new boat, considering twin f 150 yamis
by 1978elcamino. 07/17/19 03:20 PM
Preventative repair - 2009 Ford Flex water pump
by KGMtech. 07/17/19 02:56 PM
Bought out phone lease for a song
by 14Accent. 07/17/19 02:54 PM
Do you have a fave RTV sealant you use?
by ZZman. 07/17/19 01:36 PM
Scanner
by tiger862. 07/17/19 12:36 PM
Hyundai ELantra ATF follow up
by flinter. 07/17/19 10:14 AM
Poor Bill
by 4WD. 07/17/19 10:05 AM
Cadillac parked for 25 years...
by mattwithcats. 07/17/19 09:52 AM
Sumitomo Encounter Tires
by parshisa. 07/17/19 09:40 AM
API 1509 Updated with New GF-6B Shield
by Solarent. 07/17/19 07:27 AM
Car Vac Recommendations
by klt1986. 07/17/19 07:05 AM
ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
prof_redbeard, drnc, blackseven, EdK, guru2019
68686 Registered Users
115 registered members (2003f7, 1978elcamino, 2015_PSD, 2009Edge, 14Accent, 12 invisible), 2,265 guests, and 24 spiders.
Topics291,991
Posts5,014,761
Members68,686
Most Online2,967
Mar 10th, 2019
Page 785 of 797 1 784 785 786 797
Re: Post your latest oil change [Re: Superbuick96] #5136614
06/17/19 01:32 PM
06/17/19 01:32 PM
Alabama, United States
Red91 Offline
Red91  Offline
99 town car
4.6 v8
Out: Valvoline 5/20, service champ filter
In: Napa 5/20, Napa proselect filter
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Post your latest oil change [Re: Superbuick96] #5136833
06/17/19 05:07 PM
06/17/19 05:07 PM
Washington
Puckrobber Offline
Puckrobber  Offline
Washington
2016 VW Jetta w/1.4L turbo engine at 30,982 miles.
OUT: Castrol Magnatec 5W-30 Synthetic and a FRAM Extra Guard PH3614 oil filter
IN: Carquest Full Synthetic 5W-30 and a Carquest Premium #85348 oil filter
2005 Ford Explorer AWD - 169,920 miles (Pennzoil Plat. HM 5W-30)
1995 Mercury Cougar XR7 - 58,490 miles (Mobil 5000 10W-40)
2016 Volkswagen Jetta - 31,200 miles (Carquest Full Syn. 5W-30)
Re: Post your latest oil change [Re: Puckrobber] #5136842
06/17/19 05:17 PM
06/17/19 05:17 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Are you aware that neither oil is appropriate for your Jetta?
"Zed's dead baby, Zed's dead."
Re: Post your latest oil change [Re: rooflessVW] #5136850
06/17/19 05:27 PM
06/17/19 05:27 PM
Washington
Puckrobber Offline
Puckrobber  Offline
Washington
I thought it would be, too. But, I've taken this Jetta to the dealer for oil changes since I purchased it. When I checked the invoice at the first change, it had Castrol 5-30 put in it. When I inquired about it, the service manager said 5-30 was just fine for the climate I live in, and the difference from 5-40 was negligible. They only put 5-40 in if the customer asks for it. It's had both 5-40 and 5-30 in it, with no difference in engine noise or driving ability.
Re: Post your latest oil change [Re: Puckrobber] #5136864
06/17/19 05:41 PM
06/17/19 05:41 PM
CA
The Critic Offline
The Critic  Offline
CA
They were most likely using Castrol Edge Professional OE 5W-30, which is a 502.00 approved oil:
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/711A4665F31054FE80257F8E006CA9C9/$File/BPXE-A9VF45.pdf
There are many different varies of 5W-30 oils; they can be extremely different.
2011 Toyota Prius 1.8L - 193K - Idemitsu ZEPRO Adv. Moly 0W-20
2007 Honda Accord 2.4 - 137K - Mobil 1 EP HM 5W-30
Re: Post your latest oil change [Re: Superbuick96] #5136867
06/17/19 05:43 PM
06/17/19 05:43 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
What grade they use is almost irrelevant as long as they’re putting in oil with the right VW specification. The only time it would make a difference is if you are routinely starting the car at extremely cold temperatures, below -25° F. Otherwise, if they are focusing on grade rather than specification you need to find a different mechanic.
1994 BMW 530i, 242K
1996 Honda Accord, 277K
1999 Toyota Sienna, 418K
2000 Toyota ECHO, 281K
Re: Post your latest oil change [Re: The Critic] #5136874
06/17/19 05:48 PM
06/17/19 05:48 PM
Washington
Puckrobber Offline
Puckrobber  Offline
Washington
Ah, thank you for the info. My sister has the Jetta, currently. She took it to her mechanic friend who did the work.
Re: Post your latest oil change [Re: Superbuick96] #5136921
06/17/19 06:39 PM
06/17/19 06:39 PM
Red91 Offline
Red91  Offline
01 f150
4.6 v8
Out: havoline 5/20, mighty filter
In: Napa 5/20, Napa gold filter
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Post your latest oil change [Re: Red91] #5136924
06/17/19 06:41 PM
06/17/19 06:41 PM
Red91 Offline
Red91  Offline
Forgot to put that a bottle of full throttle hm oil treatment was used in the town car change, like it matters.
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Post your latest oil change [Re: Superbuick96] #5137213
06/18/19 05:02 AM
06/18/19 05:02 AM
NC
Matagonka Offline
Matagonka  Offline
NC
2018 Mazda 3
Out: Pennzoil 0w20 w/Mazda oil filter
In: M1 AFE w/M1 oil filter
2018 Mazda 3 Touring HB 2.5
Re: Post your latest oil change [Re: Superbuick96] #5137224
06/18/19 05:27 AM
06/18/19 05:27 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
2012 Mazda 3 Skyactive - Chevron Conventional 5w30 - Basic Purolator oil filter
2008 Dodge Durango 4.7 - Chevron 5w30 Conventional - Super Tech oil filter
Out = same as above
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: Post your latest oil change [Re: Superbuick96] #5137315
06/18/19 08:27 AM
06/18/19 08:27 AM
MN
ZebRuaj Offline
ZebRuaj  Offline
MN
2011 Hyundai Sonata
Out: 3 qts unknown + Fram OC
In: Supertech Syn HM + Supertech filter
2008 Corolla
Out: unknown + unknown paper element
In: Supertech 0w20 Syn HM + Fram Ultra
~Shade tree mechanic for friends and family.
Re: Post your latest oil change [Re: Superbuick96] #5137360
06/18/19 09:34 AM
06/18/19 09:34 AM
south dakota
joekingcorvette Offline
south dakota
2005 Corvette Z-51 64,500 miles. OLM 72 percent. I had some cold starts over the winter just to keep it lubricated and thought it would be nice to change it. Mobil 1 10w30 and kept the old K&N oil filter on because of low mileage on the filter. Bought this car with 1000 miles back in 2005.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: Post your latest oil change [Re: Superbuick96] #5137509
06/18/19 12:50 PM
06/18/19 12:50 PM
High Country of Western NC
sopususer Offline
sopususer  Offline
Vehicle: 2017 Subaru Impreza 2.0L 20K on unit/5K oci
Out: 4.2 Quarts QSUD 0W20 and Wix 57055 filter
In: 4.2 Quarts Castrol Magnatec 0W-20 and NAPA Gold 7055 filter
[Linked Image]
Re: Post your latest oil change [Re: Superbuick96] #5137512
06/18/19 12:53 PM
06/18/19 12:53 PM
sopususer Offline
sopususer  Offline
Vehicle: 2017 Subaru Forester 2.5L 25K on unit/5K oci
Out: 5 Quarts PP 0W20 and NAPA Gold 7055 filter
In: 5 Quarts NAPA 0W20 Synthetic and Fram XG7317 filter
[Linked Image]
