whatever genes we may have inherited,what we eat can affect how those genes affect our health-The power is mainly in our hands and on our plates.
Re: Particle Count (PC) testing of used oil [Re: CourierDriver] #5138275 06/19/19 09:07 AM
T
T
Catastrophic, sudden, mechanic engine failures are rarely identified beforehand by oil analysis and normally not caused by oil. In that sense I agree. Have engines experienced shortened life span, severe wear from wrong viscosity, over-filling, poor quality oil, severe contamination, sure. Most people do not keep their vehicles long enough for an engine failure or be able to ascertain a shortened life span. There have been a few cases where junk oil (API SA) and even used oil has been re-bottled and sold on the market. In those cases damage was caused by the oil alone.
Re: Particle Count (PC) testing of used oil [Re: Talent_Keyhole] #5138965 06/20/19 06:21 AM
dnewton3 Offline
Global Moderator
Global Moderator
I, too, have never lost an engine due to oil failure, or a filter failure for that matter.
But that does not stop me from doing UOAs. Because UOAs have more than one purpose.
UOAs can, but will not always, predict a component failure. There a lot of "what if ..." scenarios here; too many to make a blanket statement other than to say UOAs can see some instances of imminent failure, but not all.
UOAs are first and foremost a fiscal savings too, although you'd not really know it given how BITOGer use them as toys. UOAs are most effective at deciphering wear trends, and then using that knowledge to set reasonable OCI cycles. If the UOA shows good wear, low contamination and decent physical properties, then you should extend the OCIs out. You do that in a continued fashion until you reach some condemnation point. Why do an OCI at 5k miles if all is good at 10k miles? Why OCI at 10k miles if all is good at 15k miles? In large sump systems, you can often see OCIs go 30k to 100k miles (typically in OTR trucks).
There is a caveat; UOAs can cost as much or more than an OFCI at times, so the ROI really isn't great, especially on small sump systems. Why pay $32 for a UOA for you 2-qrt riding mower? Why pay $28 for a UOA when $25 will fill your sump? In these circumstances, I advocate for UOAs to establish a mantra, then cease the UOAs until an issue is suspected. For example, I used UOA data to prove that 10k mile OFCIs are safe for our 4.6L Ford engines; the data repeatedly shows no ill effects. After establishing the safe trend, I then stopped the UOAs. I will only get another UOA if I see something go awry; smell of fuel in the oil, appearance of coolant in the oil, audible noises that would indicate mechanical issues, etc.
PCs are also a tool. They have benefits, but also limitations. They help you understand particulate loading, but they don't speak a word to the substances found. PCs tell you about loading, but UOAs tell you about elements. PCs will tell you how large something is, in a delineated scale of concentration. UOAs will tell you the composition of the element, but not size.
The better way to manage a maintenance program is to use the tools (PCs, UOAs, physical observations) together, and understand the pros/cons of each tool used in concert with each other.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Particle Count (PC) testing of used oil [Re: dnewton3] #5139416 06/20/19 05:19 PM
M
Mad_Hatter Offline
M
Well said..đź‘Ť
Re: Particle Count (PC) testing of used oil [Re: Talent_Keyhole] #5140480 06/21/19 09:36 PM
SubieRubyRoo Offline
TestOil includes PCs in its standard battery of tests, but there are some caveats: 1. No “universal averages” to compare to. 2. If you already have shell shock from Blackstone’s prices, well... it’s around $48 for the VOAs with PCs that I posted from TestOil.
You really gotta have a hankering to see the data at that price, IMO. If you’ve got a Rural King nearby, $48 is essentially 3 full synthetic Warren Oil changes and PrimeGuard or EcoGuard filters, with tax!
