Valvoline
by Koncrete_Cam - 12/06/19 01:32 PM
91 registered members (264mag, Bebop367, bbhero, ArrestMeRedZ, BeerCan, 2010Civic, 5 invisible),
1,839
guests, and 58
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,388
Posts5,134,332
Members70,054
Most Online3,589 Nov 2nd, 2019
Re: The Truth & Myths about Ceramic Coatings
[Re: rooflessVW]
#5136619
06/17/19 12:35 PM
HYUNDAIFAN0001
OP
OP
Posts: 557 |
What would you do for a car that is 95% highway, used on alot of roadtrips, and plan to keep? A whole-car custom-cut PPF. A quality SiO2 coating professionally applied is the next best thing. Indeed. A hood guard/shield wouldn't be a bad idea either.
Always taking care of my rides.
[Re: HYUNDAIFAN0001]
#5136632
06/17/19 12:45 PM
PimTac
Posts: 11,673 |
What would you do for a car that is 95% highway, used on alot of roadtrips, and plan to keep? A whole-car custom-cut PPF. A quality SiO2 coating professionally applied is the next best thing. Indeed. A hood guard/shield wouldn't be a bad idea either. I agree. The only thing that can help against chips and the line is a PPF.
2017 Mazda CX5 Havoline Pro DS 0w20 Roki OEM filter.
#5136647
06/17/19 01:03 PM
rooflessVW
Posts: 6,967 |
What would you do for a car that is 95% highway, used on alot of roadtrips, and plan to keep? A whole-car custom-cut PPF. A quality SiO2 coating professionally applied is the next best thing. Indeed. A hood guard/shield wouldn't be a bad idea either. Windshield savers, those. We're on a roll here, man!
"Zed's dead baby, Zed's dead."
[Re: rooflessVW]
#5136695
06/17/19 01:42 PM
Pew
Posts: 536 |
What would you do for a car that is 95% highway, used on alot of roadtrips, and plan to keep? A whole-car custom-cut PPF. A quality SiO2 coating professionally applied is the next best thing. Indeed. A hood guard/shield wouldn't be a bad idea either. Windshield savers, those. We're on a roll here, man! Great ideas... I always have to wipe down the windshield every time I gas up during my summer trips because the bugs and dust on the windshield is bad enough that visibility at night actually starts to be impaired.
#5136714
06/17/19 01:59 PM
HYUNDAIFAN0001
OP
OP
Posts: 557 |
A good UV protection spray wax will actually help avoid those buggers sticking and making the mess they usually make. I use my Chemical Guys Blazin' Banana on all exterior surfaces, including painted areas, plastic, chrome, trim, and windshields...it applies easy and makes washing windows easy too. There are other products which do the same thing (although some don't fare well on glass or dark trim).
[Re: grampi]
#5136887
06/17/19 05:00 PM
The_Nuke
Posts: 737 |
I'm still undecided about using ceramics. For one thing, I enjoy spending time detailing my vehicles, and I know that using ceramics isn't going to make them look any better. Secondly, I KNOW what the products I use now are capable of, as far as how they will look, and how long they will last. I know if I use Collinite on my vehicle, it will easily last 6 months, especially if I use a quick detailer in between wax applications. I feel like I know what I'm getting now and if I make a move to ceramics, it'll be like starting all over again because I won't have a clue about the product(s) I'm using... Think of these new spray on ceramic products as just another entrant into the easily-applied paint protection field. Treat them like you would a shiny new wax-as-u-dry from Meguiars or Griots. Buy a bottle, give it a day in court, put it on the shelf to give away if you aren't impressed with the results. Basically the same as any other spray wax/sealant you might stumble across OTC and want to try - it may be a little nicer to use than current go-to, or it may not be any different. Only you can decide, try 'em out and see. Don't expect miracles or even significant difference from a good spray wax you are already using. May be easier or last a little longer, that's about it.
2012 Charger Pursuit aka "The Bacon Hauler" - 5.7L + NAG1 (A5) + 2.65 (215mm)
#5136891
06/17/19 05:04 PM
The_Nuke
Posts: 737 |
For the record, I've tried the ceramic sprays from Megs, Mother's, and Turtle Wax. Each has its perks; none are head and shoulders above my normal go-to (GG BiS spray wax). I'll use them until gone and then likely go back to my bottle of GG i have left.
#5137010
06/17/19 07:22 PM
PlzRepond
Posts: 116 |
@Pew- regarding the bugs 🐛 and dust
You can use a really good sealant like turtle wax Ice or nu finish on the windshield to help make a barrier so those things don’t stick anymore. Also makes the windshield super hydrophobic. I literally applied both to our glass shower doors! Good luck 🍀
#5137390
06/18/19 09:21 AM
PimTac
Posts: 11,673 |
“Great ideas... I always have to wipe down the windshield every time I gas up during my summer trips because the bugs and dust on the windshield is bad enough that visibility at night actually starts to be impaired.”
In your situation stay away from the cheap windshield wash products. Get something strong like Krystal Klar. Keeping the windshield clean is the biggest step.
I would refrain from using the orange bottle stuff on glass. There are much better products out there. Putting something on your windshield that ends up causing wiper skip or smearing is just doubling up on your troubles.
[Re: PimTac]
#5137543
06/18/19 12:25 PM
Pew
Posts: 536 |
I would refrain from using the orange bottle stuff on glass. There are much better products out there. Putting something on your windshield that ends up causing wiper skip or smearing is just doubling up on your troubles. Thanks for the tip. I just started using Rain-X on the Focus again but I'll definitely add in the Krystal Klear. $12 on amazon isn't bad to make sure the windshield is good to go. I tried the Rain-X anti-fog on the inside of the windshield and it left a lot of residue that made the glass look fogged up.
[Re: gofast182]
#5148253
06/30/19 09:37 PM
bbhero
Posts: 7,188 |
At on average $ 1500 per car around here, the cost / benefit is questionable. People have the unrealistic expectation that the coating will protect the paint from EVERYTHING ... as the video states, it doesn't.
So why bother ... $ 1500 buys a lot of professional detailing, or a ton of do it yourself detailing products. Well... Let's say that you went against the BITOG grain and bought a nice car, that you plan to keep forever. Not because you're cheap, but because it's unique. Let's say that you're finally doing well, and you've saved up. You're going to custom order that new ///M3, Individual Composition, and you're going to pick it up in Germany. Once it is home, you want to protect your investment, so you visit a professional detailer. He explains the paint correction process, and will correct any swirls or contamination presently on your paint, restoring the finish to a better-than-new shine. How would you like him to protect the car's newfound shine? The detailer of course reccomends a full custom-cut PPF as the ultimate protection, but you're not sure you want to spend $3000+. A ceramic coating is presented as the next best thing. It creates a near-permanent sacrificial layer, so that the scratches that WILL accumulate over time, accumulate in the coating, not directly into your clear coat (think micro-marring here, swirls from washing, brushing against the paint, etc.) It also protects against etching and the car will not accumulate the dust and dirt that lead to scratching as easily. It also makes the car easier to wash - again, less chance of marring the finish. As a bonus, if your car needs a paint correction in 5 years or so to handle the swirls, you will be polishing (removing) the ceramic coating first - not the clear coat. Or of course, you could do as you say - spend $500 every few years for that same detailer to grind away layer after layer of your clearcoat to remove the defects introduced when using the car. The unrealistic expectations are not created by the product, they're created by less than reputable sellers and installers. A quality company or professional detailer will be honest, and up front. Managing expectations is customer service 101. Well put. The vast majority of the ~$1,000-$1,500 prices people see for coatings are the standard paint correction in order to perfect the paint before you apply the coating. As for the protection itself, it offers a lot more than a wax or paint sealant as long as one understands it isn't an excuse not to take care of the finish. In the next few weeks I'm going to apply Polish Angel Cosmic V2 to the new X5. I'm anxious to see how it goes. Great, great post by RooflessVW and gofast......
Nissan Altima 3.5 Coupe Napa full synthetic 5w30 Wix 57356 Oil filter "Treat your family like your friends and treat your friends like your family."
#5150685
07/03/19 05:42 PM
avacado11
Posts: 195 |
IMO DIY ceramic coats are not worth it. $200-300 for a proven DIY coat will only last like 2 years with maintenance washes and toppers. Majority of them only last a year. The long lasting professional grade ones are really the only ones worth your time, but at $1000+ you really question wether it's cheaper to buy a $20 bottle of Collinite 845 that'll easily last 5-6 applications/2-3 years per car.
2017 Subaru Outback 2014 Lexus IS250F 2014 BMW i3 2014 Maserati Ghibli S Q4
[Re: avacado11]
#5150695
07/03/19 06:14 PM
rooflessVW
Posts: 6,967 |
$2-300, eh? Try half that, for the same products the professionals use. You may spend $200-300 for Modesta but CQuartz, Gyeon, Wolfgang, Blackfire, etc... There all $75-150 depending on the kit.
#5150773
07/03/19 08:33 PM
robertcope
Posts: 1,048 |
Ceramic coatings are amazing. I had my '92 NSX done a few years ago. It's simply amazing how easy it is to keep looking good. Nothing sticks to the paint. I wouldn't bother doing it to my daily driver, but for any nice car, it is worth it. Actually, if I bought a new daily driver that I planned to keep, I'd probably have it done.
#5156701
07/10/19 11:19 AM
flemiis
Posts: 3 |
Remember the Teflon products?
