API 1509 Updated with New GF-6B Shield
by Solarent. 07/17/19 07:27 AM
Car Vac Recommendations
by klt1986. 07/17/19 07:05 AM
ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
Aother MEGA score+Free Mobil 1 oil change
by GMguy84. 07/17/19 12:39 AM
I think I need therapy...
by tony1679. 07/16/19 11:53 PM
Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
My new rig - 1987 Ford Econoline 27' Glendale RV
by caprice_2nv. 07/16/19 07:44 PM
Air Compressor OCI?
by Vern_in_IL. 07/16/19 07:35 PM
Looking for an SUV
by dgunay. 07/16/19 07:29 PM
Castrol GTX Magnatec 5w30
by Envoyguy. 07/16/19 07:21 PM
2019 Subaru Dual X-Mode
by buster. 07/16/19 06:36 PM
guru2019, MBhuntington, captainfloss, Lyndol, Belczek
68682 Registered Users
109 registered members (87sammy, Alfred_B, 4WD, AandPDan, 69GTX, 2010Civic, 9 invisible), 1,948 guests, and 23 spiders.
Topics291,979
Posts5,014,505
Members68,682
Most Online2,967
Mar 10th, 2019
2017 Silverado Front Bumper & Skid Plate?? #5137056
06/17/19 09:20 PM
06/17/19 09:20 PM
Wisconsin
Mr_Joe Offline OP
Mr_Joe  Offline OP
Wisconsin
I’m out West with my truck & while out on the prairie caught a hidden rock under the engine area. I was going slow & while backing off the front plastic(useless) bumper/air dam came off. I didn’t look closely, seems almost undamaged, besides getting torn off.
I was thinking, instead of putting this plastic back on, what is the procedure to track and install a REAL bumper? I’m not even talking a massive ‘cow-catcher’ type, just some midlin aftermarket front bumper.
While looking, my plastic skid plate got torn some. I think a metal one would be nice too, lower priority.
Just asking, I’ll snoop around the web some, maybe a local SE WI shop does the bumper sort of thing?
Re: 2017 Silverado Front Bumper & Skid Plate?? [Re: Mr_Joe] #5137092
06/17/19 10:03 PM
06/17/19 10:03 PM
Florida
MoultrieCreek Offline
Florida
My 2015 Silverado 1500 earns a living on rutted logging roads almost daily (forestry work). My air dam was removed and in a dumpster within the first hour I owned the truck... It wouldn't have lasted a week without being mangled. My truck looks completely normal without it (just a couple inches of extra clearance), although yours might be a little different since they changed the bumper shape in 2016 or 17. If/when my bumper ever gets damaged I'll upgrade to a Ranch Hand - I've seen a few up close and they look pretty solid.
A little known fact about this generation of GM is that all the 1/2 tons come with plastic "skid plates" for keeping water out of the engine compartment while splashing around. This includes the Z71's which historically came with true steel plates until 2014. However, steel plates are available as a dealer installed option (I suspect few salespeople know this) and I ordered my kit right at the parts counter for $266 and had them the next day - they replace all the plastic pieces up front and include one for the transfer case. I installed all three plates in about 20 minutes. I don't recall the part number but I believe it's called an "under body shield kit," just make sure you specify V6 or V8 otherwise the oil filter hole might be in the wrong place. Mine is officially battle tested... I've bounced off more than a few stumps and bottomed it out in deep ruts many times. I wouldn't recommend aftermarket unless you can find something cheaper.
Re: 2017 Silverado Front Bumper & Skid Plate?? [Re: Mr_Joe] #5137293
06/18/19 07:44 AM
06/18/19 07:44 AM
Southeast
meep Online content
meep  Online Content
Southeast
^^^ best post of the week^^^
2018 F150
2015 crv (wifey!)
Re: 2017 Silverado Front Bumper & Skid Plate?? [Re: Mr_Joe] #5137886
06/18/19 08:32 PM
06/18/19 08:32 PM
Wisconsin
Mr_Joe Offline OP
Mr_Joe  Offline OP
Wisconsin
Thanks, looking at this bumper currently. I’m home now & will look closer.
Re: 2017 Silverado Front Bumper & Skid Plate?? [Re: Mr_Joe] #5138673
06/19/19 06:39 PM
06/19/19 06:39 PM
Wisconsin
Mr_Joe Offline OP
Mr_Joe  Offline OP
Wisconsin
Just an update; I could spend more time looking & evaluating. Yes, it’s my ‘air dam’, not really a bumper problem. The actual bumper is fine, though weak it may be.
I attached my actual license plate holder to the bumper, technically 2 plates required in WI. I removed that lower, center metal bracket, behind the air dam. I also ordered the metal, GM skid plate, eBay seller, about $238 or so shipped.
My plastic skid plate is all buggered up & hanging. I tied off some electrical wires, I should be fine once my new skid plate is on. I didn’t want to spend the $630+ on a bumper anyway. Truth be known, my truck spends most of it’s time on good roads.
Re: 2017 Silverado Front Bumper & Skid Plate?? [Re: Mr_Joe] #5138679
06/19/19 06:44 PM
06/19/19 06:44 PM
Texas
4WD Online confused
4WD  Online Confused
Texas
One thing folks need to look at - is aftermarket bumpers can effect collision protection - they alter the crush zone and can impact the SRS trigger sensor
Re: 2017 Silverado Front Bumper & Skid Plate?? [Re: Mr_Joe] #5138682
06/19/19 06:45 PM
06/19/19 06:45 PM
Texas
4WD Online confused
4WD  Online Confused
Texas
Please send pictures when done - I own a 2018 and don't like that big sand plow in the front ...
Re: 2017 Silverado Front Bumper & Skid Plate?? [Re: Mr_Joe] #5138994
06/20/19 07:05 AM
06/20/19 07:05 AM
Wisconsin
Mr_Joe Offline OP
Mr_Joe  Offline OP
Wisconsin
Here is a picture. That flimsy air dam will be in the trash soon.
