Older fram ultra
by tblt44 - 10/19/19 08:42 PM
Best price on Colt 9MM pattern mags?
by GumbyJarvis - 10/19/19 08:20 PM
Using a trim router for cutting sheetrock
by JLawrence08648 - 10/19/19 08:09 PM
C&P of a Tough Guard w/50,000 miles to be posted soon
by MrQuackers - 10/19/19 08:04 PM
Chevy dealer, 7 free oil changes?
by Zacc - 10/19/19 07:34 PM
School me..1200 amp jumper
by Schmoe - 10/19/19 07:19 PM
YouTube Finish Test
by RayCJ - 10/19/19 07:09 PM
Overfilled, drained some, still too full?
by OCDriver - 10/19/19 06:16 PM
Wix made in Korea?
by JGmazda - 10/19/19 06:01 PM
Oil change interval question
by SkipCam - 10/19/19 05:49 PM
Remove Spark Plug Wires
by borgward - 10/19/19 04:53 PM
Pinion yoke loose, is the bearing ruined?
by Fsharp - 10/19/19 03:45 PM
Need tires for the mustang
by BeerCan - 10/19/19 03:24 PM
No sign of of oil sample at BStone :(
by 21Rouge - 10/19/19 02:45 PM
Carpet Shopping - Need Advice
by The Critic - 10/19/19 02:17 PM
Local Autozone clearance
by Soggydog - 10/19/19 02:05 PM
Two Fumoto valves
by otis24 - 10/19/19 01:17 PM
Going in the engine today!
by domer10 - 10/19/19 01:15 PM
GM 4WD rubbing/grinding after 4Lo
by HawkeyeScott - 10/19/19 12:52 PM
Choosing a new phone
by ram_man - 10/19/19 12:28 PM
Hallj49803, Tralever, Jhams, gmguy57, jamie24874
69612 Registered Users
80 registered members (4WD, bbhero, aquariuscsm, AdditiveOCD, 2015_PSD, ammolab, 7 invisible), 1,667 guests, and 24 spiders.
Topics296,195
Posts5,093,281
Members69,612
Most Online3,532
Jul 30th, 2019
Why such a low temp thermostat? #5137152 06/17/19 11:21 PM
Chris142 Online Content OP
OP Online Content
My tractor calls for a 150F thermostat. I had a 160 so I put that in. Wouldn't a 180 be a better choice? A 195F is too close to the boiling point IMO.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Why such a low temp thermostat? [Re: Chris142] #5137172 06/18/19 12:21 AM
M
maxdustington Offline
M
Pre-emissions and less airflow through the rad than an automobile?
97 GMC RCLB K2500LD L30/4L60
Re: Why such a low temp thermostat? [Re: Chris142] #5137210 06/18/19 04:44 AM
P
Popsy Offline
P
My old diesel with aluminium head, mostly pre-emission, got a 160° from factory, along with an oil cooler, same cars with gas engines got a regular 190°, I always thought it was to keep the oil temperature fairly low (the turbo is oil cooled), because oils of that era didn't like high heat much, but maybe it was a naive thought.
96 Barchetta, 300V 5W40 | Forfour 95, M1 0W40
Mazda 6 2.3, Castrol 0W30 | Colt Ralliart, 300V 5W40
Re: Why such a low temp thermostat? [Re: maxdustington] #5137244 06/18/19 05:59 AM
T
Tman220 Offline
T
Pre-emissions is the key. Has nothing to do with airflow, in fact this is one of those things a lot of people get confused about. Assuming equal airflow a radiator is far more efficient when filled with 200 degree coolant vs. 160 degree coolant. Far more temp differential.
2012 Regal GS Turbo PP 5w30 90k
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30 165k
2005 GMC Sierra 1500 5.3 160k
2004 Civic LX M5 178k
2007 Camry 2.4 232k
2016 Victory Vegas
Re: Why such a low temp thermostat? [Re: maxdustington] #5137271 06/18/19 07:07 AM
OP Online Content
It has a solid mounted fan that blows like a hurricane.
Reason I bring this up is because the top end is pretty dirty. I assume from the oil not getting hot enough to evaporate the moisture. Also. No pcv system, just a vented cap.
I blocked part of the radiator last night and let it run about 185F for about an hour.
Re: Why such a low temp thermostat? [Re: Chris142] #5137282 06/18/19 07:16 AM
K
Kruse Offline
K
First, your radiator is a non-pressurized system and, from the factory, was designed for water only. Back then, the tight-wad farmers didn't add antifreeze. If they did, it was alcohol-based, which had a low boiling point. During the cold winter in all places except California, the water was usually drained every night. Also, your gas tank sits very close to your engine. They didn't want the gas to vaporize because it was so close to the hot block.
A couple of weeks ago, I drove my Oliver 70 about 10 miles in 90° weather. (Google for a photo of an Oliver 70. From the factory, it had enclosed tin around the engine) Now gas is different than it was back in 1938 when it was built, but my tractor did experience vapor lock the final two miles of driving. Your 180° MIGHT work, unless your are plowing the back 40 in high temperatures.
Re: Why such a low temp thermostat? [Re: Tman220] #5137292 06/18/19 07:42 AM
W
WyrTwister Offline
W
Yes , greater delta T . Assuming constant / consistent ambient temperature .
Wyr
God bless
Re: Why such a low temp thermostat? [Re: Chris142] #5137298 06/18/19 07:53 AM
R
ragtoplvr Offline
R
Your tractor was designed for that temperature thermostat. Going hotter is risky. Car engine operates at 10% load most of the time. When working a tractor engine is over 80% load, it is severe service. I had a old allis, I added a pvc system and oil vapor separator. The oil did stay cleaner. When mowing, it did get the oil hot enough to drive off the water, the catch can had to be drained every day. First day I must have drained a pint. Then it went down to about a ¼ cup.
Rod
Re: Why such a low temp thermostat? [Re: Kruse] #5137300 06/18/19 07:54 AM
OP Online Content
Actually it is pressurized! 4 psi! It is hot. 100+ is common.
Re: Why such a low temp thermostat? [Re: Chris142] #5137304 06/18/19 08:03 AM
M
mattwithcats Offline
M
Thermosiphon cooling system?
No water pump, just physics moving hot water up, cold water down...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Why such a low temp thermostat? [Re: mattwithcats] #5137316 06/18/19 08:27 AM
L
Linctex Offline
L
My 1949 Farmall "C" is Thermosiphon with a fan.
Later "Super C" engines got a water pump.
Re: Why such a low temp thermostat? [Re: mattwithcats] #5137353 06/18/19 09:19 AM
OP Online Content
Its not that old LOL! It has a belt driven water pump.
Re: Why such a low temp thermostat? [Re: Chris142] #5137482 06/18/19 12:10 PM
T
thastinger Offline
T
My 49 Farmall C doesn't have a water pump at all...but it has a helluva fan on it
My 68 JD 3020D rad was designed for water only or people would add alcohol to the water, alcohol evaporates at 173 degrees...hence the 150 thermo
