Monroe made in Turkey
by atikovi - 02/18/20 03:31 PM
NSFBitog
by Ursatdx - 02/18/20 03:25 PM
Wider rear tires?
by drop - 02/18/20 03:07 PM
ROCKAUTO Coupon Codes
by jrvn - 02/18/20 02:24 PM
Gold (brass?) flecks in drained Honda ATF
by TNM6i - 02/18/20 12:10 PM
What happened to licensed ATF clones?
by TimN3QE - 02/18/20 12:08 PM
E85 in non-flex fuel Ford Expy ~2013
by DriveHard - 02/18/20 11:46 AM
Jacking up a car by itself
by Alfred_B - 02/18/20 11:44 AM
Valvoline MST in 2015 Macan S
by musclecarscott - 02/18/20 11:43 AM
PH10060 oversized?
by bullwinkle - 02/18/20 11:36 AM
Toyota Sienna
by cb_13 - 02/18/20 10:05 AM
Larger fuel filter on Riding mower?
by dedonderosa - 02/18/20 10:03 AM
Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
spbonus, mtnwzrd11, TnTA2, TimN3QE, musclecarscott
70742 Registered Users
105 registered members (762fermeandyou, ABerns, 53' Stude, ArrestMeRedZ, andreigbs, 11 invisible), 2,293 guests, and 18 spiders.
Topics301,617
Posts5,199,181
Members70,742
Page 1 of 3 1 2 3
Brakes on my F250 #5136124 06/16/19 07:57 PM
Donald Offline OP
I could hear the brakes screeching on my F250 and made an appt for Thur to get pads and rotors done. No time to do them myself.
Backing out of my daughters drive today one of the front pads fell off in the driveway.
I was surprised since I really had not let the brakes go (very much).
2015 Ford F-250 w/Powerstroke
Re: Brakes on my F250 [Re: Donald] #5136129 06/16/19 08:04 PM
A
atikovi Online Content
Online Content
A
How does a pad fall out of a caliper mounted on the truck? I mean, it's pretty much captive between the caliper bracket and caliper. You can't change pads without removing the caliper.
Re: Brakes on my F250 [Re: atikovi] #5136132 06/16/19 08:07 PM
K
Kruse Offline
K
A WAG is that the friction pad separated from the steel backing plate and fell out.
Re: Brakes on my F250 [Re: Kruse] #5136139 06/16/19 08:20 PM
spasm3 Offline
That would be my guess as well could have rusted out.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Brakes on my F250 [Re: Donald] #5136303 06/17/19 04:50 AM
M
Miller88 Offline
M
If you run the pads down to metal, there is enough of a gap between the caliper and the rotor that they can fall out.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Brakes on my F250 [Re: Kruse] #5136330 06/17/19 05:49 AM
supton Offline
My guess too. I had that happen on a pad that still had 3/4 of the material left. Rustbelt problems. Although 4 years old is a bit early I'd think, on my vehicles around the 5 year mark is where I've seen the start of delamination.
2011 Toyota Camry, base, 2.5L/6MT, 201k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: Brakes on my F250 [Re: Donald] #5136343 06/17/19 06:15 AM
Donald Offline OP
Here is what we found on the driveway.
Re: Brakes on my F250 [Re: Donald] #5136345 06/17/19 06:19 AM
supton Offline
Dang. And people say I'm weird for pulling my brakes apart on a yearly basis--I have to wonder if you have a frozen slider pin or the like to take out a pad that fast.
That pad backing plate looks pretty thin, like it had been like that for some time... I wouldn't drive it now, it must be piston on rotor now.
On the flip side you didn't lose brakes like I did (pedal to the floor until the piston pumped up).
Re: Brakes on my F250 [Re: Donald] #5136356 06/17/19 06:50 AM
2015_PSD Offline
I can only imagine what the condition of the frame and underpinnings must be. Road salt FTW!
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Mahle]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Brakes on my F250 [Re: Donald] #5136406 06/17/19 08:07 AM
W
WyrTwister Offline
W
Never heard of a brake pad falling out !
Thankful I do not live in the salt belt .
Wyr
God bless
Re: Brakes on my F250 [Re: Donald] #5136417 06/17/19 08:22 AM
L
Linctex Offline
L
I'm having a hard time seeing how this happened.
There's no friction material left at all, and the backing plate is worn severely.
Most people are aware of a brake wear issue before they get to this serious condition.
Re: Brakes on my F250 [Re: Donald] #5136455 06/17/19 09:12 AM
M
mk378 Online Content
Online Content
M
It was worn down to metal for some time then it was about to wear down to nothing. The screeching sound of metal on metal means replace pads and rotors immediately. You will only get a few stops like that before the final stage where nothing happens when you press the brake pedal.
Re: Brakes on my F250 [Re: Donald] #5136473 06/17/19 09:34 AM
T
thastinger Offline
T
Must have been a nice sparkler fireworks show at every stop light
Re: Brakes on my F250 [Re: thastinger] #5136507 06/17/19 10:34 AM
L
Linctex Offline
L
Hmmmm.... Brake rotors are likely just cast iron or cast steel,
and the brake pads are most likely mild steel - - so probably not so much
Re: Brakes on my F250 [Re: Donald] #5136515 06/17/19 10:42 AM
Donald Offline OP
So I know I needed brakes, but was not aware I was down to no brake pad. Getting brakes on Thur. Not driving until then except to the shop.
The vehicles gets sprayed yearly with CarWell so no rust on frame or body. Brakes cannot sprayed.
Page 1 of 3 1 2 3
