Shop light LED conversion bone head move.
by JTK. 07/21/19 02:27 PM
The Hunt Begins...
by MCompact. 07/21/19 02:10 PM
Cambodia Forest, River and Beach.
by Voleak. 07/21/19 02:01 PM
Foxwoods Resorts Casino 301 at NHMS
by bdcardinal. 07/21/19 01:29 PM
2017 Ram 1500 rear brake lines
by LAGA. 07/21/19 01:27 PM
yacco oils, better than motul (xcess)?
by pep808. 07/21/19 01:22 PM
Scotty K. has finally let me down
by Lolvoguy. 07/21/19 01:03 PM
Exxon/Mobil Synergy Supreme +
by incognito_2u. 07/21/19 12:51 PM
Son going to bring another vehicle home
by vavavroom. 07/21/19 12:43 PM
The stent didn't work, now what?
by andyd. 07/21/19 12:34 PM
TV shows you enjoy
by 53' Stude. 07/21/19 12:14 PM
Replaced strut mount. Still binding
by lairdwd. 07/21/19 11:07 AM
2019 Jeep Wrangler Unlimited Rental
by 2015_PSD. 07/21/19 10:33 AM
Galvanic corrosion
by LeakySeals. 07/21/19 10:20 AM
Ford EcoBoost Oil Catch Can?
by JeffKeryk. 07/21/19 10:17 AM
Hybrid-Keep or Trade
by Spector. 07/21/19 10:05 AM
STP S 4967 NEW FILTER CUT OPEN
by 53' Stude. 07/21/19 09:03 AM
Is my mower battery going to die one day?
by motor_oil_madman. 07/21/19 08:26 AM
andrewv, AMHKCMO, vanenk, grikor, Mikelima
68723 Registered Users
104 registered members (53' Stude, AlienBug, 1WildPig, AdditiveOCD, 2010Civic, 4WD, 17 invisible), 2,363 guests, and 30 spiders.
Topics292,201
Posts5,018,615
Members68,723
Most Online2,967
Mar 10th, 2019
Brake bleeding procedure #5136502
06/17/19 11:28 AM
06/17/19 11:28 AM
New Jersey
painfx Offline OP
painfx  Offline OP
New Jersey
Does anyone have access to ALLDATA or Toyota database?
I am looking for the procedure to manually bleed the brakes on a 2018 Toyota Camry 4 cylinders.
Also can maunally bleeding the brakes be efficient and effective as using a scan tool to activate the ABS? Will it get all the air out doing it manually?
Thanks
Re: Brake bleeding procedure [Re: painfx] #5136508
06/17/19 11:35 AM
06/17/19 11:35 AM
VA
thastinger Offline
thastinger  Offline
VA
If you don't want to mess with it, shops have a machine that hooks to all 4 bleeder valves and sucks out old fluid from those as it pumps in new fluid to the reservior.
Otherwise, I bought a kit to do it on my own, it has a bag and suction cup that attached to your fenders, start with the wheel furthest away from the res.
Re: Brake bleeding procedure [Re: painfx] #5136510
06/17/19 11:37 AM
06/17/19 11:37 AM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
You've already asked this before.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Brake bleeding procedure [Re: painfx] #5136540
06/17/19 12:15 PM
06/17/19 12:15 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
I'm not familiar with the newer Toyota brake systems, but for my 04 , the ABS unit has no effect at all for normal braking. The two lines from the MC go in and pressurize the four lines to the brake calipers. Without the ABS, the two MC lines would be routed to the pressure compensating valve, just like they are now.. I replace brake fluid every two years using Russell Speed Bleeders installed on calipers.I don't think the ABS system is a factor. Some of the early ABS systems required special equipment because they used a pressurized accumulator to assist pump. My 84 Honda had that ABS system. Honda dropped that in about 90.
Re: Brake bleeding procedure [Re: mclasser] #5136555
06/17/19 12:28 PM
06/17/19 12:28 PM
Ohio
hallstevenson Offline
Ohio
Why not refresh the OP's memory with the answer that he/she got ? As I recall, no one was able to other than paying for the data.
Re: Brake bleeding procedure [Re: Yah-Tah-Hey] #5136573
06/17/19 12:54 PM
06/17/19 12:54 PM
SE PA
diyjake Offline
diyjake  Offline
SE PA
These Russell Speed Bleeders work pretty good?
Re: Brake bleeding procedure [Re: diyjake] #5136577
06/17/19 01:01 PM
06/17/19 01:01 PM
Santa Barbara, CA
bdcardinal Online content
bdcardinal  Online Content
Santa Barbara, CA
They work fantastic. I have put them in every car I have owned and have been more than happy with them.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Brake bleeding procedure [Re: painfx] #5136640
06/17/19 01:56 PM
06/17/19 01:56 PM
Suburban Washington DC
atikovi Offline
atikovi  Offline
Did you run the master cylinder dry? If so, you will need a scan to activate the ABS. Or maybe if still under warranty... If not, and doing PM, just buy a Mityvac system for less than what the dealer would charge for one bleed service.
Re: Brake bleeding procedure [Re: painfx] #5136747
06/17/19 03:48 PM
06/17/19 03:48 PM
SE PA
diyjake Offline
diyjake  Offline
SE PA
I went on their website ( http://www.russellperformance.com/mc/speed-bleeders/ ) and it doesn't show a listing for my 2009 Camry or my 2014 Sienna.
Re: Brake bleeding procedure [Re: diyjake] #5136790
06/17/19 04:24 PM
06/17/19 04:24 PM
Ohio
Ohio
I checked a couple car models and they don't list them either. I suspect it's more a case of they haven't cataloged or cross-referenced their parts and where they fit. I mean, brake bleeders hopefully don't vary too much ! But maybe they do....
Re: Brake bleeding procedure [Re: painfx] #5136869
06/17/19 05:46 PM
06/17/19 05:46 PM
USA
slacktide_bitog Offline
USA
Why do you need to bleed the brakes so soon? hide
Re: Brake bleeding procedure [Re: mclasser] #5137264
06/18/19 06:52 AM
06/18/19 06:52 AM
New Jersey
painfx Offline OP
painfx  Offline OP
New Jersey
You are right. My fault.
Re: Brake bleeding procedure [Re: hallstevenson] #5137265
06/18/19 06:53 AM
06/18/19 06:53 AM
New Jersey
painfx Offline OP
painfx  Offline OP
New Jersey
Thank you smile
Re: Brake bleeding procedure [Re: slacktide_bitog] #5137267
06/18/19 06:56 AM
06/18/19 06:56 AM
New Jersey
painfx Offline OP
painfx  Offline OP
New Jersey
It's personal preference. smile
Re: Brake bleeding procedure [Re: hallstevenson] #5137275
06/18/19 07:12 AM
06/18/19 07:12 AM
NH
supton Online content
supton  Online Content
NH
But he did... by adding a link to the post. Maybe it could have said "LINK TO POST" to make it more obvious, but it was a link nevertheless.
2011 Toyota Camry, base, 2.5L/6MT, 187k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 152k, ours
1999 Toyota Camry LE, 2.2L/4AT, 208k, his
