Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
Flank drive wrenches
by spasm3 - 01/24/20 08:39 PM
Auto assembly and mfg. logistics
by P10crew - 01/24/20 08:26 PM
Kodiak
by P10crew - 01/24/20 08:05 PM
yet another black eye for the 2,4 ecotec
by super20dan - 01/24/20 07:52 PM
New incentive for 0w20
by Snagglefoot - 01/24/20 06:43 PM
2020 Kia Forte Engine
by artbuc - 01/24/20 03:27 PM
Torn filter that's NOT a motorcraft.
by mpgo4th - 01/24/20 03:22 PM
K&N PS-1008 $3.36
by jayjr1105 - 01/24/20 03:14 PM
Forum notifications?
by jayjr1105 - 01/24/20 02:50 PM
Thinking about transmission cooler for Honda
by jayjr1105 - 01/24/20 02:26 PM
Pete44, Connie7, 2020XT, 4strokes, Perseus
70518 Registered Users
47 registered members (2009Caraman, allgm59, askani79705, alchargo, aleneros, 4 invisible), 2,067 guests, and 25 spiders.
Topics300,514
Posts5,177,571
Members70,518
Page 1 of 3 1 2 3
1985 Toyota Camry.. Any tips? #5136596 06/17/19 12:20 PM
spavel6 Offline OP
I've recently been itching for a new automotive challenge. The challenge is how quickly I can get a running, driving, and road-tripping car.
[Linked Image]
Just picked up this time-capsule 1985 Camry. It has milkshake in the oil, and runs rough (doesn't idle), the PO believes the head gasket blew.
The engine started right up, but was smoking and smelled of burning oil from the back passenger-side corner. It went into gear and I was able to drive it out onto the road from it's hiding place in the driveway.
Has anyone worked on these before? Any tips/tricks on 1st gen Camry engines?
2003 VW Jetta Wagon TDI 198k M1 5W40 TDT
2001 VW GTI VR6 250k T6 5W40
2001 VW Passat Wagon V6 4motion 110k PP 5W30
Re: 1985 Toyota Camry.. Any tips? [Re: spavel6] #5136600 06/17/19 12:23 PM
B
BMWTurboDzl Offline
B
Looks like a great candidate for the crusher. I would not want to risk my life on 30+ yr old 1980's technology.
435i
Re: 1985 Toyota Camry.. Any tips? [Re: spavel6] #5136623 06/17/19 12:39 PM
M
mk378 Offline
M
This was not a good car when it was new. You have the stunted performance of 1980s smog compliance technology, and the styling of a Toyota Camry. That was when it was new.
Re: 1985 Toyota Camry.. Any tips? [Re: spavel6] #5136625 06/17/19 12:40 PM
V
vw7674 Offline
V
Have no idea as to the 1985 engine materials, but if it's aluminum head/block, pull the head check for warpage (shop or trust yourself)
on head surface & block surface. Check the radiator for leakage that could've caused the blown gasket, put it back together & drive.
As I recall, every mid-eighties econobox was slow, i.e.60-75hp, top end 108-111 mph. Time probably won't make this one any faster.
Re: 1985 Toyota Camry.. Any tips? [Re: spavel6] #5136626 06/17/19 12:41 PM
M
mclasser Offline
M
Hope you didn't pay anything for that.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: 1985 Toyota Camry.. Any tips? [Re: spavel6] #5136662 06/17/19 01:16 PM
A
atikovi Offline
A
[Linked Image]
Got this 86 back in 2006 for $300 at auction. It ran fine through the lane. Go to drive it to my storage and as soon as I step on the gas to get on the highway, I see a smokescreen behind me like a dragster burnout. Smoke goes away when letting up on the gas and it was only a 5 mile drive so I made it. Thought it had a blown head gasket and a compression test showed 60psi in the center 2 cylinders. So I pull the head, replace the gasket and put it back together. Go for a drive and it still smokes like a mother. Take the head back off and investigate some more. Turned out that those two cylinders had broken piston rings and cracked ring grooves. So I replaced the 2 pistons and rings in all 4 cylinders. Think I replaced the rod bearings as well.
[Linked Image]
Turned out real nice, Car ran great and I drove it 800 miles to Chicago for someone I sold it to on Ebay. These Camry's are very pleasant to drive and very comfortable. Few of complicated electronics of newer models to go bad.
Re: 1985 Toyota Camry.. Any tips? [Re: spavel6] #5136668 06/17/19 01:21 PM
P
PandaBear Offline
P
The quickest would be to pull a crashed total engine from junkyard.
The cheapest would be to take the head off, flatten the head, install with new HG, then run some 20w50 praying that it will not burn too fast. This will likely cost more than the car is worth if you don't have a shop to do the job right.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: 1985 Toyota Camry.. Any tips? [Re: spavel6] #5136669 06/17/19 01:21 PM
dadto2 Offline
Don't let the nay-sayers deter you. Sounds like a fun project to me! I frequently risk my life in even older automotive technology. Many decades older... It's fun!
'16 GMC Sierra 1500 Crew Cab 4.3
'15 Volvo S60 T5 AWD
'99 Volvo S70 2.4
Re: 1985 Toyota Camry.. Any tips? [Re: spavel6] #5136692 06/17/19 01:40 PM
Dave9 Offline
Milkshake oil and you decide to drive it.
Best tip is don't be fooled into thinking you can make a worn out old vehicle road-trip worthy without pouring far more into it than its worth, which right now is about $200 scrap value.
If you really want to put the time into an old vehicle, start out with something classic, iconic, beautiful, built before '80 at least.
Re: 1985 Toyota Camry.. Any tips? [Re: spavel6] #5136696 06/17/19 01:43 PM
supton Offline
I'd pull the head and go from there. If it's warped it might be best to send it along. The engine that is. Maybe look to see what later model engine would drop in. Maybe an entire driveline swap is in order.
But maybe it's just a blown HG and it'll be a quick job.
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 220k, his
Re: 1985 Toyota Camry.. Any tips? [Re: atikovi] #5136707 06/17/19 01:53 PM
A
AC1DD Offline
A
I remember these when they were being sold as brand new! While not sporty or stylish they are comfortable, VERY durable, and decently safe even today.
Very straight forward, cheap to keep cars. I'd gladly own one of these today if it wasn't beaten up.
Folks forget this was when Toyota was the most well built and durable cars you could get at any price. They STILL measure up in that department today.
This is a miracle feat.
If you wanted a fun daily driver that was inexpensive and fairly reliable with some room for passengers you'd go for the Honda Accord with stick which was also
a almost Toyota like bulletproof design, but with great driving dynamics too.
Re: 1985 Toyota Camry.. Any tips? [Re: Dave9] #5136710 06/17/19 01:57 PM
A
alchargo Online Content
Online Content
A
For some reason, post 1980 cars like this are becoming popular with younger generations that never experienced them the first time around. Events like Radwood are becoming popular and are for cars from the 1980s and 1990s only. The Camry in question appears to be mostly rust-free and, sadly, some millennial would probably pay crazy money for it.
Re: 1985 Toyota Camry.. Any tips? [Re: alchargo] #5136717 06/17/19 02:06 PM
supton Offline
As compared to a muscle car, or anything pre-war... shrug Beauty is in the eye of the beholder, I guess.
Re: 1985 Toyota Camry.. Any tips? [Re: spavel6] #5136723 06/17/19 02:16 PM
rollinpete Offline
If you get it cheap,
Would be a fun car to work on, and get it going.
Body looks to be in good shape.
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 190k
03 Saturn Ion 2.2 L4 5spd 241k
Shell Rotella Gas Truck 5w30
PPHM 5w30
Currently under the influence of oil shocked2
Re: 1985 Toyota Camry.. Any tips? [Re: spavel6] #5136741 06/17/19 02:41 PM
M
meep Offline
M
i remember lots of room in that hood, good angles to wrench in, much easier to fiddle with than newer tech. weak spot was the the torque converters - it took toyota (aisin?) a while to figure out TC durability back then, as manuals had previously been more prevalent in 4-cyl life.
replace the oil and do a compression check, both wet and dry, to see what you're getting in to. I might pull the pan and a rod cap and look for scoring on the bearings. If there's damage, I'd look at wrecked or even autozone motor/block prices. If the bearings don't show issues, I'd proceed with head work if the wet/dry tests give similar numbers. If you aren't sure what that means, read up on it so you can get good information to help you make informed decisions.
My best friend in high school had a test drive in one of those. It was a better car IMO than what he ended up with. Unfortunately, it had some TC noises that we figured would become a costly repair in a few months and went with a lesser car in better shape.
2018 F150
2015 crv (wifey!)
Page 1 of 3 1 2 3
