Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
56 registered members (allgm59, AC1DD, bbhero, BLND1, 6 invisible), 1,793 guests, and 28 spiders.
Topics300,414
Posts5,175,268
Members70,497
GM 2.4L ECOTEC Gen II, 569 UOA samples #5136147 06/16/19 08:27 PM
T
Talent_Keyhole Offline OP
T
I have a spreadsheet of 569 BSL oil samples, for the GM ECOTEC Gen II engine from 2006-2017 . I was not able to add the spreadsheet. I have revised the data and added averages, std devs, min, max, iron wear rates and comparisons between GDI and non-GDI versions of this engine for standard OCI, and fuel dilution.
Let me know your comments, questions, or any additions you would think might be meaningful. I originally shared this on the Chevy Equinox Forum which contains the full spreadsheet.
I am not convinced by labs and OEMs indicating that fuel dilution above 3% is normal for GDI engines.. It maybe typical, but not what I would consider normal.
https://www.equinoxforum.net/31-eng...cotec-oil-analysis-file-568-samples.html
Re: GM 2.4L ECOTEC Gen II, 569 UOA samples [Re: Talent_Keyhole] #5136263 06/17/19 02:01 AM
SteveG4 Online Content
Online Content
I can't read your grainy jpgs. frown
Somewhere between Alaska and Wisconsin...
2006 Silverado LT Crew Cab 4WD & 2013 Equinox AWD
Re: GM 2.4L ECOTEC Gen II, 569 UOA samples [Re: Talent_Keyhole] #5136329 06/17/19 05:47 AM
P
Popsy Offline
P
Can you put printscreens in .png, or upload the .xlx file ?
96 Barchetta, 300V 5W40 | Forfour 95, M1 0W40
Mazda 6 2.3, Castrol 0W30 | Colt Ralliart, 300V 5W40
Re: GM 2.4L ECOTEC Gen II, 569 UOA samples [Re: Popsy] #5136483 06/17/19 09:50 AM
T
T
Re: GM 2.4L ECOTEC Gen II, 569 UOA samples [Re: Talent_Keyhole] #5136486 06/17/19 10:00 AM
JohnnyJohnson Offline
LOL well that's an improvement you still can't read.
2004 Corolla 138385
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: GM 2.4L ECOTEC Gen II, 569 UOA samples [Re: Talent_Keyhole] #5136561 06/17/19 11:38 AM
I
IndyFan Offline
I
How can something typical not be normal? Just curious.
18 Jeep JLUR Wrangler 3.6 25k
15 Ford Transit 129k, Reman 3.5 @85k
17 Jeep Renegade 2.4 22k
08 Jeep Wrangler 3.8 135k
04 Jeep Grand Cherokee 4.7 105k
99 Mercedes E430 Sport 92k
Re: GM 2.4L ECOTEC Gen II, 569 UOA samples [Re: JohnnyJohnson] #5136579 06/17/19 12:05 PM
53' Stude Offline
Very good point Johnny
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: GM 2.4L ECOTEC Gen II, 569 UOA samples [Re: Talent_Keyhole] #5136973 06/17/19 06:37 PM
J
JAG Offline
J
Thanks for sharing that. It is hard to read. It looks like higher fuel content is correlated with higher iron wear rate. A plot of iron wear rate vs fuel percentage would be interesting to see. Same for other wear metals.
Re: GM 2.4L ECOTEC Gen II, 569 UOA samples [Re: JohnnyJohnson] #5137418 06/18/19 10:11 AM
T
T
Rather than just laughing, how would you post a screen shot or an Excel file on this forum.
Re: GM 2.4L ECOTEC Gen II, 569 UOA samples [Re: IndyFan] #5137425 06/18/19 10:17 AM
T
T
When Polaris Labs puts out a tech bulletin saying upwards of 7% fuel dilution is normal for a GDI engine, and my local GM dealer will not even discuss the issue or provide any incite.
When a GDI system sprays fuel directly on the backside of of the cylinder, washing the oil from the cylinder wall, leaking past the rings, and contaminating the sump.
When GM extends warranty coverage to 7.5 years and 120K miles for oil consumption and damage to rings and pistons for many of these GDI Ecotec engines.
Re: GM 2.4L ECOTEC Gen II, 569 UOA samples [Re: Talent_Keyhole] #5137453 06/18/19 10:39 AM
53' Stude Offline
Taking a screenshot is NOT hard at all. MAD_Hatter helped me take one and re size it smile
161,669 miles
Re: GM 2.4L ECOTEC Gen II, 569 UOA samples [Re: Talent_Keyhole] #5138091 06/19/19 04:12 AM
dnewton3 Offline
Global Moderator
Global Moderator
I think there is confusion in the use of the words here, between their formal and informal meanings. When you say "normal" in a sense of statistical analysis, it would indicate that the data defines something being inside the bounds of the 6-sigma (std devs). But the word "normal" to most folks just means typical, commonplace, everyday, expected, etc. I would argue that the statistical "normality" of the dilution and resulting wear is demonstrated by the data, itself. These 2.4L engine which have GDI are acting totally "normally"; they do what they do. It's just that you (understandably) find the results undesirable; eg - not acceptable. Further, there can be a big difference between a normal condition and acceptable. Example ... It's normal for an adolescent to be tempted to smoke marijuana, but it's not acceptable. (at least in my house).
So my point is that the data is telling you that the 2.4L GDI dilution of fuel is normal, and the wear results it causes are normal. They're just not desirable.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: GM 2.4L ECOTEC Gen II, 569 UOA samples [Re: 53' Stude] #5138321 06/19/19 09:32 AM
T
T
The original .PNG file on my computer is 1920x1080. Then I upload it. When I open the image in the post and save it, the size is 768x432, and much smaller in file size. Let me know what I am doing wrong.
Re: GM 2.4L ECOTEC Gen II, 569 UOA samples [Re: dnewton3] #5140236 06/21/19 02:20 PM
T
T
My use of the word normal is with respect to what any reasonable consumer and vehicle owner would expect from a manufacturer who's stated goal is to produce a durable, reliable product that is designed, and tested to the highest standards with the knowledge and experience available. GM promoted GDI for the its improved emission standards, performance and efficiency, but failed to disclose the known problems with GDI system, fuel dilution which causes viscosity loss, increased wear, and pre-mature failure of a number of major components. This occurs at above normal averages, even when all preventative maintenance and recommendations are followed. Is this typical , some would say yes. Is it normal and expected, some would say, including myself, no. Some countries have enacted legislation to support consumer's expectation that vehicles are designed and produced with a reasonable expectation of durability.
In other cultures, the temptation of banded substances is rare and not normal.
