Monroe made in Turkey
by atikovi - 02/18/20 03:31 PM
NSFBitog
by Ursatdx - 02/18/20 03:25 PM
Wider rear tires?
by drop - 02/18/20 03:07 PM
ROCKAUTO Coupon Codes
by jrvn - 02/18/20 02:24 PM
Gold (brass?) flecks in drained Honda ATF
by TNM6i - 02/18/20 12:10 PM
What happened to licensed ATF clones?
by TimN3QE - 02/18/20 12:08 PM
E85 in non-flex fuel Ford Expy ~2013
by DriveHard - 02/18/20 11:46 AM
Jacking up a car by itself
by Alfred_B - 02/18/20 11:44 AM
Valvoline MST in 2015 Macan S
by musclecarscott - 02/18/20 11:43 AM
PH10060 oversized?
by bullwinkle - 02/18/20 11:36 AM
Toyota Sienna
by cb_13 - 02/18/20 10:05 AM
Larger fuel filter on Riding mower?
by dedonderosa - 02/18/20 10:03 AM
Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
spbonus, mtnwzrd11, TnTA2, TimN3QE, musclecarscott
70742 Registered Users
102 registered members (762fermeandyou, atikovi, 53' Stude, ArrestMeRedZ, andreigbs, 11 invisible), 2,295 guests, and 19 spiders.
Topics301,615
Posts5,199,172
Members70,742
crank and water pump pulleys stuck #5136358 06/17/19 06:50 AM
slybunda Offline OP
so changing the waterpump and doing timing belt too iv hit a snag where the water pump pulley is stuck to the pump even though iv removed the bolts that hold the pulley on. same with the crank pulley iv got the crank pulley bolt off but the pulley is still stuck on and pulling it doesnt seem to get it loose. any ideas on what i can do?
pics attached.
1995 Ford Fiesta 1.6i 16v Si
2000 Toyota Celica 1.8 VVTL-i
2007 Toyota Aygo+ 1.0i
Re: crank and water pump pulleys stuck [Re: slybunda] #5136366 06/17/19 07:08 AM
Dave Sherman Offline
If the pulleys are keyed (the crank appears to be), then maybe it's just a close fit. A three-armed puller would probably persuade them off. Be careful, it shouldn't take a lot of tension. If you find you're having to really crank on the puller bolt, STOP or you may bend the pulley. Ask me how I know. Other pulleys may be press fit on, and need a puller that grips the pulley hub.
2015 Honda Pilot EX AWD Pennzoil Platinum 0W-20 STP filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: crank and water pump pulleys stuck [Re: slybunda] #5136384 06/17/19 07:37 AM
slybunda Offline OP
Will try some penetrating oil. Those pullies last came off 13 years ago
Re: crank and water pump pulleys stuck [Re: slybunda] #5136542 06/17/19 11:17 AM
DoubleWasp Offline
Try SOFT taps with a heavy hammer. Alternate positions to make it rock a little each tap.
Re: crank and water pump pulleys stuck [Re: slybunda] #5136562 06/17/19 11:38 AM
B
bullwinkle Offline
B
Combine the 2 tips above-the tapping motion will help the penetrating oil get into the pulley bore and will help it work loose.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: crank and water pump pulleys stuck [Re: slybunda] #5136628 06/17/19 12:43 PM
slybunda Offline OP
awsome i will give that a go tomorrow. i just went out now and soaked it again in penetrating fluid.
Re: crank and water pump pulleys stuck [Re: slybunda] #5137193 06/18/19 02:31 AM
slybunda Offline OP
crank pulley came off, did as advised above, penetrating oil then rubber hammer and its off.
water pump pulley is still stuck on. iv doused it again with penetrating oil. will try again on it later.
Re: crank and water pump pulleys stuck [Re: slybunda] #5137349 06/18/19 08:10 AM
Silverado12 Offline
For future reference, I would take a pry bar and pry behind the pulley and hit the shaft with a hammer. Works every time and no chance of bending your pulley w/a puller.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: crank and water pump pulleys stuck [Re: slybunda] #5137356 06/18/19 08:25 AM
slybunda Offline OP
Thanks. Dunno what to do with waterpump pulley. I think the entire pump can come out with pulley attached. Will have to take the cam belt off first and the tensioner too.
Re: crank and water pump pulleys stuck [Re: slybunda] #5137389 06/18/19 09:20 AM
M
mk378 Online Content
Online Content
M
In many cases, the pulley is not intended to be removed in the field. The pump and pulley are a unit.
Re: crank and water pump pulleys stuck [Re: slybunda] #5137404 06/18/19 09:51 AM
slybunda Offline OP
The one on this car is supposed to be a removable pulley that then transfers over to the new pump.
Re: crank and water pump pulleys stuck [Re: slybunda] #5137468 06/18/19 10:54 AM
M
Online Content
M
If you can get it out of the car it will be much easier to remove.
It looks like now that you have the crank pulley off, the lower timing cover and the timing belt have to come off next to be able to unbolt the pump.
Re: crank and water pump pulleys stuck [Re: slybunda] #5138063 06/19/19 01:27 AM
slybunda Offline OP
yep next step take timing belt and its pullies off.
also the crank pulley is a bit rusty, is there any issues with wire brushing it and hitting it with some rust converter and a coat of paint? or is that not advised to do on it?
Re: crank and water pump pulleys stuck [Re: slybunda] #5139215 06/20/19 11:54 AM
slybunda Offline OP
took the belt off and the entire waterpump with pulley attached. also i think i solved the issue thats plagued me for over 3 years. constant high rpm driving causes engine temperature to rise. temperature drops back down if coasting in neutral or top gear is engaged:
new pump on and played it smart by pressure testing the system before fitting cam belt back on.
new belt has some slack between the camshaft pulleys, i have read i need a sprocket holding tool to loosen the sprockets and then tension the belt. so tool is now on order.
Re: crank and water pump pulleys stuck [Re: slybunda] #5139273 06/20/19 01:02 PM
cjcride Offline
Thanks for posting.
Is that the 2000 Celica?
