HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Breaking in the new clutch. Backwards.
by Chris142 - 02/22/20 02:18 PM
Toyota 0W20 $2.95 + shipping YMMV
by Q451990 - 02/22/20 01:34 PM
Toyota Catalytic Converter (B2)
by MaximaGuy - 02/22/20 01:31 PM
The Camry lives!
by 53' Stude - 02/22/20 01:01 PM
Don't Try This at Home
by MrMoody - 02/22/20 12:11 PM
Fake Online Parts
by Gebo - 02/22/20 11:04 AM
Valvoline Premium Blue Restore questions
by Hubbs1982 - 02/22/20 09:54 AM
What is this
by Farnsworth - 02/22/20 09:08 AM
Confused with Battery Issue on Laptop
by BISCUT - 02/22/20 08:54 AM
Autel MP808K
by Nyquist - 02/22/20 08:54 AM
Pennzoil 400
by Snagglefoot - 02/22/20 08:41 AM
Smelly AC in F150's.
by Cujet - 02/22/20 08:39 AM
jb5150, ZProfessor, ArgleBargle, Dannycal, ManishHonda
70780 Registered Users
108 registered members (928, 2dogs, 53' Stude, 10ecfarmer, AJB0009, antonmnster, 10 invisible), 2,157 guests, and 19 spiders.
Topics301,795
Posts5,202,864
Members70,780
A/C Blower Motor #5135837 06/16/19 02:38 PM
H
HouseTiger Offline OP
H
Vehicle is a 1992 Ford Explorer, Eddie 'edward' Bauer 4WD, 4 liter V6
Air conditioner pumps cold air; however, the blower does not seem to have a 'high' speed anymore, even on Max Cool. I have three of four speeds, not counting 'off': low, medium-low, medium-high, and what used to be the 'blow you out the window' high remains on medium high.
Fuses are good. If I understand correctly, a faulty resistor would lock the fan speed on high only. That's not the case. What am I missing?
Thanx in advance.
Re: A/C Blower Motor [Re: HouseTiger] #5135844 06/16/19 02:48 PM
B
bullwinkle Offline
B
Fan switch or wiring would be my guess.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: A/C Blower Motor [Re: HouseTiger] #5135848 06/16/19 02:55 PM
M
maxdustington Online Content
Online Content
M
Edward Bauer edition LOL!
99 Toyota Tercel CE 5EFE/C151
Re: A/C Blower Motor [Re: HouseTiger] #5135855 06/16/19 03:08 PM
O
oldhp Offline
O
Isn't there a blower motor high speed resister in there? I'm pretty sure if the resister goes out the fan will still blow on the lower speeds.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: A/C Blower Motor [Re: oldhp] #5135866 06/16/19 03:17 PM
H
HangFire Offline
H
Dakotas were infamous for this, I've replaced 2, looks like a similar part exists for yours. Try to find it and see if anything is burnt.
https://www.carparts.com/details/Fo...NQNoEAQYASABEgKlEvD_BwE&gclsrc=aw.ds
Various musings: http://hangfire.net
Re: A/C Blower Motor [Re: oldhp] #5135894 06/16/19 03:40 PM
H
H
Thanks, I'll have to check out (as in find) the resistor module. I've been told the fan will only blow on high, or as you stated, on the lower speeds - from two different parts stores (Yeah, I know, consider the sources). If my guess is right, on mine the resistor would be on the side of the housing for the evaporator. ( ?? )
Re: A/C Blower Motor [Re: maxdustington] #5135899 06/16/19 03:45 PM
H
H
For what it cost way back then when new . . . yeah, we called it 'Sir Edward' until it was paid off.
Re: A/C Blower Motor [Re: HouseTiger] #5136047 06/16/19 06:41 PM
E
edwardh1 Offline
E
my 84 olds had same prob think it was a relay
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: A/C Blower Motor [Re: HouseTiger] #5136066 06/16/19 07:00 PM
W
wrcsixeight Offline
W
My 89 Dodge at one point had 3 of 4 of the lower speeds, but turbo was not available, it would just stop spinning.
This vehicle runs full blower motor current through the speed switch itself.
i found the contacts for 'highest speed' were burnt and occluded with carbon and the wiring insulation leading to the speed switch were burnt near the connectors.
I Still have the same switch, just cleand and polished the contacts, added a bit more spring pressure, and upgraded the wire size leading from fuse block to the switch and from switch to the resistor and blower motor. Now highest speed has even more 'turbo' as significantly higher voltage is now reaching the blower motor. It also used to blow 30 amp fuses regularly before this modification, now the 20 amp fuse never blows.
Re: A/C Blower Motor [Re: HouseTiger] #5136338 06/17/19 06:06 AM
rollinpete Offline
I would replace the resistor,mine lost some of the speeds also, I replaced it about 4 years ago no problems since.
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 190k
Shell Rotella Gas Truck 5w30
www.youtube.com/channel/UCFFOhps9dt9yNI_o19vImdA/featured
Currently under the influence of oil shocked2
Re: A/C Blower Motor [Re: HouseTiger] #5145888 06/27/19 06:41 PM
01rangerxl Offline
Check the resistor first. Debris can accumulate in the evaporator box and cause issues. Losing some speeds but working on others is typically the resistor, but pull the blower motor too and clean everything out. I found burned leaves in mine. There were grommets to seal around the wiper arms and keep junk out, but not sure if they are still available.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 236K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 202K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 254K miles
