New Prestone Products
by Snagglefoot - 05/30/20 09:17 PM
BEST OBD2 scanner for UNDER $100
by flinter - 05/30/20 08:44 PM
Oil Drain vs Extraction
by js1956 - 05/30/20 08:08 PM
Toro SR Won't Stop Running
by jkasch - 05/30/20 08:05 PM
Lexus RX350 Oil Filter Housing Question (with pic)
by CrackyWainwright - 05/30/20 07:57 PM
Oil Filter and Coolant Question
by maverickfhs - 05/30/20 07:33 PM
Second change on rebuilt LS
by KirklanC - 05/30/20 07:05 PM
Certified Used Toyota; 8 miles.
by simple_gifts - 05/30/20 05:47 PM
Motul Specific LL01-FE 5w-30 for BMW S55
by sharpmoney - 05/30/20 04:36 PM
Thinking of Buying Compressor
by Mr_Luke - 05/30/20 04:16 PM
Fiat 500 transmission fluid type
by oddrodtodd - 05/30/20 03:53 PM
Help with Riding Mower for Small Yard
by YardWork - 05/30/20 03:51 PM
The ole’ robin egg passed
by 53' Stude - 05/30/20 03:33 PM
Left OR Right?
by MolaKule - 05/30/20 01:46 PM
Space X launch
by MrQuackers - 05/30/20 01:33 PM
Rotella Truck 5W-30 Disco'ed at Home Depot
by josephp732 - 05/30/20 01:17 PM
juca, jrow96, Kotsos, sharpmoney, Dermented
71581 Registered Users
101 registered members (apham8, andyd, 2015_PSD, 77GrandPrix, aba4430, 12 invisible), 2,049 guests, and 50 spiders.
Topics306,066
Posts5,285,841
Members71,581
Comparison engine oil ACEA A5/B5 ILSAC GF4/5 and ACEA A3/B3/B4 #5135435 06/16/19 05:24 AM
P
Pidziek Offline OP
P
Hi,
I have a question for you, dear colleagues.
For most cars, the specification ACEA A5/B5 ILSAC GF-4/5 is recommended.
Example of LEXUS, TOYOTA.
How the use of oil of the same viscosity, but in the A3/B3/B3/B4 specification, affects wear and engine protection?
There is a theory that A5/B5 light running oils cause less high-temperature deposits, lacquers and deposits, especially on the rings.
On the other hand, others say and write that the use of A3/B3 oil in LEXUS GS for example causes a smaller amount of so called shavings.
Has anyone investigated this topic and whether it is better to take into account the specification e. g. ILSAC GF-4/5 etc. or the most important is the oil film strength, which is higher in A3/B3 oils?
I am not talking about ecology but about cleanliness of the engine, amount of deposits and resistance to wear and tear.
Please let me know. Thank you.
Re: Comparison engine oil ACEA A5/B5 ILSAC GF4/5 and ACEA A3/B3/B4 [Re: Pidziek] #5135451 06/16/19 06:15 AM
Y
yowps3 Offline
Y
This is the same question I have.
My car specifies ACEA A5 in 5W30
What is difference between ACEA A5 & ILSAC GF-5?
Also many A5 oils don't meet API SN spec only older API
Re: Comparison engine oil ACEA A5/B5 ILSAC GF4/5 and ACEA A3/B3/B4 [Re: yowps3] #5135454 06/16/19 06:21 AM
P
Popsy Offline
P
Because of ZDDP limits in 30 grade and under for API SN.
96 Barchetta, 300V 5W40 | Forfour 95, M1 0W40
Mazda 6 2.3, Castrol 0W30 | Colt Ralliart, 300V 5W40
Re: Comparison engine oil ACEA A5/B5 ILSAC GF4/5 and ACEA A3/B3/B4 [Re: yowps3] #5135456 06/16/19 06:25 AM
B
bbhero Online Content
Online Content
B
Actually Pennzoil Platinum and Mobil 1 both meet ACEA A5 , API SN and Dexos Gen 2 and ILSAC GF-5.
.Those are the only two I know of from the top of my head that do meet all of those specs...
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: Comparison engine oil ACEA A5/B5 ILSAC GF4/5 and ACEA A3/B3/B4 [Re: Popsy] #5135458 06/16/19 06:30 AM
Y
yowps3 Offline
Y
In that sense it's better to use ACEA A5 API SJ full ZDDP oil circa 1000ppm zddp than 800ppm API SN standard ?
Re: Comparison engine oil ACEA A5/B5 ILSAC GF4/5 and ACEA A3/B3/B4 [Re: yowps3] #5135459 06/16/19 06:32 AM
B
Online Content
B
Just told you....
Pennzoil Platinum and Mobil 1 both meet ACEA A5 and API SN and SN+.... And ILSAC GF-5... And Dexos Gen 2...
These oils do exist... Their PDS states so very clearly.
Re: Comparison engine oil ACEA A5/B5 ILSAC GF4/5 and ACEA A3/B3/B4 [Re: bbhero] #5135470 06/16/19 07:02 AM
Y
yowps3 Offline
Y
Originally Posted by bbhero
Just told you....
So what benefits does the A5 standard bring over just API SN / GF-5 ?
Re: Comparison engine oil ACEA A5/B5 ILSAC GF4/5 and ACEA A3/B3/B4 [Re: yowps3] #5135493 06/16/19 07:48 AM
B
Online Content
B
If I am remembering correctly the A5 is for higher performance motors that spec a 5w30 oil and longer change interval has well...
It is a good spec. Very similar to Dexos Gen 2..
Re: Comparison engine oil ACEA A5/B5 ILSAC GF4/5 and ACEA A3/B3/B4 [Re: bbhero] #5135497 06/16/19 07:55 AM
V
Virtus_Probi Offline
V
One area of difference is LSPI, where ACEA will not be introducing tests until A7/B7.
That standard will also include timing chain wear and turbo deposit tests like d1G2.
2014 Forester XT, 114800 miles
Last Change;
Valvoline AFS 5W30
Tokyo Roki 15208AA170 oil filter
Subaru 16546AA10A air filter
Re: Comparison engine oil ACEA A5/B5 ILSAC GF4/5 and ACEA A3/B3/B4 [Re: Pidziek] #5135519 06/16/19 08:19 AM
K
Kamele0N Offline
K
Put ACEA beside...but I am pretty sure that MB 229.5x and VW 504/507 both have tests for a chain wear...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: Comparison engine oil ACEA A5/B5 ILSAC GF4/5 and ACEA A3/B3/B4 [Re: bbhero] #5135543 06/16/19 08:44 AM
Y
yowps3 Offline
Y
Which would be the better spec for a V6 T-Gdi?
D1g2 or ACEA A5 ?
Re: Comparison engine oil ACEA A5/B5 ILSAC GF4/5 and ACEA A3/B3/B4 [Re: yowps3] #5135566 06/16/19 09:12 AM
turnbowm Offline
D1g2 or ACEA A5 ?
D1 G2 offers LSPI protection, A5 doesn't.
2015 Kia Optima EX 2.4L GDI
2015 Chevy Volt
Re: Comparison engine oil ACEA A5/B5 ILSAC GF4/5 and ACEA A3/B3/B4 [Re: turnbowm] #5135602 06/16/19 10:12 AM
B
BLND1 Offline
B
D1g2 or ACEA A5 ?
As stated earlier - when in doubt, go for Mobil1 or PP.
Both offer ACEA A5 and D1G2.
Re: Comparison engine oil ACEA A5/B5 ILSAC GF4/5 and ACEA A3/B3/B4 [Re: Pidziek] #5135614 06/16/19 10:30 AM
K
Kamele0N Offline
K
I personally would never use low HTHS oil in any TGDi engine...
Re: Comparison engine oil ACEA A5/B5 ILSAC GF4/5 and ACEA A3/B3/B4 [Re: yowps3] #5135782 06/16/19 02:45 PM
B
BMWTurboDzl Offline
B
D1g2 or ACEA A5 ?
Whatever your manual calls for. BITOG tends to blow things out of proportion. Not ALL turbo DI engines have to contend with LSPI.
435i
