Ok, so my 4T60 started slipping the other day on a long drive, and I was in the middle of nowhere, in rural Canada, without any ATF available either on-hand or closeby. I did have a couple quarts of motor oil though.
Cause of the slipping was of course low fluid from a pan leak that I somehow hadn't detected. I was able to make it home, top up the fluid, and all is well.
But if the slippage was so much that the car was undriveable, how bad would it have been to add the motor oil as an interim measure? Would a couple quarts of motor oil mixed with the ATF have destroyed the transmission? Or would it have been good enough to make it a couple hundred miles until I was able to do a pan drop and complete flush?
Any thoughts?
Any thoughts?
