.308 Win or .25-06
by mobilaltima - 12/10/19 01:05 PM
FI cleaners ruin injectors?
by Redright9 - 12/10/19 12:54 PM
Planned Changes at Honda
by The Critic - 12/10/19 12:30 PM
The forgotten Bolens 1253
by Lubener - 12/10/19 11:49 AM
Valvoline High Mileage vs Valvoline Full Synthetic?
by Bettez88 - 12/10/19 10:33 AM
Anything to quiet a noisy Subaru front differential?
by anarchyx34 - 12/10/19 10:15 AM
Consumer Cellular
by CourierDriver - 12/10/19 09:53 AM
Ford 6.2L
by ford46guy - 12/10/19 09:30 AM
2012 Hyundai Santa Fe lights on dash issue
by Urshurak776 - 12/10/19 08:25 AM
Electronic Parking Brakes- Long Term Reliability?
by LoneRanger - 12/10/19 08:17 AM
New Kitchen Faucet Selection: To Pex or Not to Pex ?
by LoneRanger - 12/10/19 07:41 AM
Factory Head Unit/New Speakers
by Duffyjr - 12/10/19 06:35 AM
Valve Stem Carbon Build-up from Oil in DI Engines
by paoester - 12/10/19 03:52 AM
New plugs in 2012 Frontier
by MolaKule - 12/09/19 11:02 PM
SN vs SN+
by natas - 12/09/19 11:02 PM
75w90 conventional vs syn???
by Doublehaul - 12/09/19 10:21 PM
UOA for my extended OCIs
by Kbuskill - 12/09/19 09:34 PM
Question on Job Interview Etiquette
by bunnspecial - 12/09/19 08:40 PM
BucDan, Poboy, Mcbridej74, IvanPletex, tjb59eldo
70087 Registered Users
122 registered members (330indy, 1978elcamino, 2015_PSD, 2010Civic, 10 invisible), 1,929 guests, and 22 spiders.
Topics298,540
Posts5,137,462
Members70,087
Most Online3,589
Nov 2nd, 2019
Leaving Amsoil Ea15k filter for 2 oil changes? #5136492 06/17/19 10:15 AM
M
metroplex Offline OP
M
I've searched on BITOG and it seems like there are a few who are using their Amsoil filters for more than 1 oil change. I'd like to use an Ea15K for another oil change to reach the 15,000 mile mark with a single filter. Is this considered safe? I know there are those who will argue that the filter is cheap enough to just change each time, but do we REALLY need to change the oil filter each time? It seems if the media is strong enough and nothing breaks/wears down, we should be able to reduce waste and keep using the filters?
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: metroplex] #5136511 06/17/19 10:38 AM
L
Linctex Offline
L
If your engine is clean inside - - I don't see why not. That is likely a very robustly made filter. (Donaldson?)
Back in the mid-1990's, I ran a Motorcraft FL-1A on a 400M 2bbl V8 in a Ford F250 for 30,000 miles (3x OCI's), and when I cut it apart it looked perfectly fine.
No "failures" of any kind, and just some carbon(?) chunks between the pleats that were just big enough to make it through the oil pump screen.
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: metroplex] #5136631 06/17/19 12:45 PM
czbrian Offline
You can leave the filter on for two intervals. I do the same but with Fram Ultras.
2019 Honda Pilot
1998 Chevrolet C1500
1995 Chevrolet C1500
2018 Mitsubishi Outlander PHEV
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: metroplex] #5136901 06/17/19 05:16 PM
CR94 Offline
There's no reason not to leave it at least two changes, if (and only if) the engine has a history (like Linctex's and mine) of leaving very little junk in previous filters.
2011 Toyota Prius now at 107K
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: metroplex] #5137185 06/18/19 01:43 AM
M
MetalSlug Offline
M
I did use 1 filter for 2x oil change before . But over the years I like new filter every oil change . Don’t matter what filter it’s . I like feeling that I have fresh oil filter with fresh oils .
Like some one here saying “ it like you take a shower but rewear the old underwater LOL
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: metroplex] #5137368 06/18/19 08:52 AM
P
Pinoak Offline
P
It's rated for 15k miles so under normal circumstances it should be good for at least 15k. Myself personally I'd leave it for 20k or more if under normal ideal conditions. I'd assume since you take the time to wonder about questions like your asking that you arent one to let your vehicles go unmaintained.
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: metroplex] #5138037 06/18/19 11:21 PM
Deontologist Offline
Wouldn't leaving the filter in place be better for the first start after an oil change? Shouldn't the oil build pressure faster? I mean you could prefill the filter, but on many vehicles the oil filter is sideways and not really readily prefillable.
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: Deontologist] #5138067 06/19/19 01:45 AM
M
MetalSlug Offline
M
Million vehicles been install dry oil filter every day , and they still fine . Also on many how to videos from all brand oil filter show how to do an oil change , for example is fram , they don’t fill oil on the filter before install . I think first 2-3 second is fine.!
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: Deontologist] #5138069 06/19/19 02:04 AM
4WD Offline
Well, for that one start among many. With my L83’s it’s 7 quarts when I leave the filter on and 8 quarts when I change it …
Same with these vertical filters regardless of black or orange or purple ADV …
So, have an RP on one that’s going 2 OCI’s and an AC Delco that’s not …
Both engines probably wear at the same rate …
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: metroplex] #5138521 06/19/19 02:28 PM
harry j Offline
I left an Amsoil eao20 a long time ago for 3 OCI's with no problems. The filter is now known as the ea15k20.
As an experiment, the last OCI was with this Ea15k20 filter and I had the best ISO oil cleanliness code and
particle counts in a long time. I normally use the Amsoil eao35 filter that is unfortunately no longer made.
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: MetalSlug] #5139739 06/20/19 10:10 PM
BlueOvalFitter Offline
+1
"One Filter, One OCI!"
2007 F150, 4.2 V6
Havoline HM 5W20, MC FL-400S
"One Box, One OCI!"
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: metroplex] #5141057 06/22/19 03:18 PM
harry j Offline
I think if your oil filter is vertical, I can't see any harm in filling the filter before installing. Seems like the thing to do.
