Any upgrades worth it or USB dock suggestion
by bowlofturtle. 07/21/19 11:00 PM
Tesla 3 Wheels -- Interesting Case
by Y_K. 07/21/19 10:56 PM
Dewalt Glock or Cat? Maybe OSHA colored?
by Marco620. 07/21/19 10:39 PM
Good petroleum free tire dressing ?
by JDMiller. 07/21/19 07:52 PM
2008 Infiniti G37 P0011 and P0524
by The Critic. 07/21/19 07:23 PM
Zamboni
by Snagglefoot. 07/21/19 07:18 PM
air filter for rav4 hybrid
by NH73. 07/21/19 07:16 PM
MB C250 driver seat bottom cover replacement
by The Critic. 07/21/19 06:56 PM
Centric PQ Pro Brake Pads
by The Critic. 07/21/19 06:43 PM
Latency on fiber connectivity to Internet
by Donald. 07/21/19 05:41 PM
102K on Plugs - '13 Chevy Cruze LS
by 99Saturn. 07/21/19 03:38 PM
Shop light LED conversion bone head move.
by JTK. 07/21/19 02:27 PM
The Hunt Begins...
by MCompact. 07/21/19 02:10 PM
Cambodia Forest, River and Beach.
by Voleak. 07/21/19 02:01 PM
Foxwoods Resorts Casino 301 at NHMS
by bdcardinal. 07/21/19 01:29 PM
2017 Ram 1500 rear brake lines
by LAGA. 07/21/19 01:27 PM
yacco oils, better than motul (xcess)?
by pep808. 07/21/19 01:22 PM
Scotty K. has finally let me down
by Lolvoguy. 07/21/19 01:03 PM
Exxon/Mobil Synergy Supreme +
by incognito_2u. 07/21/19 12:51 PM
Son going to bring another vehicle home
by vavavroom. 07/21/19 12:43 PM
Kcpaz, Albush1, mwc951, bobdz, andrewv
68727 Registered Users
26 registered members (chance, 4WD, AnthemBassMan, Char Baby, alcyon, csandste, 4 invisible), 700 guests, and 16 spiders.
Topics292,209
Posts5,018,974
Members68,727
Most Online2,967
Mar 10th, 2019
Troybilt Pony ride on dropped dead #5135930
06/16/19 05:21 PM
06/16/19 05:21 PM
USA
RDMgr Offline OP
RDMgr  Offline OP
USA
I’m looking for some direction. I was mowing the grass with a Troybilt Pony ride on. I did hit a large stone that my grandson left in the grass but the mower continued to operate normally. About ten minutes later the mower died. It just shutdown and doesn’t even turn over. I was thinking that it might be the dead man switch under the seat. Does anybody have any other suggestions? Could it be the ignition switch?
Re: Troybilt Pony ride on dropped dead [Re: RDMgr] #5135948
06/16/19 05:42 PM
06/16/19 05:42 PM
Raleigh NC
MrMoody Offline
MrMoody  Offline
Raleigh NC
There are also interlock switches in the clutch/brake pedal, Fwd/N/Rev selector, and the PTO lever. Does it "clunk" when you turn the key to start it?
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
"Fob" and "Noack" are not acronyms.
Re: Troybilt Pony ride on dropped dead [Re: RDMgr] #5135963
06/16/19 06:02 PM
06/16/19 06:02 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Safety switches everywhere like MrMoody says.
Probably one of those.
Re: Troybilt Pony ride on dropped dead [Re: RDMgr] #5135964
06/16/19 06:04 PM
06/16/19 06:04 PM
SE Alabama
Fawteen Offline
Fawteen  Offline
SE Alabama
I'd check for fuel first (because it's easy). Once you've eliminated that, start checking with your voltage meter until you find the problem.
2014 Silverado
2014 Equinox
1972 Olds 442 Convertible
1918 Model T
Re: Troybilt Pony ride on dropped dead [Re: RDMgr] #5135996
06/16/19 06:47 PM
06/16/19 06:47 PM
Prospect, KY
spk2000 Offline
spk2000  Offline
Prospect, KY
Rock didn't puncture something and let oil drain out? Can engine be turned over by manually rotating the stator?
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: Troybilt Pony ride on dropped dead [Re: RDMgr] #5136009
06/16/19 06:53 PM
06/16/19 06:53 PM
USA
RDMgr Offline OP
RDMgr  Offline OP
USA
I checked fuel first but even if it was out or no supply it should still turn over. Turning the key produces nothing. No clicking or turning over at a all, just dead. I guess I have a lot of stuff to check and eliminate one at a time.
Re: Troybilt Pony ride on dropped dead [Re: RDMgr] #5136039
06/16/19 07:32 PM
06/16/19 07:32 PM
NC
BigD1 Offline
BigD1  Offline
NC
Raise the seat, and check the fuse!
Do the lights work when the switch is on?
My brother's was acting up not cranking no nothing except for the lights working. Changed the ignition switch, and then the lights did not work. It was blowing a fuse. Turns out he bought one of the China copy switches that did not work. Put the real switch on, changed the fuse, and it cranked right up.
1992 Toyota Pickup--Quaker State Advanced Durability 10W-30--Motorcraft 910S
Re: Troybilt Pony ride on dropped dead [Re: RDMgr] #5136069
06/16/19 08:04 PM
06/16/19 08:04 PM
NE Ohio
knerml Offline
knerml  Offline
NE Ohio
First things first. There is a fuse on the battery that might have blown.
After that, check interlocks.
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W30 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport AWD 2.0T Castrol Edge 5W40 & OEM/Mann W811/80 Filter
Re: Troybilt Pony ride on dropped dead [Re: RDMgr] #5136082
06/16/19 08:16 PM
06/16/19 08:16 PM
Mississippi
TheLawnRanger Offline
Mississippi
I had something similar happen with a Troy-Bilt Pony. I was mowing close to dark and ran over a large root that I thought I had removed. It stopped running soon after. It would crank back up and run for a while and then suddenly stop again. Once I jacked the mower up I saw what had happened. The root had bent one of the blades. The mower would run fine until I drove over a part of the yard where the dirt was slightly higher. At that point, the blade would dig into the ground and the engine would suddenly stop. I changed the blade and all was well.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: Troybilt Pony ride on dropped dead [Re: RDMgr] #5141019
06/22/19 03:30 PM
06/22/19 03:30 PM
USA
RDMgr Offline OP
RDMgr  Offline OP
USA
For anyone interested, I started to go through the mower today. I started with the ignition switch, the easiest, and the wires had become unplugged. Plugged the switch in and it started right up. Thanks everyone.
Re: Troybilt Pony ride on dropped dead [Re: RDMgr] #5141060
06/22/19 04:23 PM
06/22/19 04:23 PM
Massachusetts
DaHen Offline
DaHen  Offline
Massachusetts
Good. Thanks for the update.
'06 Altima
ECHO: PB-255LN Blower
Husqvarna: 445E 18" Chain Saw
McCulloch: Electramac EM300S 16" Chain Saw
John Deere: TRS-26 Snow Blower
Craftsman, (Husqvarna in disguise): 22" Lawn Mower
Re: Troybilt Pony ride on dropped dead [Re: RDMgr] #5141094
06/22/19 04:52 PM
06/22/19 04:52 PM
Mississippi
Mississippi
I'm glad to hear it's working again.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Re: Troybilt Pony ride on dropped dead [Re: DaHen] #5141164
06/22/19 07:04 PM
06/22/19 07:04 PM
Raleigh NC
MrMoody Offline
MrMoody  Offline
Raleigh NC
Yes, thanks, many times we never hear what happens.
The rock damage on the blade may have increased the vibration enough to work the plug loose.
