.308 Win or .25-06
by mobilaltima - 12/10/19 01:05 PM
FI cleaners ruin injectors?
by Redright9 - 12/10/19 12:54 PM
Planned Changes at Honda
by The Critic - 12/10/19 12:30 PM
The forgotten Bolens 1253
by Lubener - 12/10/19 11:49 AM
Valvoline High Mileage vs Valvoline Full Synthetic?
by Bettez88 - 12/10/19 10:33 AM
Anything to quiet a noisy Subaru front differential?
by anarchyx34 - 12/10/19 10:15 AM
Consumer Cellular
by CourierDriver - 12/10/19 09:53 AM
Ford 6.2L
by ford46guy - 12/10/19 09:30 AM
2012 Hyundai Santa Fe lights on dash issue
by Urshurak776 - 12/10/19 08:25 AM
Electronic Parking Brakes- Long Term Reliability?
by LoneRanger - 12/10/19 08:17 AM
New Kitchen Faucet Selection: To Pex or Not to Pex ?
by LoneRanger - 12/10/19 07:41 AM
Factory Head Unit/New Speakers
by Duffyjr - 12/10/19 06:35 AM
Valve Stem Carbon Build-up from Oil in DI Engines
by paoester - 12/10/19 03:52 AM
New plugs in 2012 Frontier
by MolaKule - 12/09/19 11:02 PM
SN vs SN+
by natas - 12/09/19 11:02 PM
75w90 conventional vs syn???
by Doublehaul - 12/09/19 10:21 PM
UOA for my extended OCIs
by Kbuskill - 12/09/19 09:34 PM
Question on Job Interview Etiquette
by bunnspecial - 12/09/19 08:40 PM
BucDan, Poboy, Mcbridej74, IvanPletex, tjb59eldo
70087 Registered Users
102 registered members (aquariuscsm, ARCOgraphite, 330indy, allepunta, 53' Stude, 11 invisible), 2,009 guests, and 22 spiders.
Topics298,540
Posts5,137,481
Members70,087
Most Online3,589
Nov 2nd, 2019
York Compressor comes with PAG only #5135983 06/16/19 05:32 PM
B
Beach_dude Offline OP
B
I'm needing to fully flush the PAG oil that comes with York compressors.
What I've traditionally done is simply drain, fill with mineral oil, shake around, attach a drill to the compressor, turn it over for a few seconds at high rpm, flush the input/output ports with mineral oil, and repeat several times.
However, when I've torn apart the systems, there's always residue of two oils in the lines.
Also, I don't want to have to tear apart the compressors to flush with a solvent to let them dry.
Is there a flush that anyone can recommend that won't leave a residue, jack up the piston rings, etc, for an R12 system?
Re: York Compressor comes with PAG only [Re: Beach_dude] #5135992 06/16/19 05:44 PM
sloinker Offline
Why not use alcohol to flush the system? Pump it in and out of the condenser/evaporator and lines? Then covert the whole system to PAG oil? When we flush our Hydrogen monitoring systems on our generators during maintenance outages we use about 20 gallons and just pump it in and out after circulating it for a day. I suppose you could just flush the compressor but alcohol isn't much of a lubricant and you may damage it.
'16 Tiguan TSI Ravenol VST 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: York Compressor comes with PAG only [Re: Beach_dude] #5136008 06/16/19 05:53 PM
B
B
That's the issue with using something like alcohol... It was destroy the compressor.
As for why not use PAG, because it's an R12 system.
Re: York Compressor comes with PAG only [Re: Beach_dude] #5136019 06/16/19 06:04 PM
Chris142 Offline
Use ester oil. Its compatible and mixes with any left over pag or mineral oil. If your really concerned put ester in it, shake it and pour it out. Capacity is only 10oz.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: York Compressor comes with PAG only [Re: Chris142] #5136023 06/16/19 06:08 PM
B
B
Ester is only compatible with R134a, not R12.
There would still be a residue of ester in the system.
Re: York Compressor comes with PAG only [Re: Beach_dude] #5136062 06/16/19 06:52 PM
Chris142 Offline
Wrong! Every r12 car I work on gets Ester. It even says its OK for r12 right on the bottle. Ester is what you use when retrofitting to r134a as its comparable with all pag, mineral oil and r12 or r134a refrigerants that may be left in the system.
