To Havoline Or Not
by BlueOvalFitter - 12/11/19 04:27 AM
Stickiest/best handling all terrain tire?
by Stickygreen - 12/11/19 03:37 AM
And so it begins. Winter 2019-2020.
by DejaVue - 12/11/19 12:13 AM
reference for tires wearing faster when new?
by NissanMaxima - 12/10/19 10:46 PM
2.4L GDI Turbo available?
by 2014_K5_Optima - 12/10/19 10:08 PM
rotary compressor breathing air
by MasterBlaster - 12/10/19 09:33 PM
Substitute for Polaris hub oil?
by The_Eric - 12/10/19 08:53 PM
'20 Hyundai Sonata -- Wow-ee! Looks!
by paoester - 12/10/19 07:11 PM
2021 Chevrolet Suburban and Tahoe Revealed
by E365 - 12/10/19 06:56 PM
Do you try to book on widebodies?
by fdcg27 - 12/10/19 06:25 PM
Carbon Farming
by SubLGT - 12/10/19 05:40 PM
How Many Vehicles Do You Maintain?
by Passport1 - 12/10/19 04:23 PM
Bypass Setting vs Subaru
by Al - 12/10/19 03:10 PM
13 chevy equinox I4 engine oil in filter box
by Fitter30 - 12/10/19 02:04 PM
Driven - Direct Injection Oils
by buster - 12/10/19 01:59 PM
.308 Win or .25-06
by mobilaltima - 12/10/19 01:05 PM
FI cleaners ruin injectors?
by Redright9 - 12/10/19 12:54 PM
Planned Changes at Honda
by The Critic - 12/10/19 12:30 PM
Bruce147, snowplow, Rovingcowboy, 2014_K5_Optima, Peter_Tremonti
70098 Registered Users
55 registered members (Amkeer, Aichiguy, bernardch, BlueOvalFitter, BloodyButUnbowed, 77GrandPrix, 7 invisible), 715 guests, and 23 spiders.
Topics298,559
Posts5,138,097
Members70,098
Most Online3,589
Nov 2nd, 2019
Painting Garage Floor #5135822 06/16/19 02:23 PM
R
raaizin Offline OP
R
I would like to paint my garage floor 2-1/2 car garage. It was repainted many years ago( we moved in 1993 and previous owner painted it.) It is currently light grey. Thereare some areas mainly in the tire tracks where that the paint has peeled off. I am not sure what to use. Not sure if epoxy will adhere to the painted areas. I dont want to spend for epoxy paint and have it come up. Do they still make oil based paint anywhere? Any ideas
Re: Painting Garage Floor [Re: raaizin] #5135838 06/16/19 02:38 PM
skyactiv Offline
Whatever you do, buy your paint at an actual paint store, not a box store. PPG makes real industrial coatings for the U.S. subs, airplanes...
The only concern is if the paint will work with temperature extremes. I'd power wash it first.
http://www.ppghighperformancecoatings.com/Products/By-Brand/MegaSeal™/MegaSeal™-High-Performance-Urethane.aspx
Sold: 13' VW GTI 3 door 6 speed manual
Me: 18' Elantra Sport 6 speed manual
Re: Painting Garage Floor [Re: raaizin] #5135970 06/16/19 05:10 PM
F
Fawteen Offline
F
If the existing coating is peeling off, then you'll want to remove as much as possible. If you don't then it will only continue to fail.
You don't need the paint store industrial coatings-I've had the 2 component epoxy on all 5 bays of my garage floor for several years now and it wears like iron. Surface prep is the key-done right and it works great. Done incorrectly and no product will perform well.
Re: Painting Garage Floor [Re: Fawteen] #5136000 06/16/19 05:49 PM
R
raaizin Offline OP
R
The current floor is NOT peeling , do you recall brand you used
Re: Painting Garage Floor [Re: raaizin] #5136022 06/16/19 06:06 PM
F
flanso Offline
F
Rustoleum makes a solvent based, two-part epoxy floor coating. I found it at Zoro. It has been very durable on my garage floor. But I sanded and power washed off the old paint and then acid etched the bare concrete.
https://www.zoro.com/rust-oleum-floor-coating-kit-2-gal-dunes-tan-238466/i/G1263936/
Re: Painting Garage Floor [Re: raaizin] #5136160 06/16/19 08:44 PM
N
NYSteve Offline
N
You're going to need an expert or two to really tell you what is possible. I had my floors epoxied as soon as I moved into my house. This is who I used and they are very friendly and chatty. They will tell you what's possible:
https://www.strongholdfloors.com/
GarageJournal is another good forum for flooring recos.
Re: Painting Garage Floor [Re: raaizin] #5136520 06/17/19 10:49 AM
Donald Offline
Unless you do it before you move in, how do people clear the garage floor? Out on driveway under tarp? Stuff on one half, do other half, then swap? If you only do half, does seam show?
2015 Ford F250 w/Powerstroke
Re: Painting Garage Floor [Re: raaizin] #5136574 06/17/19 11:56 AM
K
KrisZ Offline
K
I did mine few months ago with the rustoleum epoxy kit, it is water based, even though it's a two part product.
It only comes with a citric acid etch, so I would imagine it being way too weak for old and soiled garage floors.
My concrete slab was brand new and I still washed it twice with a heavy duty degreaser before I etched.
From my understanding, for any epoxy to adhere properly and for a long time, it pretty much needs a bare concrete that is very well cleaned and degreased.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: Painting Garage Floor [Re: raaizin] #5136575 06/17/19 11:57 AM
K
kschachn Offline
K
Or properly ground down, that is the only solution for an oily or greasy floor.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 428K
2000 Toyota ECHO, 284K
Re: Painting Garage Floor [Re: raaizin] #5137084 06/17/19 08:53 PM
P
P10crew Offline
P
I would never paint a shop floor. I don’t care what anyone says.....it will not hold up period!
Try welding over a painted floor. Try rolling a 4000 lb lathe on rigging rollers. Brake cleaner, carb cleaner, brake fluid. Jack stands. Leave it bare!
Re: Painting Garage Floor [Re: raaizin] #5137179 06/18/19 12:07 AM
splinter Offline
PUP 0W-40
Total Quartz 5W-40
M1 5W-50
Past performance is no guarantee of future results.
