Originally Posted By: paulri
So oil will hold varnish until it has no more capacity, and then it will lay it down on the engine.
Originally Posted By: Shannow
Yep
I have a few questions:
Is there an index for varnish holding capacity? e.g. Oil anti varnish index to compare different oil? Or does it depend on base oil + add packages, etc.?
if not, Can VOA give an idea of this capacity or what is left of it in case of UOA?
So any oil regardless of how much varnish it can hold, will deposit or "lay down" the varnish when it is cold enough to get to it's saturation point. No?
do cars in cold climates have more varnish in general? I assume based on your video, the colder it gets, the less varnish the oil can hold ... Does the rest is deposited like moisture in hot air vs. cold air or am i over-simplifying it?
Thanks
