Older fram ultra
by tblt44 - 10/19/19 08:42 PM
Best price on Colt 9MM pattern mags?
by GumbyJarvis - 10/19/19 08:20 PM
Using a trim router for cutting sheetrock
by JLawrence08648 - 10/19/19 08:09 PM
C&P of a Tough Guard w/50,000 miles to be posted soon
by MrQuackers - 10/19/19 08:04 PM
Chevy dealer, 7 free oil changes?
by Zacc - 10/19/19 07:34 PM
School me..1200 amp jumper
by Schmoe - 10/19/19 07:19 PM
YouTube Finish Test
by RayCJ - 10/19/19 07:09 PM
Overfilled, drained some, still too full?
by OCDriver - 10/19/19 06:16 PM
Wix made in Korea?
by JGmazda - 10/19/19 06:01 PM
Oil change interval question
by SkipCam - 10/19/19 05:49 PM
Remove Spark Plug Wires
by borgward - 10/19/19 04:53 PM
Pinion yoke loose, is the bearing ruined?
by Fsharp - 10/19/19 03:45 PM
Need tires for the mustang
by BeerCan - 10/19/19 03:24 PM
No sign of of oil sample at BStone :(
by 21Rouge - 10/19/19 02:45 PM
Carpet Shopping - Need Advice
by The Critic - 10/19/19 02:17 PM
Local Autozone clearance
by Soggydog - 10/19/19 02:05 PM
Two Fumoto valves
by otis24 - 10/19/19 01:17 PM
Going in the engine today!
by domer10 - 10/19/19 01:15 PM
GM 4WD rubbing/grinding after 4Lo
by HawkeyeScott - 10/19/19 12:52 PM
Choosing a new phone
by ram_man - 10/19/19 12:28 PM
Hallj49803, Tralever, Jhams, gmguy57, jamie24874
69612 Registered Users
79 registered members (bbhero, 4WD, 2003f7, AZjeff, aquariuscsm, AdditiveOCD, 9 invisible), 1,620 guests, and 25 spiders.
Topics296,195
Posts5,093,284
Members69,612
Most Online3,532
Jul 30th, 2019
2000 Silverado 5.3L, LS, Rim/Tire Size Recommendation #5136925 06/17/19 06:42 PM
G
Gito Offline OP
G
We just replaced the rack and pinion, pump and hoses on my father in laws 2000 Silverado 5.3L, 2wd (Step Side).
Truck currently has 18 inch rims with a 265/60/18 tires.
Father in law would like to go back to the stock rims and use a 255/70/16 tires but he feels like the stock tires and rims do not look good on his Step Side truck.
Are there any other rim sizes and rim styles by Chevy that are compatible with the 2000 Silverado (Step Side)
Next question:
Do larger rims and tires (265/60/18) cause premature wear to the pump and rack and pinion?
We found a forum thread (4x4) that talks about how larger rims and tires can cause additional stress the suspension and steering components?
Any advice is greatly appreciated
Re: 2000 Silverado 5.3L, LS, Rim/Tire Size Recommendation [Re: Gito] #5136994 06/17/19 08:06 PM
SteveG4 Online Content
Online Content
Good question!
My nice 2006 4WD Silverado has 17" wheels, with OE-sized 265/70/R17 tires on it. I'm looking at new wheels for it soon.
These in fact: Pro Comp Alloys Series 89 Wheel with Flat Black Finish (17x8"/6x139.7mm)
Check 17" wheels, making sure the bolt pattern matches (that would be the 6x139.7mm pattern noted above). It might.
BTW, you could build the exact truck you're describing and put it in your "Amazon Garage." Then, reference wheels and other parts to it. Give that a try like it did.
Good luck.
Somewhere between Alaska and Wisconsin...
2006 Silverado LT Crew Cab 4WD & 2013 Equinox AWD
Re: 2000 Silverado 5.3L, LS, Rim/Tire Size Recommendation [Re: Gito] #5137018 06/17/19 08:29 PM
AZjeff Online Content
Online Content
I had a white 2000 Silverado that I put 17" Avalanche wheels on and it looked great. Like these:
[Linked Image]
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: 2000 Silverado 5.3L, LS, Rim/Tire Size Recommendation [Re: SteveG4] #5137089 06/17/19 09:58 PM
G
Gito Offline OP
G
Originally Posted by SteveG4
Good question!
Good luck.
Amazon garage?
I'm not sure what that is, sorry.
Re: 2000 Silverado 5.3L, LS, Rim/Tire Size Recommendation [Re: Gito] #5137284 06/18/19 07:24 AM
M
mrsilv04 Offline
M
I wouldn't worry about a 265/60-18 causing additional wear and tear on a 2000 Chevy truck, as that's very close to a tire size that GM uses on today's trucks (265/65-18). I think the 265/60 is more of a size that Ford uses, but is so close that it doesn't matter.
On a 2000 Silverado that came with 16" wheels from the factory, you can use any wheel that came factory on a 1/2 ton Silverado, Tahoe, Suburban, Avalanche, Sierra or Yukon from 2000 to today. GM hasn't changed to bolt pattern at all.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: 2000 Silverado 5.3L, LS, Rim/Tire Size Recommendation [Re: Gito] #5137326 06/18/19 08:40 AM
W
WyrTwister Offline
W
Next question:
Tires and wheels area weight that is bouncing up and down , constantly ( to some degree ) . The more they weigh , the more stress on what they are bolted to .
Also , the heavier / larger diameter they are , the larger flywheel they are . Maybe gyroscope , too .
If I were to change , I would go stock . What they look like is not as important , to me , as how well they work / perform .
Beast of luck to you , :-)
Wyr
God bless
