Shop light LED conversion bone head move.
by JTK. 07/21/19 02:27 PM
The Hunt Begins...
by MCompact. 07/21/19 02:10 PM
Cambodia Forest, River and Beach.
by Voleak. 07/21/19 02:01 PM
Foxwoods Resorts Casino 301 at NHMS
by bdcardinal. 07/21/19 01:29 PM
2017 Ram 1500 rear brake lines
by LAGA. 07/21/19 01:27 PM
yacco oils, better than motul (xcess)?
by pep808. 07/21/19 01:22 PM
Scotty K. has finally let me down
by Lolvoguy. 07/21/19 01:03 PM
Exxon/Mobil Synergy Supreme +
by incognito_2u. 07/21/19 12:51 PM
Son going to bring another vehicle home
by vavavroom. 07/21/19 12:43 PM
The stent didn't work, now what?
by andyd. 07/21/19 12:34 PM
TV shows you enjoy
by 53' Stude. 07/21/19 12:14 PM
Replaced strut mount. Still binding
by lairdwd. 07/21/19 11:07 AM
2019 Jeep Wrangler Unlimited Rental
by 2015_PSD. 07/21/19 10:33 AM
Galvanic corrosion
by LeakySeals. 07/21/19 10:20 AM
Ford EcoBoost Oil Catch Can?
by JeffKeryk. 07/21/19 10:17 AM
Hybrid-Keep or Trade
by Spector. 07/21/19 10:05 AM
STP S 4967 NEW FILTER CUT OPEN
by 53' Stude. 07/21/19 09:03 AM
Is my mower battery going to die one day?
by motor_oil_madman. 07/21/19 08:26 AM
andrewv, AMHKCMO, vanenk, grikor, Mikelima
68723 Registered Users
102 registered members (4WD, 1WildPig, aquariuscsm, 2003f7, AdditiveOCD, 17 invisible), 2,482 guests, and 28 spiders.
Topics292,201
Posts5,018,601
Members68,723
Most Online2,967
Mar 10th, 2019
Thoughts On Resizing Loaded Ammo #5135997
06/16/19 06:47 PM
06/16/19 06:47 PM
Houston, TX
2015_PSD Offline OP
2015_PSD  Offline OP
Houston, TX
I have about 1500 rounds of loaded .22-.250 ammunition that has been once-fired (fireformed) and subsequently neck sized only for my brother’s varmint rifle. We managed to shoot the barrel out before using all of the ammo and (of course) it will not chamber in his new Hart barrel.
I am considering full length resizing it--removing the expander/decapping assembly from the die and tumbling afterwards to remove the sizing lube. This is not an optimum solution, but at the same time, I do not relish breaking down that many rounds and reloading them again.
I have done this in the past with .223 rounds with no issues whatsoever, but not with a medium sized cartridge like a .22-.250.
What say you? Anyone do this and have good luck or am I stuck pulling them down?
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & MB (Purflux) filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum Euro 0W-40 & Mann filter]
Re: Thoughts On Resizing Loaded Ammo [Re: 2015_PSD] #5136003
06/16/19 06:51 PM
06/16/19 06:51 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Subscribed.
God Bless Our Troops
Re: Thoughts On Resizing Loaded Ammo [Re: 2015_PSD] #5136007
06/16/19 06:52 PM
06/16/19 06:52 PM
Ruidoso, NM USA
ammolab Offline
ammolab  Offline
Ruidoso, NM USA
Not ever a thing you want to do...A FL resizes the case neck AND reduces the bullet diameter if you size a loaded round.
Bullet diameter and neck tension will vary greatly....accuracy poor.
1998 Jeep Cherokee
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: Thoughts On Resizing Loaded Ammo [Re: ammolab] #5136040
06/16/19 07:32 PM
06/16/19 07:32 PM
Houston, TX
2015_PSD Offline OP
2015_PSD  Offline OP
Houston, TX
Originally Posted by ammolab
Not ever a thing you want to do...A FL resizes the case neck AND reduces the bullet diameter if you size a loaded round. Bullet diameter and neck tension will vary greatly....accuracy poor.
There are also shoulder "bump" dies that do not touch the neck and I may have to look into one of those. I use Redding competition bushing dies to control my neck tension, so I would not want to mess that part up. These are not "junk" rounds, if they were I would just break them down over time and reload them.
Edit: I see that Redding makes a body die that will do exactly what I am attempting. Problem solved.
Re: Thoughts On Resizing Loaded Ammo [Re: 2015_PSD] #5136065
06/16/19 07:57 PM
06/16/19 07:57 PM
PA USA
rustypigeon Offline
rustypigeon  Offline
PA USA
Originally Posted by 2015_PSD
[There are also shoulder "bump" dies that do not touch the neck and I may have to look into one of those.
I was going to suggest the shoulder bump dies. I have a set for my .223 since I have several rifles in that caliber.
1994 Toyota Pickup 205,000mi
1999 Mazda Protege 230,000mi
2000 BMW 323i 130,000mi
2005 Toyota Highlander 200,000mi
Re: Thoughts On Resizing Loaded Ammo [Re: 2015_PSD] #5136389
06/17/19 08:44 AM
06/17/19 08:44 AM
Jupiter, Florida
Cujet Online content
Cujet  Online Content
Jupiter, Florida
Loose ammo is safe because it's not contained. When loaded ammo is tightly contained, it's risk factor goes way up, such as a chambered round with a plugged barrel. For that reason alone, I'm not sure the risk-reward ratio is worthwhile.
Re: Thoughts On Resizing Loaded Ammo [Re: 2015_PSD] #5136424
06/17/19 09:31 AM
06/17/19 09:31 AM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I don't have any experience reloading any rifle cartridges (or any necked pistol cartridges), but I use a Lee Factory Crimp Die for my straight/taper walled pistol cartridges. It's made to post size after being loaded, I run it as the final operation when reloading. I see that it exists for the 22-250, but it doesn't explicitly say that the FCD for rifle is for post sizing, unlike the page for pistol caliber FCD.
Rifle:
https://leeprecision.com/reloading-dies/rifle-dies/factory-crimp-die
Pistol:
https://leeprecision.com/reloading-dies/hand-gun-dies/lee-carbide-factory-crimp-die/
Re: Thoughts On Resizing Loaded Ammo [Re: Cujet] #5136462
06/17/19 10:23 AM
06/17/19 10:23 AM
Houston, TX
2015_PSD Offline OP
2015_PSD  Offline OP
Houston, TX
How is it tightly contained? The body die is open ended and seems to be purpose built for this.
Re: Thoughts On Resizing Loaded Ammo [Re: 2015_PSD] #5136466
06/17/19 10:27 AM
06/17/19 10:27 AM
Northern KY
Elkins45 Offline
Elkins45  Offline
Northern KY
Full length resizing dies oversize the neck, when is then brought back up to the correct size by the expander ball. Resizing loaded ammo would squeeze your bullet down quite a bit, possibly resulting in a poor seal and poor fit in the rifling. I doubt it would pose any danger, but accuracy would likely suffer.
If it were me I would pull the bullets and resize the cases. I have no problems with resizing cases with live primers as long as it is done slowly.
Re: Thoughts On Resizing Loaded Ammo [Re: Elkins45] #5136495
06/17/19 11:16 AM
06/17/19 11:16 AM
Houston, TX
2015_PSD Offline OP
2015_PSD  Offline OP
Houston, TX
As noted above, Redding (and others) make body dies to solve the issue I am experiencing. I ordered one this morning and will report back after I have it.
Re: Thoughts On Resizing Loaded Ammo [Re: 2015_PSD] #5136916
06/17/19 06:33 PM
06/17/19 06:33 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Ok and report back how they shoot with a picture of the target!
2004 Corolla 134004
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 75175
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Thoughts On Resizing Loaded Ammo [Re: JohnnyJohnson] #5136981
06/17/19 07:45 PM
06/17/19 07:45 PM
Houston, TX
2015_PSD Offline OP
2015_PSD  Offline OP
Houston, TX
Since the neck is unaffected, I expect they will shoot as intended. Time will tell...
Re: Thoughts On Resizing Loaded Ammo [Re: 2015_PSD] #5137078
06/17/19 09:43 PM
06/17/19 09:43 PM
Sequim, WA
edhackett Offline
edhackett  Offline
Sequim, WA
Don't tumble loaded ammunition. It can break up powder grains and/or remove coatings designed to control the burn rate. There's a risk of altering the powder burn characteristics significantly. It would be safer to just wipe them off.
Ed
Never attribute to engineers that into which politicians, lawyers, accountants, and marketeers have poked their fingers.
